查看: 3583|回复: 12
创维43E3500_主板5800-A8S620-OP30,主芯片MSD6A626,开机卡logo。
发表于: 2019-6-24 21:22:57
上门检修一台创维43E3500_主板5800-A8S620-OP30,主芯片MSD6A626,开机卡logo,死机。首先判断可能是程序坏了,于是摘板回店维修
找到主板串口,连接RT809打印信息,摘要:[    3.070870] init: boot time check(need add timer gap): start 'tvservice'
[    3.071468] init: cannot find '/system/bin/livecap', disabling 'livecap'
[    3.071547] init: cannot find '/system/bin/browserserver', disabling 'browserserver'
[    3.073765] init: cannot find '/system/bin/init.toltech.sh', disabling 'toltech_devices'
[    3.08061] init: cannot find '/system/bin/smobsd', disabling 'smobsd'
[    3.098690] X driver registered successfully.
[    3.100128] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
[    3.100164] init: powerctl: cannot expand '${sys.powerctl}'
[    3.100201] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
[    3.100225] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
[    3.149214] healthd: BatteryTechnologyPath not found
[    5.480217] init: untracked pid 1293 exited
[    5.489994] init: untracked pid 1296 exited
[    5.498755] init: untracked pid 1300 exited
[    5.505475] init: untracked pid 1304 exited
[    5.520772] init: untracked pid 1308 exited
[    5.529857] init: untracked pid 1305 exited[    5.534305] init: untracked pid 1310 exited
[    5.578159] input: Skyworth virtual key device as /devices/virtual/input/input2
[    5.597610] input: Skyworth virtual mouse device as /devices/virtual/input/input3
[    5.611441] input: Skyworth virtual touch device as /devices/virtual/input/input4
[    5.621837] input: skyworth_acc as /devices/virtual/input/input5
TVOS *checkPoint*
[    8.928823] init: no such service 'renice-tvos-0'
[   11.051754] warning: `zygote' uses 32-bit capabilities (legacy support in use)
 楼主| 发表于: 2019-6-24 21:42:13
主板供电接入单12v即可正常工作。串口与RT809的RX TX 地 相连。连接Secure CRT,主板并插入U盘强制升级文件,按住键盘回车键不放同时开机,出现MST_命令符时输入串口命令:cu,主板会自动识别升级。。。。。不用管,升级完成会重启。
 楼主| 发表于: 2019-6-24 21:51:34
升级完成后开机会进入安全模式,需进入工厂模式把他关掉即可。进入方法:设置-本机信息,依次按遥控器“上 上 下 下 左 右 左 右”,进入工厂菜单-其他设置-将safemode设置为关,退出按遥控返回键,遥控关机。
发表于: 2019-6-24 23:07:07
Thank you for your post.
发表于: 2019-6-26 14:18:08
打印信息看不懂,解释一下贝?谢谢。
发表于: 2019-7-1 17:47:10
谢谢楼主的有图有真相经验分享
 楼主| 发表于: 2019-7-25 12:47:33
杨柳依依 2019-6-26 14:18
打印信息看不懂,解释一下贝?谢谢。
一个简单的方法,百度:中英翻译互译
发表于: 2019-7-25 18:45:41
mahuanxiaohe 2019-7-25 12:47
一个简单的方法,百度:中英翻译互译
谢谢回复,学习学习。
GMT+8, 2024-12-26 21:21 , Processed in 0.060911 sec., 11 queries .
