2019-10-9, 9:36:26
COM4, BaudRate:115200 bps, RXD: VGA-> 4,TXD: VGA->11, Printed by RT809F:
[ 0.480000] Creating 11 MTD partitions on "NAND 128MiB 3,3V 8-bit":
[ 0.484000] 0x000000000000-0x0000000e0000 : "uboot"
[ 0.492000] 0x0000000e0000-0x000000120000 : "ubootdat"
[ 0.496000] 0x000000120000-0x000000180000 : "stbc"
[ 0.504000] 0x000000180000-0x0000001e0000 : "stbcdat"
[ 0.508000] 0x0000001e0000-0x000000460000 : "kr0"
[ 0.516000] 0x000000460000-0x000000a60000 : "fs0"
[ 0.520000] 0x000000a60000-0x000004220000 : "ap0"
[ 0.528000] 0x000004220000-0x0000079e0000 : "ap1"
[ 0.532000] 0x0000079e0000-0x000007ec0000 : "apdat"
[ 0.540000] 0x000007ec0000-0x000007f80000 : "logo"
[ 0.544000] 0x000007f80000-0x000008000000 : "music"
[ 0.552000] UBI: attaching mtd5 to ubi0
[ 0.556000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 0.560000] UBI: logical eraseblock size: 126976 bytes
[ 0.568000] UBI: smallest flash I/O unit: 2048
[ 0.572000] UBI: VID header offset: 2048 (aligned 2048)
[ 0.576000] UBI: data offset: 4096
[ 0.600000] UBI: attached mtd5 to ubi0
[ 0.604000] UBI: MTD device name: "fs0"
[ 0.612000] UBI: MTD device size: 6 MiB
[ 0.616000] UBI: number of good PEBs: 48
[ 0.620000] UBI: number of bad PEBs: 0
[ 0.624000] UBI: max. allowed volumes: 128
[ 0.628000] UBI: wear-leveling threshold: 4096
[ 0.632000] UBI: number of internal volumes: 1
[ 0.640000] UBI: number of user volumes: 1
[ 0.644000] UBI: available PEBs: 0
[ 0.648000] UBI: total number of reserved PEBs: 48
[ 0.652000] UBI: number of PEBs reserved for bad PEB handling: 2
[ 0.656000] UBI: max/mean erase counter: 1/0
[ 0.664000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.680000] UBI: background thread "ubi_bgt0d" started, PID 321
[ 0.684000] NT72558-port0-ehci NT72558-port0-ehci.0: new USB bus registered, assigned bus number 1
[ 0.708000] NT72558-port0-ehci NT72558-port0-ehci.0: USB 0.0 started, EHCI 1.00, overcurrent ignored
[ 0.716000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.724000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.728000] usb usb1: Product: NT72558 port0 EHCI
[ 0.732000] usb usb1: Manufacturer: Linux 2.6.30.9-svn3304 ehci_hcd
[ 0.740000] usb usb1: SerialNumber: NT72558-port0-ehci.0
[ 0.748000] usb usb1: configuration #1 chosen from 1 choice
[ 0.752000] hub 1-0:1.0: USB hub found
[ 0.756000] hub 1-0:1.0: 1 port detected
[ 0.768000] NT72558-port1-ehci NT72558-port1-ehci.0: new USB bus registered, assigned bus number 2
[ 0.788000] NT72558-port1-ehci NT72558-port1-ehci.0: USB 0.0 started, EHCI 1.00, overcurrent ignored
[ 0.796000] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.804000] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.808000] usb usb2: Product: NT72558 port1 EHCI
[ 0.812000] usb usb2: Manufacturer: Linux 2.6.30.9-svn3304 ehci_hcd
[ 0.820000] usb usb2: SerialNumber: NT72558-port1-ehci.0
[ 0.828000] usb usb2: configuration #1 chosen from 1 choice
[ 0.832000] hub 2-0:1.0: USB hub found
[ 0.836000] hub 2-0:1.0: 1 port detected
[ 0.840000] Initializing USB Mass Storage driver...
[ 0.844000] usbcore: registered new interface driver usb-storage
[ 0.852000] USB Mass Storage support registered.
[ 0.856000] mice: PS/2 mouse device common for all mice
[ 0.864000] device-mapper: ioctl: 4.14.0-ioctl (2008-04-23) initialised: dm-devel@redhat.com
[ 0.872000] usbcore: registered new interface driver usbhid
[ 0.880000] usbhid: v2.6:USB HID core driver
[ 0.884000] oprofile: using mips/24K performance monitoring.
[ 0.888000] oprofile: using timer interrupt.
[ 0.892000] Netfilter messages via NETLINK v0.30.
[ 0.896000] nf_conntrack version 0.5.0 (1856 buckets, 7424 max)
[ 0.904000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 0.908000] TCP cubic registered
[ 0.912000] NET: Registered protocol family 17
[ 0.916000] RPC: Registered udp transport module.
[ 0.920000] RPC: Registered tcp transport module.
[ 0.928000] lib80211: common routines for IEEE802.11 drivers
[ 0.932000] ============================================================
[ 0.940000] Memory protect range1: 0x00100000 ~ 0x0053dfff
[ 0.944000] Memory protect range2: 0x00100000 ~ 0x073fffff
[ 0.952000] Novatek MAU protection start.........
[ 0.956000] ============================================================
[ 0.964000] VFS: Mounted root (squashfs filesystem) readonly on device 31:11.
[ 0.972000] Freeing unused kernel memory: 140k freed
[ 0.980000] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[ 0.984000] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[ 0.992000] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[ 0.996000] [KDEBUGD] enter : SP_DEBUG
[ 0.996000]
/etc/rc.local start!!!!
NVT ROOTFS VERSION : svn2130
KERNEL MODULE VERSION : kernel module version file not found
[ 1.700000] UBI: attaching mtd8 to ubi1
[ 1.704000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 1.712000] UBI: logical eraseblock size: 126976 bytes
[ 1.716000] UBI: smallest flash I/O unit: 2048
[ 1.720000] UBI: VID header offset: 2048 (aligned 2048)
[ 1.728000] UBI: data offset: 4096
[ 1.740000] UBI error: ubi_io_read: error -77 while reading 2048 bytes from PEB 30:2048, read 0 bytes
ubiattach: error!: cannot attach mtd8
error 5 (Input/output error)
[ 1.756000] UBIFS error (pid 429): ubifs_get_sb: cannot open "ubi1:", error -22
cat: can't open '/sys/class/ubi/ubi1/volumes_count': No such file or directory
sh: 0: unknown operand
cat: can't open '/sys/class/ubi/ubi1_0/name': No such file or directory
mount: mounting ubi1: on /mtd_apdat failed: Invalid argument
/usr/script/mtdmount.sh:can not mount ubi1:.
No idtv found
Start Update MTD_APEXE from USB Disk ...
1: USB Dis NOT Mounted.
2: USB Disk NOT Mounted.
3: USB Disk NOT Mounted.
4: USB Disk NOT Mounted.
5: USB Disk NOT Mounted.
6: USB Disk NOT Mounted.
7: USB Disk NOT Mounted.
8: USB Disk NOT Mounted.
File NOT exist~ #
三洋 55CE1100
故障现像是:开机卡LOGO,偶尔可以进 主板测试各点电压均正常,大师们看下,这个是什么问题?程序也刷不进
