查看: 1712|回复: 4
RT809H on Ubuntu (Linux)
发表于: 2019-12-24 22:24:35
Hellou dear friends! I don't know Chinese, therefore I will write in English, OK? I can translate your hierogliphs via online translator. Let's go to question
Today I have buy your RT809H device programmer. But I use only Linux-like operational systems. I have a Ubuntu 18.04. I know that in China Ubuntu Kylin OS distributed also. I have a Ubuntu, it's a same thing
Device shell runs properly, I see all windows, menus. Music plays. But! Program shell does not see a programmer! In window on down-right border message appears: "Programmer is not connected".
I see is than some with USB driver. But my system see a programmer, there is a command in linux: lsusb, that list all USB devices connected to computer.
In my case lsusb print string:
  1. lsusb
  2. Bus 001 Device 002: ID 8087:8001 Intel Corp.
  3. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4. Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  5. Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  6. Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  7. Bus 002 Device 009: ID 0403:6010 Future Technology Devices International, Ltd FT2232C Dual USB-UART/FIFO IC
  8. Bus 002 Device 004: ID 09da:054f A4Tech Co., Ltd.
  9. Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
复制代码
Bus 002 Device 009 is a programmer
Other command lsusb -t show more detailed info:
lsusb -t
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 5000M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 480M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/14p, 480M
    |__ Port 9: Dev 9, If 0, Class=Vendor Specific Class, Driver=ftdi_sio, 480M
    |__ Port 9: Dev 9, If 1, Class=Vendor Specific Class, Driver=ftdi_sio, 480M
    |__ Port 13: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
    |__ Port 13: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/8p, 480M
We see a some 'ftdi_sio' device connected with Device 9 via USB2 connection
How to chain this Device 9 to program? Why I can't set port manually in program shell?
Sorry, the programmer doesn't support this system, only support windows system.  发表于 2019-12-25 09:38
 楼主| 发表于: 2019-12-24 22:52:18
p.s. Programmer app runs via WINE. I have installed all Microsoft Visual C++ (via winecfg). Programmer shell application - runs!
 楼主| 发表于: 2019-12-25 14:10:24
shirleyhuang! Deal in drivers only! Program shell is working.
Drivers located in DRIVERS subfolder. There are ftdibus.inf and ftdiport.inf command files. These files make copy driver files from amd64 (or i386) subfolder to windows
There are FTDI driver files. See next link  h t t p s :// www . ftdichip . com / Support/Documents/ InstallGuides . htm (I have can't allowed to insert links)
There are a manual for Linux drivers
Yesterday I was made all that described in manual, but programmer does not see in Linux.
I coose a 'USB Firmware repair' options in menu. On Windows this point works fine, but in Linux i see a message 'USB interface for firmware restoration fails!'
Therefore problem with that I can't point Device 9 (in my OS) in USB list is a programmer. I can't set this manually some in program shell and config file
What can do?
发表于: 2020-6-7 19:47:39
Hi,
I have the same issue using Ubuntu where USB is not recognize by programmer. Anyone could help?
Best Regards
Laurent
GMT+8, 2025-12-15 16:10 , Processed in 0.060926 sec., 16 queries .
