查看: 1408|回复: 2
求大神看看这个打印信息,开机屏自检
发表于: 2019-4-20 09:43:24
BIST_0 PASS.
MIU Initial OK
Hello Nasa:A0000000
  _readonly_start=243000, _readonly_end=43A000
MIU protect align=1000
Beon protect start=243000, end=43A000
  heap => 601F40, => 640000
## heap size is 248K under 300K!!
@@@@@@ u32CpuSpeedMHz= 216 MHz
Hit = 0
wPM_WakeUpDevice 0x185
=> DC_BOOT (1)
PM Wakeup by 0x0
MDrv_Power_PMPowerRst() Line 132:
create Audio SHM data ...
USB_Init_Configure port 0
USB_Init_Configure port 0 done...
USB_Init_Configure port 1
USB_Init_Configure port 1 done...C悙   console_init() done
Flash is detected (0x0502, 0xC2, 0x20, 0x16)
MDrv_SERFLASH_Init() done
MApp_DB_Check()
MApp_DB_GEN_Init()
=> GoodUnit=18, WriteTime=2899
msAPI_DB_GEN_Printf_Variable():
s_stDB_GEN_InitData:
u8FlashBank: 0x3E
.u16FlashSaveUnitSize: 4096
.u32DramDataAddr: 0x640000
.u16DramDataSize: 2872
u8FlashUnitNumPer1Bank=16
u8FlashUnitNumTotal=32
u16FlashUnitInfoOffset=0xFE0
MApp_DB_Factory_LoadSettingAndCheck()
MApp_DB_CH_Init()
msAPI_DB_CH_Printf_Variable():
s_stDB_CH_InitData:
u8FlashBankStart: 0x3C
.u8FlashSaveBankCount: 1
.u32DramDataAddr: 0x641000
.u32DramDataSize: 0xE2DC
u8FlashBankStart_0=0x3C
u8FlashBankStart_1=0x3D
u32CheckDataOffset=0xFFF0
MApp_DB_CH_LoadDataBase()
Keypad Initialize OK
PANEL_DEFAULT_TYPE_SEL= 22
MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
[_MDrv_PNL_Init_LPLL][304]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][306]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][349]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][351]u16HTotal=2200,u16VTotal=1125,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1125, u16DefaultVFreq=600
[XC,Version] 00442327
MApi_XC_Init, 537, pXC_InitData->stPanelInfo.eLPLL_Type=1
** MHL Cbus index value 0
** MHL function support in port A
PACLK:0xC000
PACLK:0xC000
PACLK:0xC000
MHL Init, MHL_TYPE = 0x10
** Nasa Load MHL EDID...
** Nasa Load DevCap...
** MHL third DTD start at 9F in port A
** MHL total have 6 DTD in port A
** MHL get video data block length 12 in port A
** MHL get audio data block length 3 in port A
** MHL get speaker allocation data block length 3 in port A
** MHL get vender specific data block length 5 in port A
** MHL Cbus initial mux to port A
mapi_mhl_init()
[GOP_ALL, PID 0, TID 0x-1][Driver Version]: 0089, BuildNum: 0289, ChangeList: 2147483647
[HAL_TSP_CPU_SetBase][2167] load firmware (address, size) = (0x00606400, 0x00002A28)
firmware 111 0x00606400 0x00000000 0x0000C0C8
[HAL_DSCMB_SetBank][156] Set bank 0xA0200000
=== [Utopia Version] ===
[MSD6180][Hisense][CL817363] Utopia Version[20]
Mirror function (1)
u32ReadBuffVirAddr = 80E60000, u32IntBuffVirAddr = 80F60000, u32OutBuffVirAddr = 81B60000
verJPD_SetStatus >>>>>>>>>>> w:1920,  h:1080,  p:1920
MApi_PNL_En,stGenSetting.g_SSCSetting.LVDSSwing = 300
[GOP0, PID 0, TID 0x-1][Driver Version]: 0089, BuildNum: 0289, ChangeList: 2147483647
@INTERN_DTMB_PAD_TS1_Enable...
00186939009C
Auth OK
  MApi_AUDIO_SetCommand 0x0 []
 [Warning!!]No SRS TSXT license!!
DecID 0 disconnect MApi_AUDIO_ReleaseDecodeSystem() 1505
DecID 1 disconnect MApi_AUDIO_ReleaseDecodeSystem() 1505
DecID 2 disconnect MApi_AUDIO_ReleaseDecodeSystem() 1505
===Audio Type = 0
kabalt  => 8212 init start
8212_SWMute(1)
Audio_Amplifier_OFF++++++tv-ap/dvb/app/MApp_Init.c
  MApi_AUDIO_SetSystem 0x1 []
===== Check Audio Decoder Protection from hash-key IP =====
Hash-key Support DD.
Hash-key Support DD+.
Hash-key Support Generic HE-AAC!!
Hash-key Support WMA.
Hash-key Support DRA.
Hash Key Check Dolby MS11 Fail, no Dolby MS11 license!!
Hash Key Check DTSE Fail, no DTSE license!!
Hash Key Check DTSNeoUltra Fail, no DTSNeoUltra license!!
Hash Key Check SRS_TSHD Fail, no SRS_TSHD license!!
Hash Key Check SRS_THEATERSOUND Fail, no SRS_THEATERSOUND license!!
Hash Key Check DTS_StudioSound3D Fail, no DTS_StudioSound3D license!!
===== Check Protection IP End                         =====
Error: ATV_GetAudioMode: eSource=0
8212_SWMute(0)
  MApi_AUDIO_SetSystem 0x0 []
  MApi_AUDIO_SetSystem 0x5 []
Audio_Amplifier_ON()++++core/api/audio/msAPI_audio.c,+++1184  MApi_AUDIO_SetCommand 0x5 []
8212_SWMute(1)
==========Init Set 5711 un-mute===========
8212_SWMute(0)
SetAudioMuteDuringLimitedTime
INTERN_DTMB_Power_On_Initialization
MDrv_SYS_DMD_VD_MBX_Init more than twice
--------------DMD_DTMB_CHIP_WALTZ--------------
devCOFDM_Init, 299, device/cofdm/COFDM_Demodulator.c
==delay 20ms for Tunner init!
DSP code loaded successfully
===>ConfigAGCMode eMode 5
MxL Tuner Lock....
>> DTMB Exit Ok!
  MApi_AUDIO_SetSystem 0xB3 []
MxL Tuner Lock....
[VD] force=0
MxL Tuner Lock....
msAPI_Scaler_SetSourceType(SrcType=1,win=0)
_MApp_EpgTimer_SaveTimerList()~UpdateDB:0
_MAPP_EPGDB_Setup: [Current EPG DB occupy size: 0x4918E8];  [Max EPG DB config. size: 0x49C000]
==file==tv-ap/dvb/app/MApp_Init.c==line ===2596===1============
unsupport N51 FS compress
INIT MoZuPanelSelect: 0
INIT FactoryReset: 44
== Chakra3 Software Version: 0.00
[SW_CONFIG]: SW_CONFIG_TRUNK_NASA_64_DTMB
[Board]: BD_MST6180_64M_HISENSE
[Panel]: HD400DF_E32
[MEMORY_MAP]: MMAP_64MB
[DRAM SIZE]: 64 MB
[FLASH SIZE]: 4 MB
[ENABLE_DTV]
[ATV]: PAL
[Mirror]: 1
[ENABLE_PWS]: 1
[ENABLE_POWER_SAVING_DPMS]: 1
[DEMO_FINE_TUNE]: DFT_STD_FULLHD_CMO216
[ENABLE_DLC]: 1
[DISPLAY_LOGO]: 1
[ENABLE_POWERON_MUSIC]: 1
[FRONTEND_TUNER_TYPE]: MxL_661SI_TUNER
===== Enter main loop at 6462
===== Timestamp Dec 11 2015, 17:46:52
==file==tv-ap/dvb/ui2/MApp_ZUI_ACTchannelinfo.c==line ===606===============
[VD] stable => NO SYNC(7) at 560
VD: SetStd: No sync, 50Hz=1 => Use Std=PAL
MApp_DB_Factory_SaveData!
MApp_DB_Factory_UpdateAllCheckSum()
Warning: Someone want enable WP, but another one is in use!(0x2)
>> Write flash done~ => UnitIdx=19, wt=2900, use 40ms
MxL Tuner Lock....
<<<>>>> bVdInputIs50Hz 1, m_u16LatchStatus=0x3001
g_ColorTempSource = 0
==file==tv-ap/dvb/app/MApp_Scaler.c==line ===5686===============
MxL Tuner Lock....
[VD] Auto
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock....
MxL Tuner Lock...
发表于: 2020-2-25 18:05:14
刷机了吗海信电视吧,版本不对,屏参不对
GMT+8, 2024-12-19 18:11 , Processed in 0.047601 sec., 9 queries .
