查看: 2419|回复: 9
看看这个打印信息是哪里出了问题 飞利浦55PFL5620/T3
发表于: 2020-1-20 10:49:18
主板型号是715G5279-M0D-000-005K故障不开机,测量主板开机端口,按开机键开机端口有3.3v电源,但是不到两秒就没了
连接vga口打印信息如下,最下面几行是在网上翻译单词后填上的
显示事件0x3,0x3是哪里的问题呢?
望各位兄弟给看看是哪里出了问题
2020-1-20, 9:27:3
COM5, BaudRate:115200 bps, RXD: VGA-> 4,TXD: VGA->11, Printed by RT809H:
LZHS addr:0x00100040
LZHS size:0x00680690
LZHS checksum:0x00000014
Boot
Start Lmain
MT5395 Boot Loader v0.9
MUSB none SoftReset 0x29424 = 0x01030000.
MUSB pBase = 0xF0029000 init ok.
MUSB pBase = 0xF002E000 init ok.
+++++++++now set tdv gpio val+++++++++++gpio numer is 203,val is 0
Boot reason: A/C power on!!-------------use external edid, disable internal edid------------------
SIF_Master0: new design
Load T8032 FW (addr: 0x  d3f958, size: 24576)success!!
T8032 FW version: 12
LDR_FlashCopy 0xf010 0xaa680 0x80
Detect NAND flash ID: 0x9590DAAD
Detect HY27U2G8F2CTR NAND flash(SLC): 256MB
NAND_BDM_Mount: Partid=0, offset=0x0, size=0x200000
[BDM] Partition: 0, Bad Block Count: 0
Boot reason: A/C power on!!Boot reason: A/C power on!!PDWNC_PHILIPS_2K11_GetCurrentState: 0x3
[PDWNC]PDWNC_TPV_DetermineNextState : u4Event = 0x6
PDWNC_TPV_DetermineNextState : u4Current = 3
PDWNC_TPV_DetermineNextState : system booting
PDWNC_TPV_DetermineNextState : event = PDWNC_POWER_DOWN_AC_POWER
Current = 0x3, Event = 0x6, Next = 0x3
Disable IR wakeup!
Do USB upgrade
Wait USB medium to be mounted...
No USB Medium on Device.
USB upgrade stop
@@@@@@ consumer mode
Disable VGA wakeup
Standby
Disable IR wakeup!
PDWNC_TPV_SetupPowerDown : State = 0x3
WAKE EN: 0x1000000
[PDWNC]PDWNC_PHILIPS_2K11_SetupPowerDown: u4PowerDownEvent = 0x6
[PDWNC]PHILIPS_2K11_POWER_STATE_POWER_OFF, LED changes to off
PDWNC_TPV_EnterNextState : u4Next = 0x3
H匔吤DRAM Channel A Calibration.
HW Byte 0 : DQS(-3 ~ 27), Size 31, Set 12.
HW Byte 1 : DQS(-2 ~ 26), Size 29, Set 12.
HW Byte 2 : DQS(-2 ~ 28), Size 31, Set 13.
HW Byte 3 : DQS(-2 ~ 25), Size 28, Set 11.
DRAM A Size = 256 Mbytes.
DRAM Channel B Calibration.
HW Byte 4 : DQS(5 ~ 24), Size 20, Set 14.
HW Byte 5 : DQS(-2 ~ 21), Size 24, Set 9.
DRAM B Size = 128 Mbytes.
Boot
Start Pmain
0x00004000
NID=0x9590daad
Boot
Start Lmain
[PDWNC]PDWNC_TPV_DetermineNextState : u4Event = 0x3
PDWNC_TPV_DetermineNextState : event = PDWNC_POWER_DOWN_KEYPAD
PDWNC_TPV_DetermineNextState :  PDWNC_WAKE_UP_REASON_KEYPAD, no quiet boot, next state = 0x2
Current = 0x3, Event = 0x3, Next = 0x2
Enable IR wakeup!
Disable VGA wakeup
Standby
Enable IR wakeup!
PDWNC_TPV_SetupPowerDown : State = 0x2
WAKE EN: 0x1000100
[PDWNC]PDWNC_PHILIPS_2K11_SetupPowerDown: u4PowerDownEvent = 0x3
[PDWNC]PHILIPS_2K11_POWER_STATE_STANDBY, LED changes to standby
PDWNC_TPV_EnterNextState : u4Next = 0x2
HW Byte 1 : DQS(-2 ~ 27), Size 30, Set 12.
Boot
Start Pmain
0x00004000
NID=0x9590daad
Boot
Start Lmain
PDWNC_PHILIPS_2K11_GetCurrentState: 0x2
PDWNC_TPV_DetermineNextState : u4Current = 2
Current = 0x2, Event = 0x3, Next = 0x3
Disable IR wakeup!
@@@@@@ 消费者 模式
禁用 VGA 唤醒
Standby
PDWNC_TPV_DetermineNextState : u4电流 = 2
PDWNC_TPV_DetermineNextState : 系统引导
PDWNC_TPV_确定性极限状态 : 事件 = PDWNC_电源_关机_键
当前 = 0x2, 事件 = 0x3, 下一个 = 0x3
禁用 红外 唤醒!
唤醒 EN: 0x1000000
[PDWNC]PDWNC_PHILIPS_2K11_安装程序: u4断电事件 = 0x3
[PDWNC]PHILIPS_2K11_电源状态_关闭电源, LED 更改为 关
PDWNC_TPV_EnterNextState : u4下一个 = 0x3
 楼主| 发表于: 2020-1-20 14:47:41
刚翻译了一下,但是还是不知道是哪里的问题
2020-1-20,9:27:3
COM5,BaudRate:115200 bps,RXD:VGA-> 4,TXD:VGA-> 11,由RT809H打印:
LZHS地址:0x00100040
LZHS大小:0x00680690
LZHS校验和:0x00000014
开机
启动Lmain
MT5395引导程序v0.9
MUSB无SoftReset 0x29424 = 0x01030000。
MUSB pBase = 0xF0029000初始化正常。
MUSB pBase = 0xF002E000初始化正常。
+++++++++现在设置tdv gpio val +++++++++++ gpio numer是203,val是0
引导原因:A / C上电!! -------------使用外部edid,禁用内部edid ------------------
SIF_Master0:新设计
引导原因:A / C电源打开!T8032在装箱机阶段初始化A / C ...
成功加载T8032 FW(地址:0x d3f958,大小:24576)!
T8032固件版本:12
T8032更改为装载机阶段...
检测NAND闪存ID:0x9590DAAD
检测HY27U2G8F2CTR NAND闪存(SLC):256MB
NAND_BDM_Mount:Partid = 0,偏移量= 0x0,大小= 0x200000
[BDM]分区:0,坏块计数:0
引导原因:A / C电源打开!引导原因:A / C电源打开!PDWNC_PHILIPS_2K11_GetCurrentState:0x3
[PDWNC] PDWNC_TPV_DetermineNextState:u4Event = 0x6
PDWNC_TPV_DetermineNextState:u4Current = 3
PDWNC_TPV_DetermineNextState:系统启动
PDWNC_TPV_DetermineNextState:事件= PDWNC_POWER_DOWN_AC_POWER
当前= 0x3,事件= 0x6,下一个= 0x3
禁用红外唤醒!
做USB升级
等待USB介质安装完毕...
设备上没有USB介质。
USB升级停止
@@@@@@@消费者模式
禁用VGA唤醒
支持
禁用红外唤醒!
PDWNC_TPV_SetupPowerDown:状态= 0x3
唤醒EN:0x1000000
[PDWNC] PDWNC_PHILIPS_2K11_SetupPowerDown:u4PowerDownEvent = 0x6
[PDWNC] PHILIPS_2K11_POWER_STATE_POWER_OFF,LED指示灯熄灭
PDWNC_TPV_EnterNextState:u4Next = 0x3
H匔吤DRAM通道A校准。
硬件字节0:DQS(-3〜27),大小31,设置12。
硬件字节1:DQS(-2〜26),大小29,设置12。
硬件字节2:DQS(-2〜28),大小31,设置13。
硬件字节3:DQS(-2〜25),大小28,设置11。
DRAM A大小= 256 MB。
DRAM通道B校准。
硬件字节4:DQS(5〜24),大小20,设置14。
硬件字节5:DQS(-2〜21),大小24,设置9。
DRAM B大小= 128 MB。
开机
启动Pmain
0x00004000
NID = 0x9590daad
LZHS地址:0x00100040
LZHS大小:0x00680690
LZHS校验和:0x00000014
开机
启动Lmain
MT5395引导程序v0.9
SIF_Master0:新设计
T8032更改为装载机阶段...
[BDM]分区:0,坏块计数:0
[PDWNC] PDWNC_TPV_DetermineNextState:u4Event = 0x3
PDWNC_TPV_DetermineNextState:事件= PDWNC_POWER_DOWN_KEYPAD
PDWNC_TPV_DetermineNextState:PDWNC_WAKE_UP_REASON_KEYPAD,无安静启动,下一个状态= 0x2
当前= 0x3,事件= 0x3,下一个= 0x2
启用红外线唤醒!
@@@@@@@消费者模式
禁用VGA唤醒
支持
启用红外线唤醒!
PDWNC_TPV_SetupPowerDown:状态= 0x2
唤醒EN:0x1000100
[PDWNC] PDWNC_PHILIPS_2K11_SetupPowerDown:u4PowerDownEvent = 0x3
[PDWNC] PHILIPS_2K11_POWER_STATE_STANDBY,LED变为待机状态
PDWNC_TPV_EnterNextState:u4Next = 0x2
H匔吤DRAM通道A校准。
硬件字节1:DQS(-2〜27),大小30,设置12。
DRAM A大小= 256 MB。
DRAM通道B校准。
DRAM B大小= 128 MB。
开机
启动Pmain
0x00004000
NID = 0x9590daad
LZHS地址:0x00100040
LZHS大小:0x00680690
LZHS校验和:0x00000014
开机
启动Lmain
MT5395引导程序v0.9
SIF_Master0:新设计
T8032更改为装载机阶段...
发表于: 2020-1-21 10:50:54
刚翻译了一下,用啥软件,想学学。
等待高手解答。
 楼主| 发表于: 2020-1-21 18:51:00
在一位师傅指导之下,解决了,这个打印信息是正常的,是开机无信号自己关机了,但是关机后必须用遥控才能开机,相当于键控锁了用键控开不了机
发表于: 2020-2-3 17:55:54
启用红外线唤醒!这里已经说清楚了
发表于: 2020-3-12 09:10:06
请教是怎样解决的,能分享一下吗
 楼主| 发表于: 2020-3-16 13:39:57
1470826206 2020-3-12 09:10
请教是怎样解决的,能分享一下吗
这个是遥控关机了,必须用遥控开机,你可以用万能遥控试试
发表于: 2020-3-22 21:19:48
请教一下翻译软件用的是哪个?
发表于: 2020-3-23 08:06:11
终于找到我想要的 看看能不能使用
GMT+8, 2024-12-22 01:41 , Processed in 0.068973 sec., 12 queries .
