查看: 3284|回复: 11
MS901K半边图像花屏故障维修
发表于: 2019-5-22 09:41:40
本案例由欧阳敏提供。
维修一块TCL的主板,MS901K方案,板号为40-M901KV-MAD2HG。故障现象是半边图像花屏,测试图像如下:
这个板图像由倍频电路处理后输出的一个4k的信号,华星光电的屏,既然开机半边图像正常那么主板那边的电路是正常的,接上倍频电路的串口打印查看如下:
2019-5-10, 14:32:9 COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809H: MIU0ALvs 9Lvs 8,89Lvs ALvs 6,6ALvs 9Lvs 8,79Lvs 9Lvs 5,6MIU1BIST FAIL!!!0Lvs BIST FAIL!!!0Lvs 7,8BIST FAIL!!!0Lvs BIST FAIL!!!0Lvs 6,6BIST FAIL!!!0Lvs BIST FAIL!!!0Lvs 7,7BIST FAIL!!!0Lvs BIST FAIL!!!0Lvs 5,6 DATE=Sep 5 2013, Time=10:05:45g_u32AP_FlashStart = 0xA080g_u32AP_FlashEnd = 0x10B410g_u32AP_Size = 0x101390(1053584)g_u32AP_RamStart = 0x100000 CopyFlashToDram( u32DramAddr=0x100000, src=0xA080, Size=1053584(0x101390) )----- Jump to Ap 0x100000 -----[AP] console init ok~__heap=0x213E00, __heap_end=0x300000, _readonly_start=0x104000, _readonly_end=0x1DC000,Jump to main()================================================= Urania ==============Software Version: 2.03.00Software CL: $Change: 693454 $[Board]: BD_MST166A_D01A_S_SZ[Panel]: PNL_CSOT_TA290107AE03_Vx1_4K2K_60Hz_4plus4[MEMORY_MAP]: MMAP_URANIA_256_256[DRAM SIZE]: 512 MB[FLASH SIZE]: 2 MB=====================================
显示的ddr检测不过,既然已经有图像了,那么就查运行内核的ddr。拆下散热片看倍频芯片型号为MST6M40A,在mstar方案的芯片左侧为ddr0,芯片顶部为ddr1也就是加载内核的ddr。首先测试供电跟基准电压都正常,测试回路压降,通讯也是正常的。更换两片ddr1试机图像正常。
打印如下:
2019-5-10, 15:30:51 COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809H: MIU0ALvs 9Lvs 8,89Lvs ALvs 6,6BLvs ALvs 8,89Lvs ALvs 5,6MIU1ALvs 9Lvs 8,7BLvs CLvs 6,7ALvs ALvs 8,7BLvs BLvs 7,7 DATE=Sep 5 2013, Time=10:05:45g_u32AP_FlashStart = 0xA080g_u32AP_FlashEnd = 0x10B410g_u32AP_Size = 0x101390(1053584)g_u32AP_RamStart = 0x100000 CopyFlashToDram( u32DramAddr=0x100000, src=0xA080, Size=1053584(0x101390) )----- Jump to Ap 0x100000 -----[AP] console init ok~__heap=0x213E00, __heap_end=0x300000, _readonly_start=0x104000, _readonly_end=0x1DC000,Jump to main()================================================= Urania ==============Software Version: 2.03.00Software CL: $Change: 693454 $[Board]: BD_MST166A_D01A_S_SZ[Panel]: PNL_CSOT_TA290107AE03_Vx1_4K2K_60Hz_4plus4[MEMORY_MAP]: MMAP_URANIA_256_256[DRAM SIZE]: 512 MB[FLASH SIZE]: 2 MB===================================== MApi_Ini_Variable()MApi_Ini_Variable_InputConfig() for LVDSMDrv_Chip_Initial()MDrv_UART_DebugInit Mute at 51MDrv_TX_InitAll() at 52MDrv_Tx_SetTgen() at 54 g_TX_u16FDE_VStart=52 g_TX_u16FDE_VEnd=2211 g_TX_u16FDE_VSize=2160 g_TX_u16MiniVTotalForDE=2212 g_TX_u16MiniVTotalForVTrig=2205MDrv_TX_SetModPower(0) at 69MDrv_PWM_Init()MApi_Backlight_Init(ePwmCh=0)MApi_3D_GLASSES_PWM_Init() use PWM_2MHal_LvdsRx_Set_Power(bEn=0)Data Rx selection out of rangeData Rx selection out of rangeCH 1 ENABLECH 2 ENABLEMApi_XC_Sys_Init_PQ() at 89TextBinStartaDDR ID0=F6CC400 u16PQBinId=0x600 u16CustomerId=0x0 u16PQBinId=0x800 u16CustomerId=0x0MDrv_GAMMA_BIN_Load()MApi_FUNC_Set_InputSource(src=0) VideoSrc=LVDSBrian msDlcInitWithCurve 305 ===== Enter main loop at 396 =====Input change H:1920 V:1080, f:0, preH:0 preV:0 preF:0uwAction=E1DAChange output timing: gSysConfig.u8PanelVfreq=60[APP_ACTION_3D_MODE]3D Format mapping to 33D Format mapping to 33D Format mapping to 3MDrv_PQ_DesideSrcType(src=0)==> 8(LVDS_RX_FHD_50Hz)MDrv_PQ_LoadSettings() _u16PQSrcType=8(LVDS_RX_FHD_50Hz)3D Format mapping to 33D Format mapping to 3[Vx1 Training!] UnMute at 494Switch patch e3dType:0 eFrcRate:0 eVideoType:1 MApi_PWM_Set_OutputVFreq(u16OutVFreqX10=599)uwAction=101[Vx1 Training!][Vx1 Training!][Vx1 Training!][Vx1 Training!][Vx1 Training!]Got command: g_ucMFCCmdReceivedIdx=7 CheckSum=9 Cmd=308 CheckSum1=9 [UC_SET_MOD_POWER]bModPowerOn=1MDrv_TX_SetModPower(1) at 1540!!!!!!Enable MOD patch!!!!Input change H:1920 V:1080, f:60, preH:1920 preV:1080 preF:0uwAction=E34AChange output timing: gSysConfig.u8PanelVfreq=60[APP_ACTION_3D_MODE]3D Format mapping to 33D Format mapping to 3MDrv_PQ_DesideSrcType(src=0)==> 9(LVDS_RX_FHD_60Hz)MDrv_PQ_LoadSettings() _u16PQSrcType=9(LVDS_RX_FHD_60Hz)3D Format mapping to 33D Format mapping to 3Switch patch e3dType:0 eFrcRate:1 eVideoType:1 Switch patch e3dType:0 eFrcRate:1 eVideoType:3 Got command: g_ucMFCCmdReceivedIdx=14 CheckSum=9 Cmd=308 CheckSum1=9 [UC_SET_MOD_POWER]bModPowerOn=1MApi_PWM_Set_OutputVFreq(u16OutVFreqX10=599)CPU alive - 5000ms, V=297 In Vf=5999, Out Vf=5999CPU alive - 10000ms, V=597 In Vf=5999, Out Vf=5999Got command: g_ucMFCCmdReceivedIdx=21 CheckSum=5 Cmd=104 CheckSum1=5 UC_SET_RX_OSD_ENABLEcore/api/mapi_mfc_cmd.c : MApi_CMD_ParseCmd : 406 URANIA_TODO: NOSD size configGot command: g_ucMFCCmdReceivedIdx=28 CheckSum=5 Cmd=303 CheckSum1=5 UC_SET_VIDEO_MUTEGot command: g_ucMFCCmdReceivedIdx=35 CheckSum=3 Cmd=313 CheckSum1=3 UC_SET_GAMMA_ON_OFFGot command: g_ucMFCCmdReceivedIdx=42 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=49 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=56 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=63 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=70 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=77 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=84 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=91 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=98 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=105 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=112 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=119 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=126 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=133 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=140 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=147 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=154 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=161 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=168 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=175 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=182 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=189 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=196 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=203 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=210 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=217 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=224 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=231 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=238 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=245 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=252 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=259 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=266 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=273 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=280 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=287 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=294 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=301 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=308 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=315 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=322 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=329 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=336 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=343 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=350 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=357 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=364 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=371 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=378 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=385 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=392 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=399 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=406 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=413 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=420 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=427 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=434 CheckSum=C Cmd=601 CheckSum1=C UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=441 CheckSum=D Cmd=601 CheckSum1=D UC_SET_HDMI_HDCPGot command: g_ucMFCCmdReceivedIdx=448 CheckSum=2 Cmd=602 CheckSum1=2 UC_GET_HDCP_COUNTGot command: g_ucMFCCmdReceivedIdx=455 CheckSum=5 Cmd=605 CheckSum1=5 UC_SET_HDMI_HDCP_UPDATECPU alive - 15000ms, V=898 In Vf=5999, Out Vf=5999 ** VideoMute=0x2Got command: g_ucMFCCmdReceivedIdx=462 CheckSum=1 Cmd=301 CheckSum1=1 UC_SET_3D_MODE3D Format mapping to 3Got command: g_ucMFCCmdReceivedIdx=469 CheckSum=5 Cmd=405 CheckSum1=5Got command: g_ucMFCCmdReceivedIdx=476 CheckSum=A Cmd=30A CheckSum1=A UC_SET_2DTO3DuwAction=10Got command: g_ucMFCCmdReceivedIdx=483 CheckSum=1 Cmd=302 CheckSum1=1 UC_SET_MFC_LEVELuwAction=101Got command: g_ucMFCCmdReceivedIdx=490 CheckSum=E Cmd=30E CheckSum1=E UC_GET_FW_VERGot command: g_ucMFCCmdReceivedIdx=497 CheckSum=F Cmd=30E CheckSum1=F UC_GET_FW_VERGot command: g_ucMFCCmdReceivedIdx=504 CheckSum=3 Cmd=303 CheckSum1=3
UC_SET_VIDEO_MUTECPU alive - 20000ms, V=1198 In Vf=5999, Out Vf=5999
第三期学员正在学习中,
“百人精英计划”名额有限,
6月报名正在进行中
请感兴趣的同学尽快,先到先得!
报名联系方式
国内
电话:020-28667686(潘老师)
微信:RDDZ2017
网络课程 碎片时间
随时随地 轻松学习
发表于: 2019-5-22 12:24:54
Thank you very much
回复 支持 0 反对 1
发表于: 2019-5-22 17:40:43
Thank you so much for your post.
发表于: 2019-5-23 16:01:49
Thank you for your sharing.
发表于: 2019-8-5 09:43:27
发表于: 2019-9-24 14:16:28
看来要把电视修好英语也要好才行哟!
GMT+8, 2024-12-19 20:13 , Processed in 0.077142 sec., 11 queries .
