008: C:\Users\Administrator\Desktop\Print.log
009: COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
UART_115200
BIST0-OK
BIST1-OK
[123456789A][123456789A]-55
[123456789A][0123456789]-54
_nPD
U-Boot 1.1.6CL302471 (Mar 9 2011 - 06:50:36)
Board: MSTAR TITANIA WDT (CPU Speed 504 MHz)
DRAM: 0x8000000
Skipping flash_init
Module: KEYPAD USB FAT NAND UBI UBIFS NET SPI STANDBY JFFS2 LOGO URSA
NAND: nand_bbt: searching bbt....Bad block table found at page 131008, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 130944, version 0x01
256 MiB
In: serial
Out: serial
Err: serial
Net: No ethernet found.
MSVC00B000100100208768TH0000000T
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80 Group1:88 Group2:200 Group3:f1
Change MIU1 select.....
Group0:4200 Group1:e00 Group2:30 Group3:4000
Group0:d80 Group1:f8 Group2:200 Group3:f1
0x00000000-0x0fa00000 : "mtd=0"
UBIFS: recovery needed
UBIFS: recovery deferred
UBIFS: mounted UBI device 0, volume 6, name "FACTORY"
UBIFS: mounted read-only
UBIFS: file system size: 2031616 bytes (1984 KiB, 1 MiB, 16 LEBs)
UBIFS: journal size: 1142785 bytes (1116 KiB, 1 MiB, 8 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: LZO
UBIFS: reserved for root: 0 bytes (0 KiB)
Load 'misc.ini' to 0x80400000 ,size 5748 (0x00001674)...OK
Load 'au_d.bin' to 0xa0a01000 ,size 61013 (0x0000ee55)...OK
Load 'au_s.bin' to 0xa0ad1000 ,size 17117 (0x000042dd)...OK
Load 'logo.mp3' to 0xa0c01000 ,size 20524 (0x0000502c)...OK
Load 'logo.jpg' to 0xa0c21000 ,size 183450 (0x0002cc9a)...UBI error: ubi_io_read: error -74 while reading 4144
bytes from PEB 502:118792, read %zd bytes
UBIFS error (pid 0): try_read_node: cannot read node type 1 from LEB 10:114696, error -74
UBI error: ubi_io_read: error -74 while reading 4144 bytes from PEB 502:118792, read %zd bytes
UBI error: ubi_io_read: error -74 while reading 4144 bytes from PEB 502:122936, read %zd bytes
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0xfff58613, read 0x4e5aea6d
UBIFS error (pid 0): ubifs_check_node: bad node at LEB 10:118840
UBIFS error (pid 0): ubifs_read_node: expected node type 1
UBIFS error (pid 0): do_readpage: cannot read page 16 of inode 69, error -117
Err
Load 'system.cfg' to 0x80400000 ,size 20252 (0x00004f1c)...OK
6m30 installed
=======test=========
=========enter
MDrv_Ursa_6M30_Power_MODE()=============
=========enter MDrv_Ursa_6M30_Power_MODE() really=============
>>CMD:93,8,1,0,0,0,0
MDrv_Ursa_6M30_3D_Cmd write data success.....
POWER mode ok!!!
JPD E_JPEG_WAITDONE out
UART_115200
BIST0-OK
BIST1-OK
_nPD
DRAM: 0x8000000
Skipping flash_init
256 MiB
In: serial
Out: serial
Err: serial
Wait for PM51 standby...........PM51 run ok...........==== Enter Standby Mode !! ====
