查看: 1422|回复: 7
RT809H initialization Fault with MEC1633L
发表于: 2019-12-12 20:53:14
I have a RT809H and use the Adapter RT-BGA169-02 V1.0
and have a Fault Message on my Main Desktop :
Chip may be damaged or encrypted, the Data is not valid. ( Chips new and a Board )
002: >------------------------------------OK---------------------------------------<
003: The currently selected:MEC1633@BGA169, capacity: 1.50Mbits, 192Kbytes.
004: Adapter model£ºRT-BGA169-02, 0.8,11*11
005: http://www.ifix.net.cn/thread-56900-1-1.html
006: >------------------------------------OK---------------------------------------<
007: Failed to initialize.
008: Start reading chip......
009: Read successful£¬Elapsed time£º0.005 seconds¡£
010: Auto verifying...
011: Verification successful£¬Elapsed time£º0.005 seconds¡£
012: Buffer data checksum: 16bits_0x0000 £¬32bits_0x02670000 :
013: Elapsed time: 0.013 seconds£¬average speed of 30247384 bytes/sec.
014: >------------------------------------OK---------------------------------------<
This is the RT809H and the Adapter BGA169-02 V1.0 and the SMSC MEC1633L
Software version 20191201 is 3 times reinstalled as Administrator
Start as administrator
Win7 Ultimat Sp1
Use original USB Cable  , tested on Front , Top and Rear USB Ports
Deinstalled USB driver and installed new by RT809H Software ( During installation  Programmer disconnected )
USB Serial Converter A
USB Serial Converter B
are shown
With Serial Eprom Programmer works normal
On a other Notebook with win 10 1903 MEC1633 also works normal
So only my personal Desktop is affected.
New win 7 installation is NO opinion  ..... to much other software on the system / need to fix it on actual OS
What can be the reason ?
发表于: 2019-12-13 10:07:01
Hello, sir,  you said that the chip was from a new board?? Which means the chip may be encrypted.
 楼主| 发表于: 2019-12-13 20:48:27
The Chips are new and not encrypted.
On a other Notebook (Win10 1903 )  this Set ( Programmer , Adapter , Chips and Software ) works without Faults. I can read/write/Blanc MEC1633L .
This Fault occurs only on my Desktop ( Win 7 Ultimate  SP1 ) - The Problem is on  one local Computer.
Not possible to install new OS.
Any Ideas ?
发表于: 2019-12-14 11:22:52
TN-Notebooks 2019-12-13 20:48
Suggest you uninstall  the RT809H software, delete the catalogue of RT809H, and then reinstall. After that if still can not solve, you'd better deal your computer system.
 楼主| 发表于: 2019-12-15 23:43:30
The RT809H software deleted , complete Folder of RT809H deleted and then reinstall.
Still  not solved.
i have to deal my computer system. Not possible to install new OS  - have to fix existing Installation.
What can cause this Fault ?
发表于: 2019-12-16 16:51:28
TN-Notebooks 2019-12-15 23:43
Still  not solv ...
Your OS caused
GMT+8, 2024-12-26 20:02 , Processed in 0.054555 sec., 10 queries .
