查看: 1490|回复: 6
TP.HS10.PD62 QT515P.V2.1主板开机到系统加载时重启?
发表于: 2019-7-17 09:05:56
系统也重新做过还是一样,测U9输出1.37V-1.36V之间,偶尔进系统正常后此电压为1.16V,不知这过程电压是否正常?望高手指点.
发表于: 2019-7-19 09:04:11
主芯片型号  U9型号
有的供电芯片是由CPU总线控制的,根据功耗动态自动调整。
 楼主| 发表于: 2019-7-20 10:06:52
谢谢!那开机自动重启几次才能进系统这原因我还没解决,你能否帮我分析下。
发表于: 2019-7-20 10:50:33
一切皆有可能,没有数值没有测试,不好分析。
 楼主| 发表于: 2019-7-21 20:10:14
001:  TXD: VGA--12; RXD: VGA--15.
002:  C:\Users\Administrator\Desktop\Print.log
003:  COM12, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12,
Load hi_tde.ko success.                (SDK_VERSION:[HiDPTAndroidV200R001C00SPC115_20160509] Build Time:[Dec 29 2016, 19:25:43])
Load hi_fb.ko success.                (SDK_VERSION:[HiDPTAndroidV200R001C00SPC115_20160509] Build Time:[Dec 29 2016, 19:25:28])
Load hi_jpegdec.ko success.        (SDK_VERSION:[HiDPTAndroidV200R001C00SPC115_20160509] Build Time:[Dec 29 2016, 19:25:30])
[HDMI]HDMI HPD polarity:6
[HDMI]set port0 HPD Value 0
[HDMI]set Gpio 1 to 1
[HDMI]set port1 HPD Value 0
[HDMI]set port2 HPD Value 0
[HDMI]set port3 HPD Value 0
cec main stask[HDMI] Now is hi3751av500
hisi-sndcard hisi-sndcard:  aiao-hifi <-> hisi-i2s mapping ok
Load hi_sif.ko success.                (SDK_VERSION:[HiDPTAndroidV200R001C00SPC115_20160509] Build Time:[Dec 29 2016, 19:25:43])
Load hi_png.ko success.                (SDK_VERSION:[HiDPTAndroidV200R001C00SPC115_20160509] Build Time:[Dec 29 2016, 19:25:36])
ALSA device list:
  #0: HISI-AIAO
Warning: unable to open an initial console.
Freeing unused kernel memory: 1028K (c0d7f000 - c0e80000)
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
init: /dev/hw_random not found
init: cannot open '/initlogo.rle'
EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: journal_checksum,errors=remount-ro,barrier=1,commit=1
EXT4-fs (mmcblk0p16): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk0p16): recovery complete
EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/hi_mci.1/by-name/userdata
e2fsck: e2fsck 1.41.14 (22-Dec-2010)
e2fsck: /dev/block/platform/hi_mci.1/by-name/userdata: clean, 1613/104000 files, 123274/415744 blocks
EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: nodiscard,data=ordered,errors=panic,journal_checksum,barrier=1
EXT4-fs (mmcblk0p11): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk0p11): recovery complete
EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/hi_mci.1/by-name/atv
e2fsck: /dev/block/platform/hi_mci.1/by-name/atv: clean, 62/2560 files, 4542/10240 blocks
EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: block_validity,nodiscard,data=ordered,errors=remount-ro,journal_checksum,barrier=1
EXT4-fs (mmcblk0p12): Ignoring removed nomblk_io_submit option
EXT4-fs (mmcblk0p12): recovery complete
EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,errors=remount-ro
fs_mgr: Running /system/bin/e2fsck on /dev/block/platform/hi_mci.1/by-name/cache
e2fsck: /dev/block/platform/hi_mci.1/by-name/cache: clean, 15/38400 files, 4940/153600 blocks
EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: nodiscard,data=ordered,errors=remount-ro,journal_checksum,barrier=1
healthd: No charger supplies found
healthd: BatteryStatusPath not found
init: cannot find '/system/bin/skyplayserver', disabling 'skyplayserver'
sdcardfs version 2.0
sdcardfs: mounted on top of /data/media type ext4
healthd: BatteryHealthPath not found
healthd: BatteryPresentPath not found
healthd: BatteryCapacityPath not found
healthd: BatteryVoltagePath not found
healthd: BatteryTemperaturePath not found
healthd: BatteryTechnologyPath not found
init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
init: powerctl: cannot expand '${sys.powerctl}'
init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
tntfs: module license 'Commercial. For support email ntfs-support@tuxera.com.' taints kernel.
Disabling lock debugging due to kernel taint
input: Hi Keypad as /devices/virtual/input/input3
Tuxera NTFS driver 3015.1.29.1.1 [Flags: R/W MODULE].
root@public_hisi_3751av500:/ # init: untracked pid 1414 exited
usbcore: registered new interface driver bt_usb
<1>csr_usb: CSR USB driver registered
BT_USB: major 250
[5445 ERROR-HI_VO]:WINDOW_GetNowDelayTime[701]:pstWindow->pstChannelInfo is NULL
PQ table pstVdpInfo is null!
Spread Info: <IntfType:VBO, SpreadOn:1, SpreadRatio:0, SpreadFreq:2>
Spread Info: <IntfType:VBO, SpreadOn:1, SpreadRatio:0, SpreadFreq:4>
input: alitv-mouse as /devices/virtual/input/input4
input: alitv-Vcontroller as /devices/virtual/input/input5
input: alitv-motion as /devices/virtual/input/input6
input: alitv-sensor as /devices/virtual/input/input7
[HDMI]UPDATE EDID For Port0!
[HDMI]UPDATE EDID For Port1!
[HDMI]UPDATE EDID For Port2!
[HDMI]UPDATE EDID For Port3!
init: untracked pid 1817 exited
[HDMI]Load HDCP 1.4 for HDMI Success!
[HDMI]==HDMI 1.4 Port0 enState:no signal
[HDMI]==HDMI 1.4 Port1 enState:no signal
[HDMI]Load HDCP 2.2 for HDMI 2.0 Ctrl Success!
[HDMI]==HDMI 2.0 Port2 enState:no signal
Restarting system with command 'ANDROID'.
CPU will restart.?
Bootrom start
Boot Media: eMMC
Starting fastboot ...
System startup
DDRTR Suc
Reg Version:        v1.2.5
Reg Time:        2016/3/3116:00:41
Reg Name:        hi3751v510_2layer_cpu1000_ddr1600_0768m_0768mch0_0000mch1_emmc.xlsm
Fastboot 3.3.0 (yuanerlei@ubuntu) (Mar 11 2017 - 10:19:49)
Fastboot:      Version 3.3.0
Build Date:    Mar 11 2017, 10:20:06
CPU:           Hi3751v500
Boot Media:    eMMC
MMC:   Synopsys Mobile storage: 0
MMC/SD Card:
    MID:         0x000011
    OID:         0x0100
    PSN:         0x2219a6ad
    DATA:        02/2016
    Chip Type:   MMC
    MMC Version: 5.0
    Timing:      HS
    Host Clk:    50000000Hz
    Host Div:    0
    Bus Width:   8bit
    Chip Size:   3959422976 Bytes (High Capacity)
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Boot Addr:   0
The DDR memory layout:
      page table: 0x0c000000 - 0x0c400000  4 MiB
           stack: 0x0c400000 - 0x0c800000  4 MiB
     global data: 0x0cbfffc4 - 0x0cc00000  60 Bytes
          malloc: 0x0cc00000 - 0x10c00000  64 MiB
           .text: 0x10c00000 - 0x10c89a9c  550.7 KiB
            data: 0x10c89a9c - 0x10d1cc80  588.5 KiB
Boot Env on eMMC
    Env Offset:          0x00100000
    Env Size:            0x00010000
    Env Range:           0x00010000
SDK_VERSION: [HiDPTAndroidV200R001C00SPC115_20160509]
press the ir!!!
get key = 0x81f8800000002, status = -476045311, ret = -1
ir failure. status = -476045311, ret= -1
BootMode = POWER OFF
BootMode = 1 ACDC = 1 bFacUsbUpgrade=0
will_enter_recovery = 0
boot_after_reboot = 0
 楼主| 发表于: 2019-7-21 20:16:09
打印信息到这里就重启,我看不懂是哪里的问题ir failure. status = -476045311, ret= -1
BootMode = POWER OFF。望高手指点,谢谢!
 楼主| 发表于: 2019-7-21 21:12:23
arp_tables: (C) 2002 David S. Miller
TCP: cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
lib80211: common routines for IEEE802.11 drivers
VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 3
set default tnr Fmotion mapping Curve,not use tnr.b!
set default dci,not use dci.b!
set default acm.b,not use acm.b!
set default Gamma,not use Gamma.b!
set default pq table,not use pq_table.b!
++++++++++++< Version:0 >++++++++++
!Spread Info: <IntfType:VBO, SpreadOn:1, SpreadRatio:0, SpreadFreq:2>
Load DISP success.                (SDK_VERSION:[HiDPTAndroidV200R001C00SPC115_20160509] Build Time:[Dec 29 2016, 19:25:55])
FC 0 WI 1 DA 1 WF 1 bMC 0 bMA 0 b3DC 0
ALSA device list:
  #0: HISI-AIAO
e2fsck: /dev/block/platform/hi_mci.1/by-name/userdata: clean, 2654/104000 files, 162713/415744 blocks
BT_USB: major 250
[5531 ERROR-HI_VO]:WINDOW_GetNowDelayTime[701]:pstWindow->pstChannelInfo is NULL
lowmemorykiller: lowmem_shrink: convert oom_adj to oom_score_adj:
lowmemorykiller: oom_adj 0 => oom_score_adj 0
lowmemorykiller: oom_adj 1 => oom_score_adj 58
lowmemorykiller: oom_adj 2 => oom_score_adj 117
lowmemorykiller: oom_adj 3 => oom_score_adj 176
lowmemorykiller: oom_adj 9 => oom_score_adj 529
lowmemorykiller: oom_adj 15 => oom_score_adj 1000    打印到这里卡主了,屏幕提示系统正在启动,是哪里的问题?
GMT+8, 2025-1-3 07:15 , Processed in 0.057711 sec., 10 queries .
