查看: 1127|回复: 4
WT61P805 READ/WRITE ERROR SOLUTION
发表于: 2020-2-24 16:39:39
Hi Everyone
Here is how to avoid Read/Write Verification errors on WT61P805.Just disconnect the original power supply and use an external 5Volts to power up the MCU.
I was getting errors when using the TV's power supply.
发表于: 2020-2-27 13:08:18
Thank you so much for your sharing.
GMT+8, 2024-12-25 11:13 , Processed in 0.072334 sec., 10 queries .
