求康佳LC47DS30C程序,开机出现KONKA就关机重启,如此反复,测各电压都对,1.2V3.3V5V就2.5V偏高2.6V,求大家帮忙指点,先谢过。
MStar Semiconductor Inc]
[MST5XXX]
[Version]: 40267
[Date]: Mar 04 2008
[Board]: BD_KonKa_6x89BL
[MCU_PLL]: 7 (1)
[Panel]: SAM_37_WXGA(0)
[FineTune]: DFT_9XXXC_LCD_LG32_WXGA
<MST_9xxx?A><ITU656>
<FRAME_BUF_PC444><DDR_8Mx16_1>
DDR Total use size = 0x1000000
DDR last address = 0x710000
OSD size=2,0<24c64>
Total use size = 11F4
<HDCP><HDMI><MULTI_MWE><DLC_TT_MCU><CHINA>
<IF_TDA9886_380>
bInitEEPROM=0
g_SysSetting.PowerOn=1
Disable Audio Output
Pull Low HPD
Disable DVI Clock
Disable DVI Clock
Enable DVI Clock
Enable DVI Clock
Pull High HPD
Enter LogoHandler
g_ucMenuPageIndex=44
Load Chinese (0)
-LogoHandler Finished-
... DMABurstWrite Start ...
... DMABurstWrite End ...
<* Mst-VdDec *>: 0
AudioInit()
size=28EAuSifLoadCode(type=5)
AuWriteSIFThresholdTbl finish!
AuProcessLoadCode(type=8)
AuProcessLoadCode(type=3)
AuProcessLoadCode(type=0)
AuProcessSetPrescale(db=0)
Wait BK9_A9[1]=1 timeout!!
AuSetNormalPath(0,4,1)
AudioInit() endAuProcessSetBalance2(0,0)
enable=0AuLipSync: 0 samples.
AuSetNormalPath(1,4,1)
SetYpbPr3Power(0)
Disable Audio OutputAuSetNormalPath(0,43,0)
AuSetNormalPath(1,43,5)
AuSetNormalPath(2,43,3)
ucSrcNum=1
ucSRC_EN=8[*TV*]
========msProgWindow(0)=========AuLipSync: 0 samples.
==========Enter main loop==========
Video No Signal!
g_ucMenuPageIndex=28
Load Chinese (2)
g_PowerOffCount == 300
g_PowerOffCount == 299
