查看: 1582|回复: 3
求助大师指点创维55E710U的开机打印信息
发表于: 2019-11-5 19:33:04
9R15机芯不开机,是哪里问题,可以写数据试一下吗?
U-Boot 2012.07-svn12491 (Sep 28 2014 - 12:56:45)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
MISC: efuse had NOT been written
[krsv] use default uboot memory:
DRAM:  2 GiB
Watchdog: Enabled
init_amp_prepare
name=AMP_I2C ppcb_enum.Name=AMP_I2C, ppcb_enum.info=300061b48
AMP_I2C=12884901889
name=AMP_DEVICE_ADDR ppcb_enum.Name=AMP_DEVICE_ADDR, ppcb_enum.info=1b00061b18
name=PIN_AMP_MUTE ppcb_enum.Name=PIN_AMP_MUTE, ppcb_enum.info=1790300061b28
no PIN_MISC_951_RST
Board: Tv010 v2 2G Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
MMC:
emmc:mmc_initial(1) Sep 28 2014 12:57:14
RTD299x eMMC: 0
Device: RTD299x eMMC
Manufacturer ID: 90
OEM: 14a
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Extern param: MMC blk:0x7c (to 0x9000)
         rtk_eMMC_read blk_addr=0x0000007c, data_size=0x00000800, buffer=0x00009000
Factory: MMC
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000d435, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000f433, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00286a00, buffer=0x0a900000
Factory: seq:0x15f5, blk:0xc000(pp:0), size:0x286a00 (to 0xa900000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=0
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
BOOT_PAL_NTSC_100_120_HZ=0
boot_power_on_mode=0
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
TAG=21
Panel: Use parameters in tmp/factory/bin_panel/panel.bin
Panel: lg_55_4k2k_vby1_m+
panel_init_1st
Panel: ulFreq:148500000, nDPLL:157499520, Mcode:35, Ncode:3, offset:751
================== P_VBY1_4K2K condition ===================
***** Get Chip ID (3) *****
================== VBY_ONE_PANEL_CHINA_STAR_4K2K_VBY1 ===================
DispI : Finish BISR testing done
DispD : Finish BISR testing done
Panel_Custom_INDEX=6
In:    serial
Out:   serial
Err:   serial
Net:   rtl8139: REALTEK RTL8139 @0xb8016000
Hit Esc or Tab key to enter console mode or rescue linux:  0
------------bootloader message size is 1088
======== Checking into android recovery ====
boot_ac_on=1
stopping USB..
Start Boot Setup ...
[eMMC]STR value:0x0,0x0
No STR...
REG 0xb8060100 : 0x0
JUMP address: 0x0
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000020, buffer=0x0a820000
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000400, buffer=0x0a820000
  FW Table to 0x0a820000, size=0x00000400 (0x0a820400)
  FW Table fr 0x02000000, fw count: 6
part_entry[0].len 0xd2000000
fw_desc_table_v1.paddings 0x400
fw_total_paddings 0x1090400
eMMC_bootcode_area_size0x1800000
EMMC_FACTORY_SIZE 0x800000
g_u32STDsize 0xcef6f800, g_u32STDoffset 0x3090800
blkNO 0x20000, 0x4000000, 0x200, 0x1
         rtk_eMMC_read blk_addr=0x00020000, data_size=0x00001000, buffer=0x00062960
STD identifier NOT match, enter normal boot!!
Normal boot fw follow...
Linux Kernel:
  FW Image to 0x00108000, size=0x00ac4104 (0x00bcc104)
  FW Image fr 0x02008000 (non-lzma)
Audio FW:
  FW Image to 0x81700000, size=0x0020b090 (0x8190b090)
  FW Image fr 0x02acc200 (non-lzma)
  Enter standby, skip this entry
Video FW 1:
  FW Image to 0x81a00000, size=0x002bc208 (0x81cbc208)
  FW Image fr 0x02cd7400 (non-lzma)
Video FW 2:
  FW Image to 0x81d00000, size=0x000b2e64 (0x81db2e64)
  FW Image fr 0x02f93800 (non-lzma)
ECPU FW:
  FW Image to 0x00004000, size=0x00002043 (0x00006043)
  FW Image fr 0x03046800 (non-lzma)
         rtk_eMMC_read blk_addr=0x00018234, data_size=0x00002043, buffer=0x00004000
  FW Image entry  checksum=0x000c8529
  FW Image result checksum=0x000c8529
Video[image] data 1:
  FW Image to 0x85700000, size=0x0004f955 (0x8574f955)
  FW Image fr 0x03048a00 (non-lzma)
  Kernel entry to 0x00108000, size=0x00ac4104 (0x00bcc104)
  Kernel entry fr 0x02008000 (non-lzma)
         rtk_eMMC_read blk_addr=0x00010040, data_size=0x00ac4104, buffer=0x00108000
  emmc block_no=0x00010040
  flash_to_ram_addr=0x00108000
  imageSize=0x00ac4104
  Kernel checksum FAILED
  Kernel entry  checksum=0x3b547888
  Kernel result checksum=0x3b54b2d2
dump ddr data(base=0x00108000)
000 : 00 90 0f e1 09 e0 a0 e1 1f e0 0e e2 1a 00 5e e3
010 : c0 90 89 e3 1f 90 c9 e3 13 90 89 e3 04 00 00 1a
020 : 01 9c 89 e3 0c e0 8f e2 09 f0 6f e1 0e f3 2e e1
030 : 6e 00 60 e1 09 f0 21 e1 10 4f 11 ee 01 10 c4 e3
040 : 10 4f 01 ee 10 4f 11 ee 01 4a c4 e3 04 40 c4 e3
050 : 10 4f 01 ee 00 40 a0 e3 15 4f 07 ee 10 5f 30 ee
060 : 94 80 9f e5 a5 56 08 e0 00 60 a0 e3 00 80 a0 e3
070 : 06 7f a0 e1 88 72 87 e1 56 7f 07 ee 01 80 88 e2
080 : 05 00 58 e1 f9 ff ff da 01 60 86 e2 04 00 56 e3
090 : f5 ff ff ba 00 40 a0 e3 9a 4f 07 ee 00 40 a0 e3
0a0 : 17 4f 08 ee 00 40 a0 e3 16 4f 08 ee 00 40 a0 e3
0b0 : 15 4f 08 ee 00 40 a0 e3 95 4f 07 ee 10 9f 10 ee
0c0 : 66 68 11 eb 05 a0 b0 e1 75 68 11 0a 30 30 8f e2
0d0 : 10 01 93 e8 04 40 43 e0 04 80 88 e0 3e 00 00 eb
0e0 : c6 a3 17 eb 08 00 00 eb 10 d0 9f e5 04 e0 8f e2
0f0 : 04 80 a0 e1 10 f0 8a e2 52 68 11 ea ff 01 00 00
100 : 5c 10 6f 80 04 81 10 80 00 00 00 80 41 49 88 e2
110 : 04 00 a0 e1 00 30 a0 e3 01 69 80 e2 04 30 80 e4
120 : 04 30 80 e4 04 30 80 e4 04 30 80 e4 06 00 30 e1
130 : f9 ff ff 1a 08 70 9a e5 90 00 8f e2 68 00 90 e8
140 : 03 00 40 e0 00 50 85 e0 00 60 86 e0 25 5a a0 e1
150 : 26 6a a0 e1 05 3a 87 e1 05 31 84 e7 06 00 55 e1
160 : 01 50 85 32 fa ff ff 3a 02 0a 84 e2 58 60 9f e5
170 : 07 30 88 e1 26 69 84 e0 04 30 80 e4 01 36 83 e2
180 : 06 00 50 e1 fb ff ff 9a 06 33 a0 e3 23 3a a0 e1
190 : 03 3a 87 e1 07 3a c3 e3 0c 30 c3 e3 02 3a 83 e3
1a0 : fe 0d 84 e2 00 30 80 e5 22 0a a0 e1 00 0a b0 e1
1b0 : 08 30 40 10 02 31 83 12 23 39 84 10 00 60 87 11
1c0 : 00 60 83 15 0c 70 9a e5 0e f0 a0 e1 cf 17 c1 80
1d0 : d0 81 10 80 c0 8f 56 80 e0 8f 56 80 03 00 12 e3
1e0 : 0b 00 00 1a 00 50 92 e5 2c 60 9f e5 06 00 55 e1
1f0 : 06 00 00 0a 05 00 55 e3 02 00 55 13 04 00 00 1a
Enter console mode, disable watchdog ...
Realtek>
发表于: 2019-11-8 17:38:26
路过学学,期待高手解答!
发表于: 2022-3-14 10:14:17
楼主修好了吗,遇到一样的问题
GMT+8, 2024-11-26 19:58 , Processed in 0.057416 sec., 9 queries .
