查看: 8860|回复: 12
RT809F verify error. I'm need help.
发表于: 2016-1-2 05:29:23
Hello
I see the following error during programming. What is the reason of this?
Chip auto detect ok. But I see reading and writing verification error.
001: SN: 20151008213012-034949
002:  SN:20151008213012-034949 , Programmer Firmware Version : V2.0 .
003:  Scanning VGA port with wire mode A...
004:  Scanning VGA port with wire mode D...
005:  Scanning VGA port with wire mode B...
006:  Scanning VGA port with wire mode C...
007:  Scanning SPI_Ext port ...
008:  Auto identify: 1 matched.
009:  Current selected : KB9012QF_A3,Size: 1Mbits,128KBytes.
010:  >------------------------------------OK---------------------------------------<
015: D: \ PC-TAM \ BIOS \ KBCROM \ KB9012 \ QCLA4 of La-8861P.B
016:  File loading OK. Checksum: 16bit_0x91DA,32bit_0x010491DA;
017:  Programming device......
018:  Erase & Write successfully,20.28 seconds elapsed.
019:  Auto verifying...
020:  Device blank checked failure,start address: 0x0.
021:  Verified failure,0.238 seconds elapsed.
022:  Write error occurred,Operation was aborted
 楼主| 发表于: 2016-1-6 06:21:14
Thanks Admin.
But same error again.
001:  D:\BILGISAYAR-TAMIR\BIOS\KBC ROM\KB9012\QCLA4 LA-8861P.BIN
002:  File loading OK. Checksum: 16bit_0x91DA,32bit_0x010491DA;
003:  Programming device......
004:  Erase & Write successfully,19.91 seconds elapsed.
005:  Auto verifying...
006:  Device blank checked failure,start address: 0x7DA.
007:  Verified failure,0.108 seconds elapsed.
008:  Write error occurred,Operation was aborted
发表于: 2016-1-2 09:09:24
楼主你请教季老师啊?
发表于: 2016-1-2 10:21:27
 楼主| 发表于: 2016-1-2 22:07:30
AutoISP auto detect OK.  Write ok, but  verify error.
发表于: 2016-1-2 22:38:34
肿么了楼主
发表于: 2016-1-3 09:28:31 来自手机
都是英文高手
发表于: 2016-1-3 15:12:32
Note that the best control of the connection line within the 10CM, as well as the line can be short, as short as possible.
发表于: 2016-1-4 09:35:10
1. Please use the new version : http://ifix.net.cn/thread-325-1-1.html ;
2. Please make sure that you do not use USB hub to connect the RT809F;
3. Please try to replace a new chip and write again.
发表于: 2016-1-4 09:35:34
1. Please use the newest version : http://ifix.net.cn/thread-325-1-1.html ;
2. Please make sure that you do not use a USB hub to connect the RT809F;
GMT+8, 2024-12-21 12:55 , Processed in 0.063357 sec., 14 queries .
