查看: 2310|回复: 8
海尔48A5 DH1TT0D0700开机灰屏
发表于: 2019-7-30 10:00:23
​故障现象:开机打印信息显示待机,开启后电视可以开机,灰屏没反应,用修机王显示一样。
打印信息如下:
Hello PM51...
Enter STR
MDrv_PM_PowerDown2Standby
一看信息好了待机,开机抓打印看一下,开机后,没有任何打印信息,难道串口关闭,isp自动识别可以识别到并且可以读出引导程序,暗喜带25c16,遂将引导程序用HXD十六进制编程器打开一看果然串口关闭。
马上用16进制将串口打开,打印信息出来了但是不能开机了,也不能灰屏了。
打印如下:
eMMC_CheckR1Error() ] eMMC Err: eMMC_ST_ERR_R1_23_16
  0x4F2392B4: 11h 00h 10h 09h 00h 09h 00h 00h 00h 00h 00h 00h 00h 00h 00h 00h  | ................
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 1
eMMC retry by DATA_SYNC: 0h, ori:55h
[ eMMC_CheckR1Error() ] eMMC Err: eMMC_ST_ERR_R1_23_16
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 2
eMMC Warn: slow SDR clk to 5h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 3
eMMC retry by DATA_SYNC: 40h, ori:15h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 4
eMMC Warn: slow SDR clk to 4h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 5
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 6
eMMC Warn: slow SDR clk to 2h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 7
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 8
eMMC Warn: slow SDR clk to 1h
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 9
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 10
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 11
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 12
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 13
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 14
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 15
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 16
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 17
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 18
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 19
[ eMMC_CMD17_MIU() ] eMMC WARN: CMD17 check R1 error: 80000A05h, Retry: 20
[ eMMC_CMD17_MIU() ] eMMC Err: CMD17 check R1 error: 80000A0Bh, Retry: 20
[ eMMC_DumpDriverStatus() ] eMMC Status:
[ eMMC_DumpDriverStatus() ]   MIU Mode
[ eMMC_DumpDriverStatus() ]   Polling Mode
[ eMMC_DumpDriverStatus() ]   FCIE Byte Mode
[ eMMC_DumpDriverStatus() ]   SDR Mode
[ eMMC_DumpDriverStatus() ]   FCIE Clk: 20000KHz
[ eMMC_DumpDriverStatus() ]   8-bits width
[ eMMC_DumpDriverStatus() ]   HIGH bus speed
[ eMMC_DumpPadClk() ]
[clk setting]: 20000KHz
[ eMMC_DumpPadClk() ] FCIE 1X (0x1F201790):0x44
[ eMMC_DumpPadClk() ] FCIE 4X (0x1F2016C4):0x5
[ eMMC_DumpPadClk() ] CMU (0x1F201640):0x1
[pad setting]: SDR
[ eMMC_DumpPadClk() ] chiptop_0x5A (0x1F203D68):0x0
[ eMMC_DumpPadClk() ] chiptop_0x1F (0x1F203C7C):0x0
[ eMMC_DumpPadClk() ] chiptop_0x70 (0x1F203DC0):0x0
[ eMMC_DumpPadClk() ] chiptop_0x64 (0x1F203D90):0x0
[ eMMC_DumpPadClk() ] chiptop_0x4F (0x1F203D3C):0x8000
[ eMMC_DumpPadClk() ] chiptop_0x03 (0x1F203C0C):0xF
[ eMMC_DumpPadClk() ] chiptop_0x51 (0x1F203D44):0x2404
[ eMMC_DumpPadClk() ] chiptop_0x6F (0x1F203DBC):0x0
[ eMMC_DumpPadClk() ] chiptop_0x43 (0x1F203D0C):0x19
[ eMMC_DumpPadClk() ] chiptop_0x50 (0x1F203D40):0x0
[ eMMC_DumpPadClk() ] chiptop_0x0B (0x1F203C2C):0x0
[ eMMC_DumpPadClk() ] chiptop_0x5D (0x1F203D74):0xC307
[ eMMC_DumpPadClk() ] reg_pcm_drv (0x1F203C20):0x0
[ eMMC_DumpPadClk() ] reg_pcm_d_pe (0x1F203C30):0xFFFF
[ eMMC_DumpPadClk() ] reg_nand_drv (0x1F203C30):0xFFFF
[ eMMC_DumpPadClk() ] reg_emmc_drv (0x1F203D64):0x3000
[ eMMC_FCIE_DumpRegisters() ]
FCIE Reg:
00h:| 4807h 0000h 8020h 0000h 0000h 0000h 0000h 03FFh
08h:| 000Fh 0000h 0082h 0001h 0000h 0005h 0005h 0000h
10h:| 0055h 0002h FF20h 0000h 0000h 000Fh 0010h 0020h
18h:| 0000h 0000h 0000h 8200h 52A0h 4F23h 0000h 0002h
20h:| 0000h 0000h 0000h 0000h 0000h 0000h 000Bh 0000h
28h:| 0000h 0012h 0001h 0000h 0000h 401Fh 00FFh 0100h
30h:| 5803h 0000h 0040h 0001h FFFFh 0000h A0A0h 0000h
38h:| 0000h 0000h 00FFh FFFFh 0000h 0000h 2328h 0050h
40h:| 0004h 0000h 0000h 0000h 3000h 3F00h 0000h 0000h
48h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
50h:| 0000h 0000h 0000h 0000h 004Bh E005h 0085h 0000h
58h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
FCIE CIFC:
00h:| 0011h 0910h 0900h 0000h 0000h 0000h 0000h 0000h
08h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
10h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
18h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
[ eMMC_FCIE_DumpDebugBus() ]
FCIE_TEST_MODE: 5803h
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5903h
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5A03h
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5B03h
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5C03h
FCIE_DEBUG_BUS: 510h
FCIE_TEST_MODE: 5D03h
FCIE_DEBUG_BUS: 0h
FCIE_TEST_MODE: 5E03h
FCIE_DEBUG_BUS: 600h
FCIE_TEST_MODE: 5F03h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 0h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 1000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 2000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 3000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 4000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 5000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 6000h
FCIE_DEBUG_BUS: 0h
NC_WIDTH: 7000h
FCIE_DEBUG_BUS: 0h
其实心中已经知道emmc已经危险了,但心中还是没托底,马上找罗老师问一下,建议我更换emmc,心中疑惑为啥改个串口,怎么还不能像原来不能灰屏了,询问老师,老师道赶紧换,教条啥,哎没办法,赶紧换吧。
马上更换emmc,进控制台uup升级,问题解决。
此问题在大师眼里就是小活,但对于新手来说,还是有很多知识点,借此抛砖引玉,希望可以帮助同行兄弟。
主板图片如下:
“百人精英计划”名额有限,
正在火热进行中
请感兴趣的同学尽快,先到先得!
报名联系方式
国内
电话:020-28667686(潘老师)
微信:RDDZ2017
网络课程 碎片时间
随时随地 轻松学习
发表于: 2019-7-30 11:26:28
谢谢楼主的有图有真相经验分享。
发表于: 2019-7-31 14:59:33
感谢
       分享!
发表于: 2019-8-6 09:35:12
谢谢楼主的有图有真相经验分享。
GMT+8, 2024-12-25 21:06 , Processed in 0.063692 sec., 10 queries .
