查看: 1703|回复: 4
RT809H NOT READ ENE SERIES EC
发表于: 2019-11-16 15:06:59
HELLO FRIND I HAVE RT809H UNIVERSAL PROGRAMMER WHICH IM FACING PROBLEM NOT READ ENE SERIES EC IO ITS SAY BAD EC BUT USE ANOTHER PROGRAMMER RT809F ITS READ AND WRITE EC.TRY WITH ENE 9012 ADAPTER AND THRU JUMPER WIRE NOT NOT SUCCES. PLZ HELP MEE. THANKS IN ADVANCED.
发表于: 2019-11-18 08:45:52
Thank you indeed for sharing
发表于: 2019-11-19 09:11:11
1.Suggest you do a RT809H self-testing
2.Could you please tell us the chip model in detail?
 楼主| 发表于: 2019-11-27 19:08:09
KB9022 AND ALSO NOT READ MEC RESRIES IO
ITS SAYS 001:  http://www.ifix.net.cn/thread-56900-1-1.html
002:  >------------------------------------OK---------------------------------------<
003:  MEC16xx Chip ID: 0x0
004:  ID verification error.
005:  Programmer setup error.
006:  The currently selected:MEC1633 #ISP, capacity: 1.50Mbits, 192Kbytes.
007:  http://www.ifix.net.cn/thread-56900-1-1.html
008:  >------------------------------------OK---------------------------------------<
009:  MEC16xx Chip ID: 0xFFFFFFFF
010:  ID verification error.
011:  Programmer setup error.
 楼主| 发表于: 2019-11-27 19:13:47
SELFTEST REPORT
Start writing chip......
026:  Buffer data checksum: 16bits_0x13EC £¬32bits_0x000013EC :
027:  1. ZIF open circuit:48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1
028:  2. VGA ISP 4/11/12/15 open circuit
029:  SelfTestBoard 1 is not well placed.
030:  3. HMI open circuit
031:  4. K26-K33 are open circuit
032:  4. K40-K47 are open circuit
033:  6. Pull-up-20K open circuit:1 2 3 4 5 6 7 8 48 47 46 45 44 43 42 41 9 10 11 12 13 14 15 16 40 39 38 37 36 35 34 33 17 18 19 20 21 22 23 24 32 31 30 29 28 27 26 25
034:  Elapsed time: 1.282 seconds£¬average speed of 102 bytes/sec.
035:  >------------------------------------OK---------------------------------------<
Start verifying chip......
037:  Buffer data checksum: 16bits_0x13EC £¬32bits_0x000013EC :
038:  SelfTestBoard 2 is not well placed.
GMT+8, 2024-12-26 21:29 , Processed in 0.100356 sec., 10 queries .
