查看: 1330|回复: 3
哪位大师能看懂得帮忙看下这个打印信息
发表于: 2020-2-25 15:13:35
BIST0-OK
[456789A]
[6789AB]-78
_U
Hello U-Boot
U-Boot 1.1.6 (Dec 30 2011 - 14:35:48)
Board: MSTAR AMBER7 (CPU Speed 504 MHz)
DRAM:  256 MBytes
U-Boot is running at DRAM 0x87600000
Module: KEYPAD USB FAT NAND UBI UBIFS NET SPI STANDBY JFFS2 LOGO OAD ENV=SERIAL
Flash is detected (0x0507, 0xC2, 0x20, 0x15)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 2097152
        u32SecNum      = 32
        u32SecSize     = 65536
>>> nand: AUTO CE/WP
Flash Make code = 0x98, ID = 0xD1
NAND: 128 MBytes
In:    serial
Out:   serial
Err:   serial
Net:   MSVC00B000100100440822TH0000000T(? 恮
EnvFlag =: 0x54AB8CFE.....CONFIG_ENV_ADDR=: 0x1E0000
Check USB port[0]:
Check USB port[1]:
Fail to get miu settings. Use default.
keypad_pressed_1 is:0
keypad_pressed_2 is:0
keypad_pressed is [0]
ir_pressed is [0]
check_sw_upgrade
usb_complete=0 Or NULL
check_usb_upgrade
Hit any key to stop autoboot:  0  0
<< MStar >>#
发表于: 2020-2-25 17:09:53
进了控制台了,提示要升级
 楼主| 发表于: 2020-2-25 20:00:28
长江家电 2020-2-25 17:09
进了控制台了,提示要升级
谢谢老师的指导,这个要刷程序吗?
发表于: 2020-4-10 20:28:42
怎么解决了。主程序升级了吗?
GMT+8, 2025-3-11 13:51 , Processed in 0.051024 sec., 9 queries .
