查看: 9759|回复: 12
这个打印信息是咋回事
发表于: 2021-2-1 20:07:27
组装机,版号TP.MS358.PB818  芯片MSD6S358ATH。原芯片烫手。不开机。换芯片后。打印信息这样。不停重复
C_ON
BIST0-OK
BIST1-OK
#_U
Relocation Offset is: 01700000
[AT][MB][start ub][473]
U-Boot 2011.06-00000-gaa9daf0-dirty (Sep 07 2018 - 15:06:16)
[SYS][Utopia]: Function = SYSOpen, Line = 1143, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 1162, [SYS INFO] OPEN INSTANCE...
create instance at 28CEB240 with private size 128 bytes at 28CEB288
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 28CEB310 with private size 80 bytes at 28CEB358
create instance at 28CEB3B0 with private size 48 bytes at 28CEB3F8
uboot held at [28ADDF60~2A500000],size=01A220A0
DRAM:  165 MiB
Now running in RAM - U-Boot at: 29B00000
eMMC: HS200 200MHz
eMMC 3.53 GB [70FFF8h]
SAR5=ON
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MAC:  0x78: 0xDD: 0xD9: 0xBC:0x48: 0x9D
[CPU][Utopia]:
[CPU INFO] cpu opencreate instance at 28CFB868 with private size 44 bytes at 28CFB8B0
[CPU][Utopia]: CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[tu]: ????? ?`???xV4
[AT][MBoot][Driver Init][652]
<env reload for CHECK_IF_MBOOT_DEFAULT_ENV>
mmc change mount : system
** File not found /etc/set_env
[ERROR] vfs_getsize:420: ext4filesize mmc fail, try again!
[ERROR] vfs_getsize:424: ext4filesize mmc fail
[ERROR] loadscript:866: No enough buffer or path fail(/etc/set_env) :
[src/MsUtility.c] [loadscript]
MPOOL size : 0x200000
[ERROR] Secure_doAuthentication:124: signature[0+224]=32, digest[0]=33
[ERROR] Secure_doAuthentication:125: Error: Authentication Fail!!
[ERROR] Secure_doAuthentication:126:  Image address=0x28D1ACD0
[ERROR] Secure_doAuthentication:127:  RSA encryption's result=
[DUMP] Secure_doAuthentication:128:
28ADCC48: 3B CE F4 49 24 C1 DB 8D 51 C0 39 36 85 E1 3E 32    ;..I$...Q.96..>2
28ADCC58: 7D 62 6F B6 AF 20 19 10 34 68 24 A4 FF 9C 84 80    }bo.. ..4h$.....
[ERROR] Secure_doAuthentication:129:  Image's SHA result=
[DUMP] Secure_doAuthentication:130:
28ADD048: 33 77 28 2A 18 10 E7 95 74 EB 01 B8 16 03 B9 6F    3w(*....t......o
28ADD058: 0B 2F 9B 18 8D 91 FB 7A 9A 83 10 76 45 D4 B7 DB    ./.....z...vE...
[ERROR] isCustomerKeyBankValid:1106:  Auth CustomerKeyBank FAIL
[ERROR] isCustomerKeyBankValid:1107:  RSA image public-N key=
[DUMP] isCustomerKeyBankValid:1108:
28ADD094: AA 5E 3F DA D0 1D DF 4A FA FE 67 A1 B5 3B BB 8B    .^?....J..g..;..
28ADD0A4: 93 1F EC BA AC 0F 0C 0E D6 1A 66 EC 04 C4 16 E5    ..........f.....
28ADD0B4: A4 A6 9A AF EF B6 EE 7D A3 E7 A5 59 E4 00 6B C5    .......}...Y..k.
28ADD0C4: FC E9 79 B2 8B 8E 81 13 6C 8A B6 CC 11 D9 A7 CE    ..y.....l.......
28ADD0D4: A8 3C 7A 43 18 35 D0 4D A6 AE 40 CD 4D 04 14 F6    .<zC.5.M..@.M...
28ADD0E4: CA 3D 5E F2 27 4E F3 8C 8A 6F BC 6A C4 CC D1 23    .=^.'N...o.j...#
28ADD0F4: FB CA 63 8A BB C4 05 14 A9 98 12 76 71 F3 A3 6E    ..c........vq..n
28ADD104: A8 B2 07 E4 0E 16 9B F7 5E C4 19 15 BE 3A 9E F2    ........^....:..
28ADD114: 30 9A 76 61 68 11 91 D6 AC 2C 22 AA 46 19 4D E8    0.vah....,".F.M.
28ADD124: C7 12 B7 EF CE 29 D3 8B B9 20 95 5C 0E 5A 26 FC    .....)... .\.Z&.
28ADD134: F9 65 1F 56 8F 3C DB 60 85 36 4A 2A 35 7D 94 BD    .e.V.<.`.6J*5}..
28ADD144: CF D0 CF 6C 61 50 64 B1 2A 9A 7D A2 AC 03 EC 25    ...laPd.*.}....%
28ADD154: 48 99 E0 13 B4 86 4E 68 15 65 32 06 82 3F 02 BE    H.....Nh.e2..?..
28ADD164: 4C 0D 59 4B 4C F6 54 82 38 AA 09 47 A3 1A 8B A1    L.YKL.T.8..G....
28ADD174: D1 F8 CC 09 11 15 8F FD 4C 01 46 0C 6F F7 8D B8    ........L.F.o...
28ADD184: 22 E4 87 28 51 F6 C0 09 7C EA D1 5C 46 B4 FB 4B    "..(Q...|..\F..K
[ERROR] isCustomerKeyBankValid:1109:  RSA image public-E key=
[DUMP] isCustomerKeyBankValid:1110:
28ADD194: 00 01 00 01    ....
[ERROR] isCustomerKeyBankValid:1111:  CustomerKeyBank signature=
[DUMP] isCustomerKeyBankValid:1112:
28D1ABD0: 69 23 EF FD 3D D8 B1 91 47 F4 39 BE DD DF C9 FC    i#..=...G.9.....
28D1ABE0: D8 0B 16 9E D5 61 BF 61 AE 4F C3 6B C1 4F 16 EF    .....a.a.O.k.O..
28D1ABF0: 82 78 23 ED 95 2F 27 F1 71 45 5C 24 F0 09 D1 78    .x#../'.qE\$...x
28D1AC00: 74 3E 78 C0 22 0A 09 87 C9 F7 CD BF D0 33 F1 E1    t>x."........3..
28D1AC10: F2 A2 75 82 71 01 FE 27 8A A0 3B 85 9B 71 CC A0    ..u.q..'..;..q..
28D1AC20: 6F AC 71 1D 2A D9 4F 10 A3 8B 73 EF 41 54 C9 92    o.q.*.O...s.AT..
28D1AC30: F4 15 BA 7B 63 A0 30 46 30 C8 E6 28 D9 1E 58 17    ...{c.0F0..(..X.
28D1AC40: BE 32 65 AF 49 87 DA 5A A0 11 92 A7 38 F0 90 B4    .2e.I..Z....8...
28D1AC50: C2 7F 9D C3 FD 50 37 9A E5 3D 34 3F 74 4B A2 2B    .....P7..=4?tK.+
28D1AC60: 99 F9 8C B2 92 2A 8F E7 28 2A DF 47 C1 90 F1 07    .....*..(*.G....
28D1AC70: 00 A6 B0 BD 93 E5 CA 80 02 5B BC C9 51 1D 16 6A    .........[..Q..j
28D1AC80: 76 76 52 CF 97 D4 65 05 39 BC 2C 69 17 BE 60 4F    vvR...e.9.,i..`O
28D1AC90: 80 7F 76 37 14 F0 CB 85 E8 47 51 E1 6B 1E CF C6    ..v7.....GQ.k...
28D1ACA0: 50 89 E2 CD 1E FC 15 CB DD 41 15 E9 77 1E 55 B4    P........A..w.U.
28D1ACB0: A2 D4 C6 26 77 51 41 2D 36 D5 7D 13 23 C1 3A C1    ...&wQA-6.}.#.:.
28D1ACC0: 35 7A 76 A1 36 23 58 73 B1 09 6D 0C 0B E8 9D 08    5zv.6#Xs..m.....
[ERROR] isCustomerKeyBankValid:1113:  clear CustomerKeyBank image=
[DUMP] isCustomerKeyBankValid:1114:
28D1ACD0: 47 1D F2 BD 93 85 8F 90 E8 BC A9 C7 ED 87 15 29    G..............)
28D1ACE0: 56 64 BA CA 67 C5 A3 24 45 B5 5D BC 4A 94 65 66    Vd..g..$E.].J.ef
28D1ACF0: 04 33 32 5B 14 C3 8B 43 99 3E 4E C8 99 40 0E C7    .32[...C.>N..@..
28D1AD00: D0 6A 2D 06 78 C9 6D B9 4B D0 89 F9 2D 1D 89 D7    .j-.x.m.K...-...
28D1AD10: 0A FD E2 95 C5 48 45 18 AE DA 47 3B 78 2A 3C AC    .....HE...G;x*<.
28D1AD20: 0B 9C BB 78 C0 A1 A9 44 44 48 8E 92 9E B9 0E 56    ...x...DDH.....V
28D1AD30: CF 04 18 DF 34 89 4D 26 6B 3D 45 3F 53 30 D9 78    ....4.M&k=E?S0.x
28D1AD40: 59 C2 0E 86 38 2F DF C8 F4 71 AE 1A 96 47 2C C2    Y...8/...q...G,.
28D1AD50: 13 A1 23 09 30 BF C9 67 63 A9 29 09 00 AC CD 3E    ..#.0..gc.)....>
28D1AD60: 49 36 C5 4C 56 E4 71 4F 40 53 8C 40 0B 14 F6 7B    I6.LV.qO@S.@...{
28D1AD70: 22 6B 91 24 59 21 08 0C 72 D9 C2 F0 5F 82 B1 51    "k.$Y!..r..._..Q
28D1AD80: DB EC 66 06 68 72 95 6B 0F 1E FC D6 5C CE 3F 20    ..f.hr.k....\.?
28D1AD90: AA A8 A8 7B 30 72 1B 35 03 51 C5 E8 DF 03 DB AF    ...{0r.5.Q......
28D1ADA0: BD AC C9 40 A3 82 C8 C5 4B 22 45 2F 53 59 6C 2D    ...@....K"E/SYl-
28D1ADB0: 0F 43 66 76 D5 18 D7 85 85 8C CA 2B A2 B5 E3 E8    .Cfv.......+....
28D1ADC0: 17 D5 73 63 BD 0D C2 0B C7 FA 5A 8F 5B B0 B5 6D    ..sc......Z.[..m
28D1ADD0: 32 AF 2A C6 63 62 1F 9C EF 0F 75 19 94 A7 51 FF    2.*.cb....u...Q.
28D1ADE0: E2 45 E2 55 37 E6 37 2C D4 14 57 E0 0B 79 71 E6    .E.U7.7,..W..yq.
28D1ADF0: 09 53 40 B4 7F 15 3D 36 C3 17 C5 6F DC E1 1B FB    .S@...=6...o....
28D1AE00: 6C 89 8E BA C9 38 5C 0D 4B 0B 22 99 1B A0 F1 CE    l....8\.K.".....
28D1AE10: C1 75 D0 C1 59 39 5E FD 0F 55 A8 1F 1E 55 CD CC    .u..Y9^..U...U..
28D1AE20: 76 17 21 4A 50 A7 9D 64 7A 9F 22 AB 37 C9 92 4C    v.!JP..dz.".7..L
28D1AE30: 75 48 CC 3F 49 FB 23 96 1E 7D 24 4D 71 7B 74 3B    uH.?I.#..}$Mq{t;
28D1AE40: BA CF BA E0 07 4F 22 9F 38 4F 4F 56 52 03 C3 B4    .....O".8OOVR...
28D1AE50: EB C5 C5 E2 0F 5A C5 FE 72 C4 DF 6A 02 62 BB F2    .....Z..r..j.b..
28D1AE60: 7C 75 86 29 F1 FE F5 47 4E 25 9D 72 A3 3D F4 88    |u.)...GN%.r.=..
28D1AE70: DE B7 E9 A4 C1 A7 62 58 A6 B7 93 C6 70 E8 7B 7F    ......bX....p.{.
28D1AE80: 2C 13 D9 04 06 CD 30 57 46 9E 23 04 35 FF F8 B9    ,.....0WF.#.5...
28D1AE90: 39 37 3F FC 49 F3 C9 58 CB EC 30 D7 CC 91 9C B4    97?.I..X..0.....
28D1AEA0: 1B 3C 0F B0 EE 87 D7 41 7E 30 CA F4 EB 30 02 74    .<.....A~0...0.t
28D1AEB0: 65 FD 9B 19 73 33 3B AE 01 D9 C6 1A CD C7 43 E8    e...s3;.......C.
28D1AEC0: 49 74 C3 9A 7E 30 0C 8C 96 7D 93 AF CC C0 5F 6F    It..~0...}...._o
28D1AED0: A0 DB 78 B8 ED 4C AA CB 99 69 FE A2 EB 90 5C FA    ..x..L...i....\.
28D1AEE0: 27 C8 34 72 02 F3 A6 77 05 20 D8 BB D4 12 4D D6    '.4r...w. ....M.
28D1AEF0: BD 2D 30 75 47 CA F9 EE D5 7E 13 A1 29 BD E6 2B    .-0uG....~..)..+
28D1AF00: 76 D4 ED 40 93 78 9D 68 89 0A D1 79 B1 9D 83 2A    v..@.x.h...y...*
28D1AF10: 20 11 E3 DE 32 C3 B8 E1 96 89 E1 7B B6 AB A1 74     ...2......{...t
28D1AF20: F7 00 7D BA F9 BF F7 7F 04 F1 A4 AB 7D 31 8C EB    ..}.........}1..
28D1AF30: A6 7C FC E0 67 E1 D4 61 A4 DE A9 36 86 B1 CE 4C    .|..g..a...6...L
28D1AF40: 9A F6 39 D5 60 62 F5 CF 23 F5 54 15 E8 19 8B 53    ..9.`b..#.T....S
28D1AF50: B9 91 09 8A 91 5E 29 68 FD 9F BD 9E 0D D6 53 9E    .....^)h......S.
28D1AF60: 36 CC 94 B2 61 49 73 3E 65 75 10 35 07 98 19 ED    6...aIs>eu.5....
28D1AF70: BA 6E 4F EA B7 9F D5 91 67 DF AF A2 39 9E 62 16    .nO.....g...9.b.
28D1AF80: 5E 09 7D EA 5E 4A FC BF B1 4A 01 80 4E C2 6B EC    ^.}.^J...J..N.k.
28D1AF90: 8D 6A 5D 7F 5C A7 A3 A1 5A 52 6E 2F 5A 46 63 46    .j].\...ZRn/ZFcF
28D1AFA0: 4A 5B 7C 7F 29 AA 27 28 33 E9 18 91 CF DC F2 FF    J[|.).'(3.......
28D1AFB0: BC 37 E2 B4 5B 10 67 F7 E1 B7 EA 7B 97 A3 5F 0A    .7..[.g....{.._.
28D1AFC0: 7A B9 7E 10 E3 AC 40 43 E1 ED 86 0D 05 85 9B 40    z.~...@C.......@
28D1AFD0: DD 32 A8 1E 1B 3B 1F 1B 5E 34 20 B2 D7 4A A2 89    .2...;..^4 ..J..
28D1AFE0: BF 68 15 EB 6D 29 22 40 79 B1 21 DD 6F 2B 32 6C    .h..m)"@y.!.o+2l
28D1AFF0: A9 AB FB 87 A8 D6 6F 2D EE 83 3A 3B A7 C3 F6 6C    ......o-..:;...l
28D1B000: 73 66 08 46 AA CA 43 BF 37 14 9D A7 CD 20 36 53    sf.F..C.7.... 6S
MBoot will reset within 10s, if you don't want to reset, please run wdt_enable 0!!
jump_to_console start!!
<< MStar >># UART_115200
发表于: 2021-2-1 23:01:25
试试进控制台输入cu升级一下
 楼主| 发表于: 2021-2-2 11:12:16
技术支持008 2021-2-1 23:01
试试进控制台输入cu升级一下
谢谢   我试试
发表于: 2021-2-2 11:31:56
这是芯片ID 绑定失败,身份验证失败的打印信息。
 楼主| 发表于: 2021-2-2 11:43:15
进不了控制台  。不停重复打印信息
 楼主| 发表于: 2021-2-2 11:46:32
00-00_ODYBB 2021-2-2 11:31
原机数据读出写进别的芯片。就出3行打印信息。第三行是效验失败。 不动了
发表于: 2021-9-6 07:46:42
Mboot 将在 10s 内重置, 如果您不想重置, 请运行wdt_enable 0!! jump_to_console开始!! << Mstar >># UART_115200
http://ifix.net.cn/thread-103489 ... 0%E5%B0%86%E5%9C%A8,%E5%BC%80%E5%A7%8B%EF%BC%81%EF%BC%81%20%3C%3C%20Mstar%20%3E%3E%23%20UART_115200
发表于: 2021-9-6 08:25:59
原芯片烫手。不开机。换芯片后。打印信息这样。不停重复 C_ON BIST0-OK BIST1-OK #_U Relocation Offset is: 01700000 [AT][MB][start ub][473]   U-Boot 2011.06-00000-gaa9daf0-dirty (Sep 07 2018 - 15:06:16)   [SYS][Utopia]: Function = SYSOpen, Line = 1143, current resource pri_shm content is: 0 [SYS][Utopia]: Function = SYSOpen, Line = 1162, [SYS INFO] OPEN INSTANCE... create instance at 28CEB240 with private size 128 bytes at 28CEB288 [MIU][Utopia]: [MIU INFO] miu opencreate instance at 28CEB310 with private size 80 bytes at 28CEB358 create instance at 28CEB3B0 with private size 48 bytes at 28CEB3F8   uboot held at [28ADDF60~2A500000],size=01A220A0 DRAM: 165 MiB Now running in RAM - U-Boot at: 29B00000   eMMC: HS200 200MHz eMMC 3.53 GB [70FFF8h]  SAR5=ON: 串行 出: 串行 Err: 串行 网: 未找到以太网。 MAC: 0x78: 0xDD: 0xD9: 0xBC:0x48: 0x9D [CPU] [乌托邦]: [CPU INFO] cpu 开放创造实例在 28cfb8 68 与私人大小 44 字节在 28CFB8B0 [CPU] [乌托邦]: CPUIoctl - MDrv_CMD_CPU_QueryClock [乌托邦 INFO] 关闭模块命名 [tu]: ??????`???xV4   [AT] [MBoot] [驱动程序 Init]   [652] <为CHECK_IF_MBOOT_DEFAULT_ENV> mmc 更改安装重新加 载: 系统 ** 未找到 / 等/set_env [0;31m[错误] vfs_getsize:420: [0mext4 文件 mmc 失败, 再试一次! ** 未找到 /etc/set_env [0;31m][错误] vfs_getsize:424: [0mext4 文件 mmc 故障 [0;31m] 错误] 负载脚本:866: [0m 没有足够的缓冲或路径故障 (/等/set_env) : [src/使用.c] [负载 脚本] MPOOL 大小 : 0x200000 [0;31m][错误] Secure_doAuthentication:124: [0msignature]0=224]=32,摘要 [0]=33 [0;31m][错误] Secure_doAuthentication:125: [0meror: 身份验证失败!! [0;31m[错误] Secure_doAuthentication:126: [0m]0;31m 图像地址=0x28D1ACD0 [0m]0;31m[错误] Secure_doAuthentication:127: [0m]0;31m RSA 加密结果 =0m [0;31m][DUMP] Secure_doAuthentication:128:[0m 28ADCC48:3B CE F4 49 24 C1 DB 8D51 C0 39 36 85 E1 3E 32:.我...Q.96.>2 28ADCC58: 7D 62 6F B6 AF 20 19 10 34 68 24 A4 FF 9C 84 80+bo....4h$... [0;31m[错误] Secure_doAuthentication:129: [0m [0;31m 图像的 SHA 结果][0m [0;31m][DUMP] Secure_doAuthentication:130:]0m 28ADD048: 33 77 28 2A 18 10 E7 95 74 EB 01 B8 16 03 B9 6F 3w (*.t......o 28ADD058: 0B 2F 9B 18 8D91 FB 7A 9A 83 10 76 45 D4 B7 DB./....z... [0;31m [错误] 是客户钥匙银行瓦利德: 1106: [0m ]0;31m Auth 客户钥 匙银行失败 [0]0;31m [错误] 是客户钥匙银行瓦利德: 1107: [0m]0;31m Rsa 图像公共 -N 键 =0m [0;31m][DUMP] 是客户 钥匙银行瓦利德:1108:[0m 28ADD094: AA 5E 3F DA D0 1D DF 4A FA FE 67 A1 B5 3B BB 8B +?....J..g..;.. 28ADD0A4: 93 1F EC BA AC 0F 0C 0E D6 1A 66 EC 04 C4 16 E5.。f..... 28ADD0B4: A4 A6 9A AF EF B6 EE 7D A3 E7 A5 59 E4 00 6B C5..........Y..k. 28ADD0C4: FC E9 79 B2 8B 8E 81 13 6C 8A B6 CC 11 D9 A7 CE.y.....l....... 28ADD0D4: A8 3C 7A 43 18 35 D0 4D AE 40 CD 4D 04 14 F6 .<zC.5.M.@.M... 28ADD0E4: CA 3D 5E F2 27 4E F3 8C 8A 6F BC 6A C4 CC D1 23 ++N...o. j.# 28ADD0F4: FB CA 63 8A BB C4 05 14 A9 98 12 76 71 F3 A3 6E.c........vq..n 28ADD104: A8 B2 07 E4 0E 16 9B F7 5E C4 19 15 BE 3A 9E F2...... 28ADD114: 30 9A 76 61 68 11 91 D6 AC 2C 22 AA 46 19 4D E8 0.vah.....M" 28ADD124: C7 12 B7 EF CE 29 D3 8B B9 20 95 5C 0E 5A 26 FC....)... .\.Z&. 28ADD134: F9 65 1F 56 8F 3C DB 60 85 36 4A 2A 35 7D 94 BD.e.V.<.'.6J*5]. 28ADD144: CF D0 CF 6C 61 50 64 B1 2A 9A 7D A2 AC 03 EC 25.拉普德。.. % 28ADD154: 48 99 E0 13 B4 86 4E 68 15 65 32 06 82 3F 02 BE....Nh. e2.?.. 28ADD164: 4C 0D 59 4B 4C F6 54 82 38 AA 09 47 A3 1A 8B A1 L.YKL.T.8.G.... 28ADD174: D1 F8 CC 09 11 15 8F FD 4C 01 46 0C 6F F7 8DB8...洛杉矶... 28ADD184: 22 E4 87 28 51 F6 C0 09 7C EA D1 5C 46 B4 FB 4B"。。(问:|.• F.K [0;31m][错误] 是客户钥匙银行瓦利德: 1109: [0m [0;31m RSA 图像公共 E 键][0m ]0;31m [DUMP] 是客户钥匙银行瓦利德: 1110:[0m 28ADD194: 00 01 00 01.... [0;31m [错误] 是客户钥匙银行瓦利德: 1111: [0m ]0;31m 客户钥匙银行 签名] [0 米]0;31m [DUMP] 是客户钥匙银行Valid:1112:[0m 28D1ABD0: 69 23 EF FD 3D D8 B1 91 47 F4 39 BE DD DF C9 FC i#.=...G.9. 28D1ABE0: D8 0B 16 9E D5 61 BF 61 AE 4F C3 6B C1 4F 16 EF....a.a.O.O. 28D1ABF0: 82 78 23 ED 95 2F 27 F1 71 45 5C 24 F0 09 D1 78 .x#./'qE]...x 28D1AC00: 74 3E 78 C0 22 0A 09 87 C9 F7 CD BF D0 33 F1 E1 t>x"。........ 3.28D1AC10: F2 A2 75 82 71 01 FE 27 8A A0 3B 85 9B 71 CC A0 .q.. 28D1AC20: 6F AC 71 1D 2A D9 4F 10 A3 8B 73 EF 41 54 C9 92 o.q.q.o.s.AT. 28D1AC30: F4 15 BA 7B 63 A0 30 46 30 C8 E6 28 D9 1E 58 17.\c.0F0.(..X. 28D1AC40: BE 32 65 AF 49 87 DA 5A A0 11 92 A7 38 F0 90 B4 .2e.I..Z....8... 28D1AC50: C2 7F 9D C3 FD 50 37 9A E5 3D 34 3F 74 4B A2 2B.P7.+4?tK.+ 28D1AC60: 99 F9 8C B2 92 2A 8F E7 28 2A DF 47 C1 90 F1 07.......(*.G.... 28D1AC70: 00 A6 B0 BD 93 E5 CA 80 02 5B BC C9 51 1D 16 6A.。[..Q..j 28D1AC80: 76 76 52 CF 97 D4 65 05 39 BC 2C 69 17 BE 60 4F vvR...e.9.,即。'O 28D1AC90: 80 7F 76 37 14 F0 CB 85 E8 47 51 E1 6B 1E CF C6 .v7.GQ.k. 28D1ACA0: 50 89 E2 CD 1E FC 15 CB DD 41 15 E9 77 1E 55 B4 P..一个。。w.U. 28D1ACB0: A2 D4 C6 26 77 51 41 2D 36 D5 7D 13 23 C1 3A C1...•wQA-6.#.:. 28D1ACC0: 35 7A 76 A1 36 23 58 73 B1 09 6D 0C 0B E8 9D 08 5zv.6#X..m..... [0;31m [错误] 是客户钥匙银行瓦利德: 1113: [0m [0;31 米清晰客户钥匙银行 图像] [0m]0;31m [DUMP] 是客户钥匙银行瓦利德:1114:[0m 28D1ACD0: 47 1D F2 BD 93 85 8F 90 E8 BC A9 C7 ED 87 15 29 G....) 28D1ACE0: 56 64 BA CA 67 C5 A3 24 45 B5 5D BC 4A 94 65 66 Vd..g..$E。]。J.ef 28D1ACF0: 04 33 32 5B 14 C3 8B 43 99 3E 4E C8 99 40 0E C7 .32 [...C.>N.@.. 28D1AD00: D0 6A 2D 06 78 C9 6D B9 4B D0 89 F9 2D 1D 89 D7 .j-x.m.K.-... 28D1AD10: 0A FD E2 95 C5 48 45 18 AE DA 47 3B 78 2A 3C AC....他。。。G;x*<。 28D1AD20: 0B 9C BB 78 C0 A1 A9 44 44 48 8E 92 9E B9 0E 56...x...赫德...V 28D1AD30: CF 04 18 DF 34 89 4D 26 6B 3D 45 3F 53 30 D9 78.4.M=E?S0.x 28D1AD40: 59 C2 0E 86 38 2F DF C8 F4 71 AE 1A 96 47 2C C2 Y.8/...q...G,. 28D1AD50: 13 A1 23 09 30 BF C9 67 63 A9 29 09 00 AC CD 3E.#0.gc.....> 28D1AD60: 49 36 C5 4C 56 E4 71 4F 40 53 8C 40 0B 14 F6 7B I6.LV.qO@S.• 28D1AD70: 22 6B 91 24 59 21 08 0C 72 D9 C2 F0 5F 82 B1 51"k.$Y!..r..._..Q 28D1AD80: DB EC 66 06 68 72 95 6B 0F 1E FC D6 5C CE 3F 20 .f. hr. k. 28D1AD90: AA A8 A8 7B 30 72 1B 35 03 51 C5 E8 DF 03 DB AF.\0r.5.Q... 28D1ADA0: BD AC C9 40 A3 82 C8 C5 4B 22 45 2F 53 59 6C 2D...K"E/Syl-28D1ADB0: 0F 43 66 76 D5 18 D7 85 85 8c CA 2B A2 B5 E3 E8.Cfv....... 28D1ADC0: 17 D5 73 63 BD 0D C2 0B C7 FA 5A 8F 5B B0 B5 6D .Sc...Z.[..m 28D1ADD0: 32 AF 2A C6 63 62 1F 9C EF 0F 75 19 94 A7 51 FF 2.*.cb....u...Q. 28D1ADE0: E2 45 E2 55 37 E6 37 2C D4 14 57 E0 0B 79 71 E6 。欧盟7.7,..W..yq. 28D1ADF0: 09 53 40 B4 7F 15 3D 36 C3 17 C5 6F 直流 E1 1B FB 。S@... 28D1AE00: 6C 89 8E BA C9 38 5C 0D 4B 0B 22 99 1B A0 F1 CE l.8\K...... 28D1AE10: C1 75 D0 C1 59 39 5E FD 0F 55 A8 1F 1E 55 CD CC.u..Y9=.U...U.. 28D1AE20: 76 17 21 4A 50 A7 9D 64 7A 9F 22 AB 37 C9 92 4C 诉!JP.dz."7.L 28D1AE30: 75 48 CC 3F 49 FB 23 96 1E 7D 24 4D 71 7B 74 3B uH.?I.#..}$Mq\t; 28D1AE40: BA CF BA E0 07 4F 22 9F 38 4F 4F 56 52 03 C3 B4.O".8O奥夫尔... 28D1AE50: EB C5 C5 E2 0F 5A C5 FE 72 C4 DF 6A 02 62 BB F2.Z..r..j.b. 28D1AE60: 7C 75 86 29 F1 FE F5 47 4E 25 9D 72 A3 3D F4 88 |u.)...GN.r.。 28D1AE70: DE B7 E9 A4 C1 A7 62 58 A6 B7 93 C6 70 E8 7B 7F.bx....p.\. 28D1AE80: 2C 13 D9 04 06 CD 30 57 46 9E 23 04 35 FF F8 B9 ,.....0WF.#5... 28D1AE90: 39 37 3F FC 49 F3 C9 58 CB EC 30 D7 CC 91 9C B4 97?I.X.0.... 28D1AEA0: 1B 3C 0F B0 EE 87 D7 41 7E 30 CA F4 EB 30 02 74 .<....A+0.t 28D1AEB0: 65 FD 9B 19 73 33 3B AE 01 D9 C6 1A CD C7 43 E8 e...s3;...C. 28D1AEC0: 49 74 C3 9A 7E 30 0C 8C 96 7D 93 AF CC C0 5F 6F 它.+0...|...._o 28D1AED0: A0 DB 78 B8 ED 4C AA CB 99 69 FE A2 EB 90 5C FA.x. l.i....\. 28D1AEE0: 27 C8 34 72 02 F3 A6 77 05 20 D8 BB D4 12 4D D6 '.4r...w. ....M. 28D1AEF0: BD 2D 30 75 47 CA F9 EE D5 7E 13 A1 29 BD E6 2B .-0ug.....• 28D1AF00: 76 D4 ED 40 93 78 9D 68 89 0A D1 79 B1 9D 83 2A诉@.x.h.y...* 28D1AF10: 20 11 E3 DE 32 C3 B8 E1 96 89 E1 7B B6 AB A1 74...2......{...t 28D1AF20: F7 00 7D BA F9 BF F 7 7F 04 F1 A4 AB 7D 31 8C EB.。.........} 1.28D1AF30: A6 7C FC E0 67 E1 D4 61 A4 DE A9 36 86 B1 CE 4C .|.g..一个。。。6...L 28D1AF40: 9A F6 39 D5 60 62 F5 CF 23 F5 54 15 E8 19 8B 53.9.'b..*. t....S 28D1AF50: B9 91 09 8A 91 5E 29 68 FD 9F BD 9E 0D D6 53 9E.。)h...S. 28D1AF60: 36 CC 94 B2 61 49 73 3E 65 75 10 35 07 98 19 ED 6>... 28D1AF70: BA 6E 4F EA B7 9F D5 91 67 DF AF A2 39 9E 62 16 .nO..g...9.b. 28D1AF80: 5E 09 7D EA 5E 4A FC BF B1 4A 01 80 4E C2 6B EC+*J...J..N.k. 28D1AF90: 8D6A 5D 7F 5C A7 A3 A1 5A 52 6E 2F 5A 46 63 46 .j]...ZRn/ZFcF 28D1AFA0: 4A 5B 7C 7F 29 AA 27 28 33 E9 18 91 CF DC F2 FF J[|.)(3.... 28D1AFB0: BC 37 E2 B4 5B 10 67 F7 E1 B7 EA 7B 97 A3 5F 0A 。7.{.._. 28D1AFC0: 7A B9 7E 10 E3 AC 40 43 E1 ED 86 0D 05 85 9B 40 z.+...@C...... 28D1AFD0: DD 32 A8 1E 1B 3B 1F 1B 5E 34 20 B2 D7 4A A2 89 。2......•4.J.. 28D1AFE0: BF 68 15 EB 6D 29 22 40 79 B1 21 DD 6F 2B 32 6C .h.h.m)"@y!o+2l 28D1AFF0: A9 AB FB 87 A8 D6 6F 2D EE 83 3A 3B A7 C3 F6 6C.o-..:;...l 28D1B000: 73 66 08 46 AA CA 43 BF 37 14 9D A7 CD 20 36 53 sf.F..C.7.6s Mboot 将在 10s 内重置, 如果您不想重置, 请运行wdt_enable 0!! jump_to_console开始!! << Mstar >># UART_115200  分享到:   QQ好友和群 收藏  转播   分享   淘帖 回复
http://www.ifix.net.cn/forum.php ... F%E8%8A%AF%E7%89%87,%E6%B7%98%E5%B8%96%20%E5%9B%9E%E5%A4%8D
GMT+8, 2026-3-21 16:31 , Processed in 0.060666 sec., 9 queries .
