查看: 1523|回复: 2
TP.MS628M.PB818组装机打印信息。开机出开机画面就关机
发表于: 2019-10-16 10:34:45
TP.MS628M.PB818组装机打印信息。开机出开机画面就关机。这是打印信息。大师们看看。哪里问题。
UART_115200
STR_DC_ON
_U
Relocation Offset is: 00dda000
[AT][MB][start ub][344]
U-Boot 2011.06-00000-g5441566-dirty (Mar 06 2016 - 11:26:33)
cvte_buildinfo: 54415669_20160306_112622
[NOS] UtopiaInit
1st UTOPIARegisterToUtopia is done[MBoot] Driver Register to Utopia
uboot held at [2e1ddf60~2f500000],size=013220a0
CPU  : Madison
Board: BD_MST064B_10AVXM_14065_MADISON
DRAM:  245 MiB
Now running in RAM - U-Boot at: 2e600000
eMMC: DDR 48MHz
eMMC 3.63 GB [747FF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0x0: 0x25: 0x92: 0xc3:0x80: 0x6f
msIR_Initialize
[AT][MBoot][Driver Init][659]
Changelist:        24543697
DC XXon
<CVTE> do_cvte_get_mac_from_emmc
block_data[0]:00
block_data[1]:25
block_data[2]:92
block_data[3]:c3
block_data[4]:80
block_data[5]:6f
<628> Read MAC Value-->00:25:92:c3:80:6f
<628> EMMC MAC-->00:25:92:c3:80:6f , ENV MAC-->00:25:92:c3:80:6f
<2984> do_cvte_init_at_env_by_value AT_Read=0 OR AT_B=0 OR AT_T=0 AT_BOOTCH=0:
Same as console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0xA800000 EMAC_MEM=0x40000 DRAM_LEN=0x40000000 LX_MEM2=0xA0000000,0xCF00000 cma_miu1=0xA0000000,0x4000000 KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=OFF
<628> AT Start UART Control-init_pram.AT_P=0
UART BUS OFF 1!!!
UART_115200
AC_ON
AutoDQS0-[56789ABCDEF][56789ABCDEF][56789ABCDEF][56789ABCDEF]-[0xAAAA]
AutoDQS1-[56789ABCDEF][56789ABCDEF][456789ABCDEF][456789ABCDE]-[0x99AA]
BIST0-OK
BIST1-OK
_U
[AT][MB][start ub][785]
[NOS] UtopiaInit
CPU  : Madison
DRAM:  245 MiB
eMMC: DDR 48MHz
In:    serial
Out:   serial
Err:   serial
msIR_Initialize
[AT][MBoot][Driver Init][1099]
AC on
====cvte power on check usb and upgrade ====
<628> do_cvte_init_at_prama4env
Check USB port[0]:
Host type:2
scanning bus for devices...
[USB] interface[0] conf:1 value ff:
1 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
Check USB port[1]:
No USB is connecting
usb init failed
Check USB port[2]:
usb init failed
FAIL : can not init usb!!
<628> custar = -1
<628> USB Disk Not Found
block_data[0]:00
block_data[1]:25
block_data[2]:92
block_data[3]:c3
block_data[4]:80
block_data[5]:6f
UART BUS OFF 1!!!
发表于: 2021-2-11 11:11:33
UART BUS OFF 1!!!    总线关闭
GMT+8, 2024-11-17 19:35 , Processed in 0.049867 sec., 9 queries .
