查看: 1389|回复: 1
UART BUS OFF 1 !!!
发表于: 2019-8-27 22:37:56
Hello.
Partners planning with the RT809H to fix this problem now via VGA port ....
They have a solution to this warning.
Thanks
Hit any key to stop autoboot: 0
DC on !!
<638> AT Start UART Control-init_pram.AT_P = 0
  UART BUS OFF 1 !!!
On the 638 chips ...
发表于: 2019-8-29 09:13:41
This means the serial port is closed, you need to open your serial port.
GMT+8, 2024-12-20 16:16 , Processed in 0.052675 sec., 10 queries .
