查看: 1095|回复: 6
i need help with this board rsag7.820.6823
发表于: 2020-3-24 19:16:00
Hello this is a hisense rsag7.820.6823 turn on and it remains in logo. update via console but still the same
I leave an impression of the boot to see if they can help me
2020-3-23, 14:54:38
COM3, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
H…C…ÃDRAM Channel A Calibration.
1T = (90 - 20) = 70 delay cells
Clock frequency = 798 MHz, Clock period = 1253 ps, 1 delay cell =17 ps
Byte 0 : Gating(-35 ~ 35), Size=71 .
Byte 1 : Gating(-34 ~ 35), Size=70 .
Byte 2 : Gating(-34 ~ 34), Size=69 .
Byte 3 : Gating(-34 ~ 35), Size=70 .
HW Byte 0 : DQS(-9 ~ 16), Size 26 , Set 4.
HW Byte 1 : DQS(-11 ~ 16), Size 28 , Set 3.
HW Byte 2 : DQS(-8 ~ 19), Size 28 , Set 6.
HW Byte 3 : DQS(-10 ~ 18), Size 29 , Set 4.
DATLAT calibration
first_step= 11 total pass= 5 best_step=12 .
TX HW Byte 0 : DQS(2 ~ 25), Size 24, Set 13.
TX HW Byte 1 : DQS(3 ~ 27), Size 25, Set 15.
TX HW Byte 2 : DQS(0 ~ 22), Size 23, Set 11.
TX HW Byte 3 : DQS(1 ~ 25), Size 25, Set 13.
DRAM A Size = 1024 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x99744407
:0x110127d0
:0x34473261
:0x90014a48
LZHS addr:0x00100040
LZHS size:0x00142a80
LZHS checksum:0x0000007a
store RSA & AES keys in DMX SRAM
LZHS begin
Boot
Start Lmain
MT5882 Boot Loader v0.9
Change pinmux register 0xf000d624 (old: 0x       0, new: 0x 1000000)
Change pinmux register 0xf000d600 (old: 0x      a4, new: 0x  4000a4)
Change pinmux register 0xf000d600 (old: 0x  4000a4, new: 0x 14000a4)
Change pinmux register 0xf000d600 (old: 0x 14000a4, new: 0x114000a4)
Change pinmux register 0xf000d600 (old: 0x114000a4, new: 0x914000a4)
Change pinmux register 0xf000d600 (old: 0x914000a4, new: 0x915000a4)
Change pinmux register 0xf000d604 (old: 0x       0, new: 0x 8000000)
Change pinmux register 0xf000d604 (old: 0x 8000000, new: 0x 9000000)
Change pinmux register 0xf000d604 (old: 0x 9000000, new: 0x 9000008)
Change pinmux register 0xf000d60c (old: 0x       0, new: 0x       1)
Change pinmux register 0xf000d60c (old: 0x       1, new: 0x      11)
Change pinmux register 0xf000d628 (old: 0x       0, new: 0x       1)
Change pinmux register 0xf000d60c (old: 0x      11, new: 0x     111)
Change pinmux register 0xf000d60c (old: 0x     111, new: 0x    1111)
Change pinmux register 0xf000d60c (old: 0x    1111, new: 0x   11111)
Change pinmux register 0xf000d60c (old: 0x   11111, new: 0x  111111)
Change pinmux register 0xf000d628 (old: 0x       1, new: 0x     101)
Change pinmux register 0xf000d614 (old: 0x       0, new: 0x   10000)
Change pinmux register 0xf000d614 (old: 0x   10000, new: 0x  110000)
Change pinmux register 0xf000d614 (old: 0x  110000, new: 0x 1110000)
Change pinmux register 0xf000d610 (old: 0x       0, new: 0x       1)
Change pinmux register 0xf000d614 (old: 0x 1110000, new: 0x 1110001)
Change pinmux register 0xf000d628 (old: 0x     101, new: 0x     111)
Change pinmux register 0xf000d614 (old: 0x 1110001, new: 0x 1110011)
Change pinmux register 0xf000d614 (old: 0x 1110011, new: 0x 1110111)
Change pinmux register 0xf000d614 (old: 0x 1110111, new: 0x 1111111)
Change pinmux register 0xf000d604 (old: 0x 9000008, new: 0x 9003008)
Change pinmux register 0xf000d604 (old: 0x 9003008, new: 0x 9000008)
Change pinmux register 0xf000d604 (old: 0x 9003008, new: 0x 901b008)
Change pinmux register 0xf000d624 (old: 0x 1000000, new: 0x31000000)
Change pinmux register 0xf000d604 (old: 0x 901b008, new: 0x 90db008)
Change pinmux register 0xf000d604 (old: 0x 90db008, new: 0x 96db008)
Change pinmux register 0xf000d610 (old: 0x       1, new: 0x  300001)
Change pinmux register 0xf000d604 (old: 0x 96db008, new: 0x 96db0c8)
Change pinmux register 0xf000d604 (old: 0x 96db0c8, new: 0x 96db6c8)
Change pinmux register 0xf000d610 (old: 0x  300001, new: 0x  330001)
eeprom para:140(cf3f5c) u4MemLen:0x00000009
SIF_Master0: V2 design
eeprom para:149(cf3f68) u4MemLen:0x00000009
eeprom para:152(cf3f74) u4MemLen:0x00000009
eeprom para:140(cf3f34) u4MemLen:0x00000009
eeprom para:149(cf3f34) u4MemLen:0x00000009
eeprom para:152(cf3f34) u4MemLen:0x00000009
eeprom para:140(f110) u4MemLen:0x00000009
eeprom para:39f(cf3f27) u4MemLen:0x00000001
Get IR HotKey num = 1 .
netflix  HotKey num = 1 .
eeprom para:39f(cf3f57) u4MemLen:0x00000001
HotKeyNumEepOffset is 0x39f,u1HotKeyNum is 1
eeprom para:39b(1500040) u4MemLen:0x00000004
HotKeyEepOffset is 0x39b
HotKey[0] = 0x7
HotKey[1] = 0xf0
HotKey[2] = 0xe
HotKey[3] = 0x0
Hot key in EEPROM is OK ,shouldn't write
eeprom para:39b(1500080) u4MemLen:0x00000004
IR wakeup : w [0xf0028240]= 0xb34cfb04 .
IR wakeup : w [0xf0028244]= 0x9d6250af .
IR DATA register : 0x       0
LDR_FlashCopy 0xf010 0x7a280 0x80
AES init success!
90014a48:34473261:110127d0:90014a48
id1:4a483447 id2:32611101
eMMC Name: H26M31001HPR
Change pinmux register 0xf000d610 (old: 0x  330001, new: 0x  230001)
Change pinmux register 0xf000d604 (old: 0x 96db6c8, new: 0x 96d86c8)
Change pinmux register 0xf000d604 (old: 0x 96d86c8, new: 0x 96db6c8)
Change pinmux register 0xf000d610 (old: 0x  230001, new: 0x  330001)
Support network!eeprom para:216(1500300) u4MemLen:0x0000000e
1st MAC in EEP is valid (a8:a6:48:70:90:33)
1st : (a8:a6:48:70:90:33)
2nd : (ff:ff:ff:ff:ff:ff)
No valid DRAM tag in DRAM.
eeprom para:377(cf3fc8) u4MemLen:0x00000001
eeprom para:37b(cf3fb7) u4MemLen:0x00000001
PDWNC_Init
Change pinmux register 0xf00280b4 (old: 0x 1b00000, new: 0x db00000)
eeprom para:381(cf3f7b) u4MemLen:0x00000001
GPIO_MtkLedCtrlFunc eLedStatus:1----fgledEnabl: 1
Control LED u4BlinkingLedGpio = 204,u4BlinkingLedOnVal = 0
eeprom para:378(cf3fc7) u4MemLen:0x00000001
Read boot logo index from eeprom Index(new): 2,
Loader_ReadNandFlash(17, 2, 0x3391c000, 524288)
Panel Header values [Flag: 0xfe, PanelDataMode: 0].
OSD_SetPlaneSwitchOrder[1,2,0],Switch[2,3,1]
[SA7] vDDDSInit
[SA7] _fgVopllUseDDDS = True
[LVDS] VOPLL Initialize successful !
Change pinmux register 0xf000d600 (old: 0x915000a4, new: 0x915020a4)
[LVDS][backlight] DeltaTime=2686532 us, BLOnDelay=450000 us
[LVDS][backlight] GPIO:210, value=0, temp=0xd2
jpeg_decode(0x3391c000, 524288, 0x3491c000, 524288, 0x3591c000, 1366, 768)
Color:14 BmpAddr:0x3591c000 Width:1366 Height:768
<ds>: Get Flip/Mirror config value is 1.
<ds>====u1FlipMirrorEnable 3
[OSD]DBG Timing is Front Scaler
[OSD]i4H=177 i4V=9
u4HaderAddr = 0x37e0a000, u4DisAddr=0x37e0b000
Panel 1366 x 768
*************u4BmpPitch=5504******************
u4SrcWidth=1366 u4Value=0
u4OutWidth=1366,u4OutHeight=768,u4OutX=0,u4OutY=0.
OSD_SetPlaneSwitchOrder[0,1,2],Switch[1,2,3]
LDR_OsdDisplay(14, 0x3591c000, 1366, 768) return 0
eeprom para:376(cf3fd1) u4MemLen:0x00000001
update check AP_Flag =0
Flash load lzhs header from 0xa0000 to dram(0x1503d90), size=2048
Decompression uboot to 0x01000000...
Flash load image from 0xa0000 to dram(0x1503d90), size=0x3a8ea
Flash load tz from 0x150(part_4) to dram(0x3ec00000), size=0x0
SHA of Img is wrong
发表于: 2020-3-24 19:47:39
It is recommended to brush the bootstrap first and then upgrade the main program
 楼主| 发表于: 2020-3-24 23:29:06
技术支持008 2020-3-24 19:47
Would brushing be using mtktools? thanks for answering
发表于: 2020-3-25 09:45:01
Yes, MTK brush booting is done with the Flash Tool
 楼主| 发表于: 2020-3-27 19:03:51
技术支持008 2020-3-25 09:45
load by data line with my rt809h and it is solved. I have a question. to load file by mtktools is a pkg modified in boot program or is there another file that I am not aware of
thanks
发表于: 2020-3-28 09:15:27
In a metaphorical sense, leading is equivalent to leading the passer-by, and leading wrong means that the guide is lost.I don't know if you understand?
 楼主| 发表于: 2020-3-28 18:48:20
mariano 2020-3-27 19:03
load by data line with my rt809h and it is solved. I have a question. to load file by mtktools is  ...
sorry metaphorically it is not clear to me, I would like more clarity, I appreciate your help to have been very kind in responding
GMT+8, 2024-11-19 21:19 , Processed in 0.061744 sec., 9 queries .
