用户名  找回密码
楼主: shirleyhuang
EMMC ISP功能常见问题与解决方法
发表于: 2019-12-26 09:45:28
感谢官方强大技术支持,好的经验方案请多多分享!!!
举报
发表于: 2019-12-31 12:49:15
Thank you sharing sir
举报
发表于: 2020-1-1 10:43:52
编程器的VCC端对GND端接一个1uf的高频电容.我拿个液晶电视上贴片安装上24 /25存储器识别不了望同行注意
举报
发表于: 2020-1-31 11:38:10
Nice information sir
举报
发表于: 2020-2-8 19:36:14
Hi!
I am trying to configure a new EMMC chip for installation in a TV, but I have a problem.
I can not write configuration bytes 162 177 179 EXT_CSD EMMC V5.1.
I read the section EXT_CSD as a programmer RT809H through a socket BGA153 and ISP.
Then I correct the dump in the WinHex editor, assign new values bytes 162, 177 and 179.
Then I write a new dump to EMMC, but the shell stops working, crashes.
When I read it again, I see byte 179 changing, but byte 177 and 162 do not change.
Is there any way to configure the new EMMC programmer RT809H?
If not, then will the algorithm be added to the program?
举报
发表于: 2020-2-22 08:17:15
for emmc read and write use Laptop
举报
发表于: 2020-2-22 15:37:29
004:  VCCIO: 3.3V
005:  eMMC OCR: 80FF8080
006:  eMMC CID:  1501004D324731484608250DB3E93F
007:  eMMC CSD: D02701320F5A03B9F6DBFFE78A4040
008:  Chip ID:00010015,Chip Name:M2G1HF
009:  Chip Size: User=1908MB,Boot1=Boot2=1024KB,RPMB=128KB.
010:  SAMSUNG EMMC Version : V4.41
011:  Speed set to level 1.
012:  Start writing chip......
013:  EMMC version in current EXT_CSD file is V4.41
014:  BOOT1Write and verify success.
015:  CRC error @ 0xFFE00
016:  Write error, operation terminated.
举报
发表于: 2020-2-22 18:00:24
Edited by mekaku68 at 2020-2-25 07:31
pimasında doğru. seçenek bastığımda otomatik isp bağlanmıyor. Okuma kalitesinde okur. Silme ile siler. Yazma ile yazmaz.
举报
发表于: 2020-2-23 15:18:40
imranashraf 2020-2-22 02:17
why.......?
举报
GMT+8, 2025-4-16 12:43 , Processed in 0.053916 sec., 11 queries .
