谁有DM1001的编程器固件?我接ISP打印出的信息,看不懂,哪位师傅帮忙看看是什么?
001: TXD: VGA--12; RXD: VGA--15.
002: C:\Users\Administrator\Desktop\Print.log
003: COM9, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12,
0
exit abortboot: 0
compatible nand
Booting from nand ...
NAND read: logo whole chip
8388608 bytes read: OK
unpackimg:Magic error, use old format
unpackimg wrong!
cp - memory copy
Usage:
cp [.b, .w, .l] source target count
NAND read: boot offset 0x0, size 0x600000
NAND bbt detect factory Bad block at 2400000
Skipping bad block 0x00400000
2097152 bytes read: OK
hdcp get form storage medium: nand
don't found keyname,uboot_key_read:1634
prefetch hdcp keys from nand failed
AML-LOG : Invalid AML-CHK-BLK ID or Ver!
Error! Illegal kernel image, please check!
enter recovery
unpackimg wrong!
cp - memory copy
Usage:
sdio_detect return 0
[mmc_init] SDIO Port B:0, SD or TSD: Card did not respond to voltage select! mmc->block_dev.if_type=7
(Re)start USB...
USB: dwc_usb driver version: 2.94 6-June-2012
USB (0) peri reg base: c1108400
USB (0) use clock source: XTAL input
USB (0) PHY Clock not detected!
USB (0) base addr: 0xc9040000
Force id mode: Host
dwc_otg: No USB device found !
** Invalid boot device **
NAND read: recovery offset 0x0, size 0x600000
6291456 bytes read: OK
m6_mbx_th8_secure#
