拔下模板也是一样,打印信息如下,麻烦师傅看一下
UART_115200
BIST0-OK
[123456789A][123456789A][123456789ABC][123456789AB]-5566
U[AT][MB][start ub][0]
U-Boot 2011.06-svn10482 (Feb 19 2014 - 08:57:23)
DRAM: 256 MiB
Hello U-Boot
Stack Pointer at: 87e620c0
uboot held at [8f000000~90000000]
Now running in RAM - U-Boot at: 871f0180
NAND: DMA MODE
[NC_Init] SDR NAND is detected
CIS is found @Blk0
FCIE is set to 54MHz
128 MiB
*** Warning - set default for mtdparts, using default environment
Creating 1 MTD partitions on "nand0":
0x000000640000-0x000000840000 : "mtd=2"
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
UBI: attaching mtd1 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: attached mtd1 to ubi0
UBI: MTD device name: "mtd=2"
UBI: MTD device size: 2 MiB
UBI: number of good PEBs: 16
UBI: number of bad PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 250
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 1
UBI: total number of reserved PEBs: 15
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 1098/907
NAND read: device 0 offset 0x180000, size 0x90
144 bytes read: OK
Volume "MPOOL" found at volume id 0
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Set MAC default
Ethaddr: 0x0: 0x30: 0x1b: 0xba:0x2: 0xdb
It's the last cmd
UBI: mtd1 is detached from ubi0
0x0000013c0000-0x000008000000 : "mtd=5"
UBI: MTD device name: "mtd=5"
UBI: MTD device size: 108 MiB
UBI: number of good PEBs: 858
UBI: number of bad PEBs: 8
UBI: number of user volumes: 6
UBI: available PEBs: 72
UBI: total number of reserved PEBs: 786
UBI: number of PEBs reserved for bad PEB handling: 14
UBI: max/mean erase counter: 251/31
UBIFS: mounted UBI device 0, volume 3, name "CONFIG"
UBIFS: file system size: 8253440 bytes (8060 KiB, 7 MiB, 65 LEBs)
UBIFS: journal size: 1777664 bytes (1736 KiB, 1 MiB, 14 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root: 0 bytes (0 KiB)
Loading file '/PM.bin' to address 0x87ff0000 (size 65536)
Loading file '/PM.bin' to addr 0x87ff0000 with size 35572 (0x00008af4)...
Done
icache config = fea3519f
icache_dsc->linesz = 20
icache_dsc->sets = 100
icache_dsc->ways = 4
icache_dsc->waybit = d
icache_size = 8000
start = 0x87ff0000, end = 0x87ff8000
u8OffsetBit = 5
u8IndexBit = 13
u8WayBit = 15
Clear Way-Select
Disable WST test mode
dcache config = fea3519f
dcache_dsc->linesz = 20
dcache_dsc->sets = 100
dcache_dsc->ways = 4
dcache_dsc->waybit = d
dcache_size = 8000
start = 0x87ff8000, end = 0x88000000
u8OffsetBit = 5
u8IndexBit = 13
u8WayBit = 15
Clear Way-Select
[src/CusPM.c][SetPm2L1] Start PM at :0x87ff0400
