查看: 1555|回复: 12
TCL LE50D8900电视机电源板维修
发表于: 2020-1-15 19:27:12
这台电视机有时开机,有时指示灯不亮不开机,不开机时,5SB电压5V,PS电压3V左右。12V,5V,24V没有电压,现在已确认是电源板问题,就是找不到原因,请师傅们分析一下,谢谢了,下面是图纸和实物哦图。
发表于: 2020-1-15 20:31:38
上示波器,一下就OK!问题是故障点要 明确范围
发表于: 2020-1-15 21:04:03
IC2的8脚供电,IC3的12脚供电都有了吗
发表于: 2020-1-15 22:12:29
if you have PS 3 volt that must activate Q14 so that the optocoupler UF1A turns on that activates the UF1B and Q10 then you will have voltage vc pfc and vc pwm
发表于: 2020-1-15 23:19:43
Thank you for your post.
 楼主| 发表于: 2020-1-16 08:43:22
PFC电压正常375V,两个IC电压没测,我今天测一下,我估计与电容有关,或者是漏电,有时开机就正常,正常了只要不关机就能看。
发表于: 2020-1-16 18:59:54
Does pin12 of NCP1396 and pin8 of NCP1653 have voltage of vcc? With a simple multimeter you can measure. Just look where you put the multimeter gnd. if there is no vcc the ic will not start is the first condition you need.
 楼主| 发表于: 2020-1-17 17:20:23
PFC 开机时370,不开机时360v
 楼主| 发表于: 2020-1-17 18:04:26
国外朋友的帖子内容看不懂,谁能翻译一下,谢谢了。
GMT+8, 2024-12-22 16:11 , Processed in 0.057299 sec., 9 queries .
