查看: 1283|回复: 7
pls support K9F2G08U0C@TSOP48 chip
发表于: 2019-8-3 15:52:51
Edited by datcanlong at 2019-8-3 15:54
My device is DVD in hyundai grand i10. It's login to WinCE when turn on.
Now i try copy NAND Flash to Bin File by RT809H. Then check bad block, Erase again. rewrite the copied file
but now Solder the chip into the board, it doesn't turn on like the original
Chip error or I do failed something
thanks all so much
sorry my english not good ^^!
发表于: 2019-8-3 16:10:41
It showed that there is block in your chip, so that's the chip problem.
 楼主| 发表于: 2019-8-3 16:18:44
shirleyhuang 2019-8-3 16:10
Thanks for your support
I try all setting, wirte ok, verify ok. But put it back to main board cannot power up.
firt, it work normal.
What should I do to make it work again like the first time?
发表于: 2019-8-3 17:02:48
datcanlong 2019-8-3 16:18
I try all setting, wirte ok, verify ok. But put it back to main board can ...
Chip problem, you can change another chip to try.
 楼主| 发表于: 2019-8-3 17:16:25
shirleyhuang 2019-8-3 17:02
I have one chip onboard working ok now
Try with it or no. maybe work, or die two device )
so hard
I will answer later ^^!
 楼主| 发表于: 2019-8-3 18:29:37
OLD CHIP
056:  Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
057:  The currently selected:K9F2G08U0C@TSOP48, capacity: 2112Mbits, 264Mbytes.
058:  Adapter model£ºRT-TSOP48-1, 0.5, 12*18, Pin to Pin
059:  http://www.ifix.net.cn/thread-53859-1-2.html
060:  Download device programming algorithm......
061:  Algo update OK
062:  >------------------------------------OK---------------------------------------<
063:  Chip pins contact is detected OK.
064:  TotalPageNum: 0x20000,PageNumInBlock: 64,PageSize: 2112
065:  Chip ID verification OK. (Check bad block old chip)
066:  TotalBlockNum: 2048
067:  detected 4 Bad block.
068:  Bad block is located£º302, 1173, 1427, 1990,
069:  >------------------------------------OK---------------------------------------<
ANOTHER CHIP
124:  >------------------------------------OK---------------------------------------<
125:  Chip pins contact is detected OK.
126:  TotalPageNum: 0x20000,PageNumInBlock: 64,PageSize: 2112
127:  Chip ID verification OK. (check bad block new chip)
128:  TotalBlockNum: 2048
129:  detected 4 Bad block.
130:  Bad block is located£º83, 228, 570, 977,
131:  >------------------------------------OK---------------------------------------<
132:  Chip pins contact is detected OK.
133:  TotalPageNum: 0x20000,PageNumInBlock: 64,PageSize: 2112
134:  Chip ID verification OK.
135:  Start writing chip...... (Chose file read from old chip)
136:  Auto erasing...
137:  Erase successful£¬Elapsed time£º1.464 seconds¡£
138:  Start writing...
139:  Algorithm equal to : Hard Copy (Ignore bad block)
140:  Elapsed time: 74.57 seconds£¬average speed of 7424841 bytes/sec.
141:  >------------------------------------OK---------------------------------------<
142:  Chip pins contact is detected OK.
143:  TotalPageNum: 0x20000,PageNumInBlock: 64,PageSize: 2112
144:  Chip ID verification OK. (verify again)
145:  Start verifying chip......
146:  All bytes verification is consistent.
147:  >------------------------------------OK---------------------------------------<
I don't know why have bad block in another chip but it work ! (Before I check bad and rewrite)
Now two device is dead
发表于: 2019-8-6 09:29:34
datcanlong 2019-8-3 18:29
OLD CHIP
056:  Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog b ...
Because at first your operation is wrong, do not program the master slice at beginning.
发表于: 2024-4-19 14:40:31
shirleyhuang 2019-8-6 09:29
这样的存储芯片怎么备份
GMT+8, 2024-12-23 18:20 , Processed in 0.062300 sec., 10 queries .
