查看: 1068|回复: 1
请教师傅 TCL,MT55cd 打印信息不知道什么故障
发表于: 2019-4-10 11:46:27
Boot-
DRAM Channel A Calibration.
Byte 0 : Gating(2 ~ 62), Size=61, Mid=34, Set=34.
Byte 1 : Gating(2 ~ 57), Size=56, Mid=31, Set=31.
Byte 2 : Gating(2 ~ 72), Size=71, Mid=39, Set=39.
Byte 3 : Gating(2 ~ 67), Size=66, Mid=36, Set=36.
HW Byte 0 : DQS(11 ~ 42), Size 32, Set 25, HW_Set 29.
HW Byte 1 : DQS(9 ~ 40), Size 32, Set 23, HW_Set 26.
HW Byte 2 : DQS(10 ~ 40), Size 31, Set 25, HW_Set 27.
HW Byte 3 : DQS(9 ~ 43), Size 35, Set 26, HW_Set 27.
DRAM A Size = 768 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x93a7519f
:0x3010875b
:0x30344739
:0x11010030
LZHS addr:0x00100040
LZHS size:0x00155210
LZHS checksum:0x0000007a
Boot
Start Lmain
MT5880 Boot Loader v0.9
Boot reason: A/C power on!!
read from eeprom ioff 0 phy_off ee0
SIF_Master0: new design
Load HDMI internal EDID.................
CEC Physical offset 158
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0x7d
HDMI2 PA 0x10
HDMI2 checksum 0x7d
HDMI3 PA 0x20
HDMI3 checksum 0x6d
HDMI4 PA 0x30
HDMI4 checksum 0x5d
rDtvCfg1.u1Flags=16
rDtvCfg1.u1Upgrade=0
rDtvCfg1.u1Upgrade_Ext=0
rDtvCfg1.u1Flags2=48
rDtvCfg1.u1Flags3=0
rDtvCfg1.u1Flags4=0
rDtvCfg1.u1Checksum=20
rDtvCfg1.u1UpgradeNum=0IR DATA register : 0x       0
Load T8032 FW (addr: 0x  e2eb00, size: 24576)success!!
T8032 FW version: 73
LDR_FlashCopy 0xf010 0x5f400 0x80
1st MAC in EEP is valid (5c:36:b8:2e:6e:6f)
1st : (5c:36:b8:2e:6e:6f)
2nd : (5c:36:b8:2e:6e:6f)
rDtvCfg1.u1Flags=16
rDtvCfg1.u1Flags3=0
rDtvCfg1.u1Flags4=0
rDtvCfg1.u1UpgradeNum=0Boot reason: A/C power on!!Boot reason: A/C power on!!
@@@@@@@@@rDtvCfg.u1Flags[16]@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@=
Org:0x10 Flags:0x10
         cccccccccccccccccc
---------test LYQ check eeprom boot-----------
PDWNC_EnterPowerDown(100,0)
Disable VGA wakeup
Standby
GMT+8, 2024-12-23 14:06 , Processed in 0.052895 sec., 9 queries .
