Hello,I've recently buyed 5 brand new samsung NANDs mod. K9GAG08U0E-SCB0 to fix some samsung D5500 boards. My RT809H detects that there are some bad blocks (and that's normal). Programmed all of them with "Skip BB and Data Realign" algorithm and only 2 of them worked well. The other 3 reboot while searching new channels. I'll attach my logs.
Of course my dump is 100% working and written on these 5. How can I solve it?
1st OK
001: Chip pins contact is detected OK.
002: TotalPageNum: 0x100,PageNumInBlock: 64,PageSize: 0
003: Auto identified 3 ID is match with the partnumber.
004: Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
005: The currently selected:K9GAG08U0E@TSOP48, capacity: 17491.92Mbits, 2186Mbytes.
006: Adapter model£ºRT-TSOP48-1, 0.5, 12*18, Pin to Pin
007: http://www.ifix.net.cn/thread-53859-1-2.html
008: Download device programming algorithm......
009: Algo update OK
010: >------------------------------------OK---------------------------------------<
011: Chip pins contact is detected OK.
012: TotalPageNum: 0x40E00,PageNumInBlock: 128,PageSize: 8628
013: Chip ID verification OK.
014: TotalBlockNum: 2076
015: detected 6 Bad block.
016: Bad block is located£º343, 344, 904, 932, 1728, 2073,
017: >------------------------------------OK---------------------------------------<
018: Chip pins contact is detected OK.
019: TotalPageNum: 0x40E00,PageNumInBlock: 128,PageSize: 8628
020: Chip ID verification OK.
021: Start writing chip......
022: Auto erasing...
023: Erase successful£¬Elapsed time£º0.211 seconds¡£
024: Start writing...
025: Algorithm equal to : Skip Bad Block and Data Realign
026: Bad block is located£ºBlock 904 , Skipped.
027: Bad block is located£ºBlock 932 , Skipped.
028: Bad block is located£ºBlock 1728 , Skipped.
029: Write and verify success.
030: Elapsed time: 809.1 seconds£¬average speed of 5667168 bytes/sec.
031: >------------------------------------OK---------------------------------------<
2nd FAIL (reboot 55%)
009: Algo update OK
016: Bad block is located£º59, 227, 1208, 1222, 1267, 2073,
023: Erase successful£¬Elapsed time£º0.218 seconds¡£
026: Bad block is located£ºBlock 227 , Skipped.
027: Bad block is located£ºBlock 1208 , Skipped.
028: Bad block is located£ºBlock 1222 , Skipped.
029: Bad block is located£ºBlock 1267 , Skipped.
030: Write and verify success.
031: Elapsed time: 814.1 seconds£¬average speed of 5632743 bytes/sec.
032: >------------------------------------OK---------------------------------------<
3rd FAIL (reboot 51%)
009: Algo update OK
015: detected 9 Bad block.
016: Bad block is located£º26, 110, 501, 849, 907, 908, 1121, 1653, 2073,
023: Erase successful£¬Elapsed time£º0.227 seconds¡£
026: Bad block is located£ºBlock 501 , Skipped.
027: Bad block is located£ºBlock 849 , Skipped.
028: Bad block is located£ºBlock 907 , Skipped.
029: Bad block is located£ºBlock 908 , Skipped.
030: Bad block is located£ºBlock 1121 , Skipped.
031: Write and verify success.
032: Elapsed time: 822.8 seconds£¬average speed of 5572897 bytes/sec.
033: >------------------------------------OK---------------------------------------<
4th OK
009: Algo update OK
015: detected 2 Bad block.
016: Bad block is located£º821, 2073,
023: Erase successful£¬Elapsed time£º0.195 seconds¡£
026: Bad block is located£ºBlock 821 , Skipped.
027: Write and verify success.
028: Elapsed time: 797.6 seconds£¬average speed of 5748899 bytes/sec.
029: >------------------------------------OK---------------------------------------<
5th FAIL (reboot 60%)
009: Algo update OK
015: detected 10 Bad block.
016: Bad block is located£º161, 179, 442, 939, 1165, 1236, 1294, 1369, 1420, 2073,
023: Erase successful£¬Elapsed time£º0.241 seconds¡£
026: Bad block is located£ºBlock 939 , Skipped.
027: Bad block is located£ºBlock 1165 , Skipped.
028: Bad block is located£ºBlock 1236 , Skipped.
029: Bad block is located£ºBlock 1294 , Skipped.
031: Elapsed time: 812 seconds£¬average speed of 5647241 bytes/sec.
