查看: 997|回复: 1
RT809H + BGA156 v2.2 dont read Sandisk SDIN2C2-2G
发表于: 2019-8-18 19:24:39
Hi, I bought the programmer rt809H and the emmc adapter (bga169-bga153) v2.2.
But I am trying to read a sandisk memory and cannot read anything.
Sandisk SDIN2C2-2G
The placement is correct, the solder pins clean.
I have also tried an adapter from another box, which has the emmc soldered correctly and I have connected it to the RT809H through the isp port (gnd, vcc, vccq, d0, clk and cmd) and cannot read anything either. The box reads the memory correctly.
Is it possible to add this memory?
079: Chip pins contact is detected OK.
080: Identified the genuine adapter £ ºRT-BGA169-01, V2.2, SN: 20190317xxxxxx-Sxxxxx
081: Read timeout.
嗨,我買了程序員rt809H和emmc適配器(bga169-bga153)v2.2。
但我試圖讀取一個sandisk內存,無法讀取任何內容。
Sandisk SDIN2C2-2G
放置正確,焊針清潔。
我還嘗試了另一個盒子的適配器,它正確焊接了emmc,我通過isp端口(gnd,vcc,vccq,d0,clk和cmd)將它連接到RT809H,也無法讀取任何內容。 該框正確讀取內存。
是否可以添加此內存?
079:檢測到芯片引腳接觸正常。
080:識別正品適配器:RT-BGA169-01,V2.2,SN:20190317xxxxxx-Sxxxxx
081:讀取超時。
Hāi, wǒ mǎile chéngxù yuán rt
发表于: 2019-8-19 09:50:32
You can read this article first, maybe you will  find the solution. http://www.ifix.net.cn/forum.php ... &highlight=EMMC
GMT+8, 2024-11-18 00:45 , Processed in 0.056362 sec., 11 queries .
