查看: 1367|回复: 9
求助 长虹48c1液晶电视刷机数据
发表于: 2019-3-6 11:31:39
故障现象    开机背光亮有开机音乐,液晶屏暗蓝,无图像。
今天编程器到了迫不及待的打印了信息,请大师们帮忙看看有什么问题。打上打印信息说已经超过字数没办法上传个附件。
2019-3-7, 18:7:3
COM4, BaudRate:115200 bps, RXD: VGA-> 4,TXD: VGA->11, Printed by RT809H:
USB-3: ClassCode= 0x0, u4Diff=0 ms.
No USB device.
No or Unknown SD/MMC device.
USB upgrade stop
Flash load lzhs header from 0x80000 to dram(0x15043d0), size=2048
Decompression uboot to 0x01000000...
Flash load image from 0x80000 to dram(0x15043d0), size=0x3c5f5
Flash load tz from 0x0(part_16) to dram(0x1fb00000), size=0x414f6
LZHS start
LZHS done
LZHS start
LZHS done
Starting image...
U-Boot 2011.12.12 (Jan 17 2018 - 20:28:36)
DRAM:  403.4 MiB
u4DramSize: 0x200
WARNING: Caches not enabled
MMC:   HOST 1
11010030:30344736:3002A72E:108724AB
id1:00303034 id2:47363002
eMMC Name: THGBMDG5D1LBAIL
[emmc]bus timing switch to HS
[emmc]bus width switch to 8(SDR)
msdc clock driving = 0!
msdc clock driving = 7!
[emmc]bus clock switch to 50000000
msdc clock driving = 23!
[MSDC_MT5399_MMC] emmc capacity high: 0x0, low: 0x0~
: 0
msdcgpiomsdcgpio=234,47,-1,-1,-1,-1,
0.0.0.0
In:    serial
Out:   serial
Err:   serial
Net:   init MMAC driver
ethernet internal PHY init successful!
priv : 0x00ef1d30
Mmac:hyAddr=0
Mmac::initialize
Net Initialization Skipped
lvlv
pmisc_msg:
kernel: signature verification is OK
 楼主| 发表于: 2019-3-7 18:44:20
接着1楼
## Booting kernel from Legacy Image at 00007fc0 ...
   XIP Kernel Image ... OK
OK
Starting kernel ...
TZ Heap: start=0x1FDE3240, end=0x20000000
TZ dram: start=0x1FD00000, end=0x20000000
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpuset
Initializing cgroup subsys cpuacct
Linux version 3.10.27 (yangxiaosheng@BSR16) (gcc version 4.8.2 20131014 (prerelease) (Linaro GCC 4.8-2013.10) ) #1 SMP PREEMPT Wed Jan 17 20:27:53 CST 2018
CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: MT5882
cma: CMA: reserved 16 MiB at 12400000
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @c09b7000 s7488 r8192 d12992 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 102648
Kernel command line: lpj=120000 console=ttyMT0,115200n1 root=/dev/mmcblk0p5 vmalloc=700mb mtdparts=mt53xx-emmc:2M(uboot),2M(uboot_env),2M(misc),20M(recovery),20M(boot),768M(system),80M(perm),80M(hwcfg),768M(cache),1M(reserved),1M(channelA),1M(channelB),1M(pq),1M(aq),4M(logo),4M(panel),1M(tzbp),3M(adsp),2M(hdcp),1894M(userdata) usbportusing=1,1,1,1 usbpwrgpio=44:1,45:1,46:1,47:1 usbocgpio=404:0,404:0,405:0,405:0 usbhubrstgpio=-1:-1 msdcgpio=234,47,-1,-1,-1,-1 tzsz=3m androidboot.serialno=0123456789ABCDEF
Parse Done: usb port[0] Using =1
Parse Done: usb port[1] Using =1
Parse Done: usb port[2] Using =1
Parse Done: usb port[3] Using =1
Parse Done: usb port[0] Gpio=44, Polarity=1
Parse Done: usb port[1] Gpio=45, Polarity=1
Parse Done: usb port[2] Gpio=46, Polarity=1
Parse Done: usb port[3] Gpio=47, Polarity=1
Parse Done: usb port[0] Gpio=404, Polarity=0
Parse Done: usb port[1] Gpio=404, Polarity=0
Parse Done: usb port[2] Gpio=405, Polarity=0
Parse Done: usb port[3] Gpio=405, Polarity=0
Parsing String = 234,47,-1,-1,-1,-1
Parse Done: msdc [0] = 234
Parse Done: msdc [1] = 47
Parse Done: msdc [2] = -1
Parse Done: msdc [3] = -1
Parse Done: msdc [4] = -1
Parse Done: msdc [5] = -1
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 403MB = 403MB total
Memory: 365300k/365300k available, 47756k reserved, 97664K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xd3800000 - 0xff000000   ( 696 MB)
    lowmem  : 0xc0000000 - 0xd3400000   ( 308 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc058876c   (5634 kB)
      .init : 0xc0589000 - 0xc05aed40   ( 152 kB)
      .data : 0xc05b0000 - 0xc05e88a0   ( 227 kB)
       .bss : 0xc05e88a0 - 0xc0689cb4   ( 646 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:256
ckgen Xtal:24000000 Hz
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
Console: colour dummy device 80x30
console [ttyMT0] enabled
Calibrating delay loop (skipped) preset value.. 48.00 BogoMIPS (lpj=120000)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0xc0415728 - 0xc0415780
(yjdbg) mt53xx_boot_secondary: 1, 1
(yjdbg) mt53xx_cpu_boot: 1
we turn on CPU1
CPU1: Booted secondary processor
(yjdbg) mt53xx_secondary_init: 1, 1
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
(yjdbg) mt53xx_boot_secondary: 2, 2
(yjdbg) mt53xx_cpu_boot: 2
we turn on CPU2
CPU2: Booted secondary processor
(yjdbg) mt53xx_secondary_init: 2, 2
CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
(yjdbg) mt53xx_boot_secondary: 3, 3
(yjdbg) mt53xx_cpu_boot: 3
we turn on CPU3
CPU3: Booted secondary processor
(yjdbg) mt53xx_secondary_init: 3, 3
CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
Brought up 4 CPUs
SMP: Total of 4 processors activated.
NET: Registered protocol family 16
DMA: preallocated 2048 KiB pool for atomic coherent allocations
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource timer2
Clockevents: could not switch to one-shot mode:
dummy_timer is not functional.
Could not switch to high resolution mode on CPU 0
Clockevents: could not switch to one-shot mode: dummy_timer is not functional.
Could not switch to high resolution mode on CPU 2
Could not switch to high resolution mode on CPU 1
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
Trying to unpack rootfs image as initramfs...
Could not switch to high resolution mode on CPU 3
Freeing initrd memory: 20848K (c4000000 - c545c000)
Power Management for MTK DTV.
bounce pool size: 64 pages
squashfs: version 4.0 (2009/01/31) Phillip Lougher
msgmni has been set to 595
io scheduler noop registered
io scheduler deadline registered
io schedulerSerial: MT53xx drttyMT0 at MMIO 0xf000c000 (irq = 81) is a MT53xx Serial
ttyMT1 at MMIO 0xf000c000 (irq = 144) is a MT53xx Serial
ttyMT2 at MMIO 0xf0028800 (irq = 64) is a MT53xx Serial
ttyMT3 at MMIO 0xf000c000 (irq = 81) is a MT53xx Serial
brd: module loaded
loop: module loaded
 楼主| 发表于: 2019-3-7 18:46:18
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
PPP generic driver version 2.4.2
PPP BSD Compression module registered
PPP Deflate Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
mousedev: PS/2 mouse device common for all mice
mt53xx_rtc mt53xx_rtc.0: rtc core: registered mt53xx_rtc as rtc0
mt53xx_rtc mt53xx_rtc.0: MT53xx Real Time Clock driver.
adbattery: android dummy battery driver loaded
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
MTK_MSDC: MediaTek MSDC Driver
yifan host0 drv probe
msdc0 -> host0 select clk source 0 <- msdc_select_clksrc() : L<1318> PID<swapper/0><0x1>
msdc0 -> msdc drving<clk 16,cmd 16,dat 16> <- msdc_init_hw() : L<5427> PID<swapper/0><0x1>
msdc0 -> host0 set ios, power_mode 1,bus_width is 0,clock is 0 <- msdc_ops_set_ios() : L<4825> PID<swapper/0><0x1>
msdc0 -> host0 set ios, power_mode 2,bus_width is 0,clock is 400000 <- msdc_ops_set_ios() : L<4825> PID<swapper/0><0x1>
msdc0 -> msdc0 -> set mclk to 400000 <- msdc_set_mclk() : L<1362> PID<swapper/0><0x1>
msdc0 -> !!! Set<400KHz>  -> sclk<400KHz> DDR<0> mode<0> div<16>msdc0 -> host0 set ios, power_mode 2,bus_width is 0,clock is 400000 <- msdc_ops_set_ios() : L<4825> PID<kworker/u8:0><0x6>
yifan host1 drv probe
msdc0 -> XXX CMD<8> MSDC_INT_CMDTMO Arg<0x000001aa> <- msdc_command_resp_polling() : L<2186>
msdc0 -> XXX CMD<8><0x1aa> Error<-110> Resp<0x0> <- msdc_dump_trans_error() : L<4329> PID<kworker/u8:0><0x6>
[yifan] eMMC Name: THGBMDG5D1LBAIL
msdc1 -> !!! Set<400KHz>  -> sclk<400KHz> DDR<0> mode<0> div<16>
[msdc_debug_proc_init]: successfully create /proc/msdc_debug
[msdc_debug_proc_init]: successfully create /proc/msdc_help
[msdc_debug_proc_init]: successfully create /proc/msdc_tune
msdc0 select card<0x00010000>mmc0: BKOPS_EN bit enable
[msdc_debug_proc_init]: successfully create /proc/msdc_tune_flag
msdc0 -> !!! Set<50000KHz> -> sclk<50000KHz> DDR<0> mode<1> div<0>hidraw: raw HID events driver (C) Jiri Kosina
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
zram: num_devices not specified. Using default: 2
zram: Creating 2 devices ...
ion_device_create  num_heaps = 3
ashmem: initialized
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
nf_conntrack version 0.5.0 (6289 buckets, 25156 max)
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP: cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 3
Registering SWP/SWPB emulation handler
mmc0: new high speed MMC card at address 0001
mt53xx_rtc mt53xx_rtc.0: setting system clock to 2000-01-01 16:00:00 UTC (946742400)
ALSA device list:
  No soundcards found.
mmcblk0: mmc0:0001 004G60 3.68 GiB
mmcblk0boot0: mmc0:0001 cblk0boot0: mmc0:0001 004G60 partition 1 2.00 MiB
Freeing unused kernel memory: 148K (c0589000 - c05ae000)
stat: /data/home_extend/yangxiaosheng/zhaobo/rtc_ch/rtc_5507_512m_mp_v128_20180117_cm/release/vm_linux/chiling/kernel/linux-3.10/fs/namespace.c:2674
mmcblk0boot1: mmc0:0001 004G60 partition 2 2.00 MiB
part 01: startblk 0x00000000, blkcnt 0x00001000, <uboot>
part 02: startblk 0x00001000, blkcnt 0x00001000, <uboot_env>
part 03: startblk 0x00002000, blkcnt 0x00001000, <misc>
part 04: startblk 0x00003000, blkcnt 0x0000a000, <recovery>
part 05: startblk 0x0000part 06: startblk 0x00017000, blkcnt 0x00180000, <system>
part 07: startblk 0x00197000, blkcnt 0x00028000, <perm>
part 08: startblk 0x001bf000, blkcnt 0x00028000, <hwcfg>
part 09: startblk 0x001e7000, blkcnt 0x00180000, <cache>
part 10: startblk 0x00367000, blkcnt 0x00000800, <reserved>
part 11: startblk 0x00367800, blkcnt 0x00000800, <channelA>
part 12: startblk 0x00368000, blkcnt 0x00000800, <channelB>
part 13: startblk 0x00368800, blkcnt 0x00000800, <pq>
part 14: startblk 0x00369000, blkcnt 0x00000800, <aq>
part 15: startblk 0x00369800, blkcnt 0x00002000, <logo>
part 16: startblk 0x0036b800, blkcnt 0x00002000, <panel>
part 17: startblk 0x0036d800, blkcnt 0x00000800, <tzbp>
part 18: startblk 0x0036e000, blkcnt 0x00001800, <adsp>
part 19: startblk 0x0036f800, blkcnt 0x00001000, <hdcp>
part 20: startblk 0x00370800, blkcnt 0x003b3000, <userdata>
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20partition_access is 0x2
 楼主| 发表于: 2019-3-7 18:48:17
mmcblk0boot1: unknown partition table
partition_access is 0x1
mmcblk0boot0: unknown partition table
init: property 'ro.coredump' doesn't exist while expanding '/init.${ro.coredump}.rc'
init: error while handling import on line '10' in '/init.mt5882.rc'
init: property 'ro.coredump' doesn't exist while expanding '/init.${ro.coredump}_folder.rc'
init: error while handling import on line '11' in '/init.mt5882.rc'
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
init: do_system(502): mknod /dev/block/mmcblk0p13 b 179 13 success
init: do_system(502): mknod /dev/block/mmcblk0p17 b 179 17 success
init: /dev/hw_random not found
init: coinit: cannot open '/initlogo.rle'
mtk_mod: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
MediaTek MT53XX Driver : MTK_002001_000000 (MTK_2.1.0.0)
stat: /data/home_extend/yangxiaosheng/zhaobo/rtc_ch/rtc_5507_512m_mp_v128_20180/kernel/linux-3.10/fs/namespace.c:2674
partition_access is 0x0
EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: commit=1,noauto_da_alloc
Mapped physical address 0x19b60000 - 0x1fd00000 to virtual begins 0xd5000000
Enable MID on 00000000 to 19360000
DTV>
[FBM]_ucFbpListNs 3
[FBM]Before 4k2k, MPEG1 (Y+MV)Size:0x2780000; (C)Size 0x0 MPEG2 (Y+MV)Size:0x0 (C)Size 0x0
[FBM]FBP(0) Type 0 Addr 0x19b60000 AddrC 0x19b60000 Size 0x01e61800
[FBM]FBP(1) Type 0 Addr 0x19b60000 AddrC 0x19b60000 Size 0x01e61800
[FBM]Seamless[0] Addr 0x1bce6000 u4Size 0x5fa000 fgInUse 0
[SIF]SIF_Init: SCL stretch enabled 0, open drain mode 1.
SIF_Master0: V2 design
[IR]PDWNC_Init
Preloader T8032 ack !
GPIO_MtkLedCtrlFunc_eLedStatus=3
Find panel index 1 from EEPROM
Panel Flash Table Size=256 ,>0 means usung flash table
u4Offset == 0x70
msdc_partread(/dev/block/mmcblk0p16) oft 0x70 size ox44Calc Flashpanel attrib checksum =0xff
[xh_dbg] select flash panel's base data
msdc_partread(/dev/block/mmcblk0p16) oft 0xb4 size oxc0Calc Flashpanel ex_attrib checksum =0xffffffff
[xh_dbg] select flash panel's extra data
[OSD]DBG Timing is Front Scaler
[OSD]DBG u1DrvCBEIsBypass
[OSD]DBG u1DrvBitPlusSIsBypass
[OSD]DBG u1Drv3DCMSIsBypass
[OSD]i4H=310 i4V=9
[NPTV]DDDSinitial only set error limit
[OSD]i4H=310 i4V=9
[SA7] _fgVopllUseDDDS = True
[NPTV]vApiPanelPowerSequence= TRUE (START)
[NPTV][LVDS]panel backlight power on!
[cjy]create a thread to delay unmut 1200ms
msdc_partread(/dev/block/mmcblk0p14) oft 0x0 size oxc
GFX_CmdQueInit[0x4a01000,0x40000,0x7]
MTK FB for Android mtk_fb_probe
mt5395 fb get buffer :scr base:0xdc000000, phy start:0x19360000, size 8388608, _apu1OSDSbsBuf[0]=0x19458000, 0x197dc000
u4SrcWidth=1280 u4Value=0
osd2 src_w: 1280, src_h: 720, out_w: 1920, out_h: 1080
msdc_partread(/dev/block/mmcblk0p14) oft 0xc size ox534!!!! FlashAQ(0) Init OK !!!!
MTK FB for Android probe successful
*** mtkinp events probe ***
u4IrPulseTimeUnit is 50 us
Password: ChangHongTvModel ======== 48C1_LJ6Q.
msdc_partread(/dev/block/mmcblk0p18) oft 0x0 size ox28
[IR]
[AUD]i4AdspBinMemFill wait partition count=0
msdc_partread(/dev/block/mmcblk0p18) oft 0x0 size ox180c48
RF thread IRRC_RF_LEDBlinkFunc Reg ok.
Call IRRC_Init ret:0
====[input.c]input_mixsound_register(bf073d6c)====
Start ir loop
input: mtkinp_events as /devices/virtual/input/input0
input: mtkinp_events as /devices/virtual/input/input1
====> APROC version = 0x58820008
===========  Linux  ==============
Cache    Mem Addr 0x12620020
NonCache Mem Addr 0xd2620020
[AUD]HdRstDsp....u1DspId=0
[AUD][A]AOUT_CTRL vAout_Ctrl_Setine=274, AOUT=0x1600000 0
[AUD][A]AOUT_CTRL bAout_Enableine=274, AOUT=0x1600000 0
[AUD][FeedMixSndThread] Init - 201202132000
[A]AOUT_CTRL bAout_Enableine=299, AOUT=0x1610000 0
[UOP_DSP_MIXSOUND_FLAG] Reset MIXSOUND_MEMPLAY related common dram
[FeedMixSndThread] Enter
EXT4-fs (mmcblk0p20): warning: mounting fs with errors, running e2fsck is recommended
EXT4-fs (mmcblk0p20): recovery complete
EXT4-fs (mmcblk0p20): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
EXT4-fs (mmcblk0p7): recovery complete
EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
EXT4-fs (mmcblk0p8): recovery complete
EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
init: do_system(502): /sbin/sh /system/etc/service/mtk_rm.sh success
[VDEC][VDEC_RegRmCb] VDEC RM pfnRmCb(0xbf201108).
[MTIMAGEKNL]:_MTIMAGE_GetImgrzNum
Mali: MEM_VALIDATION - phys: 0x19360000, size 0x  800000
_MTIMAGE_GetImgrzNum rArg.ai4Arg[0] = 2
Mali: Mali device driver loaded
init: 001 do_commonbash commonbash ===/system/etc/service/dtv_svc.sh: line 16: stty: coinit: I read console
===init: 002 do_commonbash /system/etc/script/install_appstore.sh ===mmand not found
==> dtv_svc: started
init: =================app store running======================
Swapspace size: 102396k
Adding 102396k swap on /dev/block/zram0.  Priority:0 extents:1 across:102396k SS
init: not com.changhong.appstore.apk, or sdk appstore changed !
init: so copy /system/apk/com.changhong.appstore.apk to /data/app
init: 001 do_commonbash commonbash ===init: I read console
===init: 002 do_commonbash /system/etc/script/checktent.sh ==={At 00:00:2:707}<<<<<dtv_svc main() function begin...>>>>>
dtv_svc_main: fbm phy addr = 19b60000, share mem addr = b5ea6000, vir addr = 0, size = 0
{AWatchdog enable:1080000000
init: ===============check tent================
init: the nv is 0
init: the cv is 0
[CLI]___vsdblen=13,uIsSupport3D=0_______
[CLI]____svd uLength=0x11______
[CLI]_____DTDlength in block0=2_______
[CLI]_____block0 PixClk=14850_______
[CLI]_____block0 PixClk=8550_______
[CLI]_____block1 PixClk=8726_______
[CLI]_____block1 PixClk=14850_______
[CLI]_____block1 PixClk=7950_______
[CLI]vic 1
[CLI]vic 2
[CLI]vic 3
[CLI]vic 4
[CLI]vic 5
[CLI]vic 6
[CLI]vic 7
[CLI]vic 8
[CLI]init: cannot find '/system/bin/rild', disabling 'ril-daemon'
[CLI]vic 10
[CLI]vic 11
[CLI]vic 12
[CLI]vic 13
[CLI]vic 14
[CLI]vic 15
[CLI]vic 16
[CLI]vic 17
[CLI]dtd 1
[CLI]dtd 2
[CLI]dtd 3
[CLI]dtd 4
[CLI]dtd 5
[CLI]dtd 6
t 00:00:2:732}<<<<<Before x_drvvic 9
init: cannot find '/system/bin/iflytekdeamon', disabling 'iflytekdeamon'
_init() ...>>>>>
drv_init as 0init: cannot find '/system/bin/virtualsensor', disabling 'sensor-daemon'
[CEC]HDMI CEC u4WakeUpReason = 3..............init: cannot find '/system/bin/pppoe_wrapper', disabling 'pppoe_wrapper'
x39 model
drv_init as EU model
[ALSA] alsa_mt85xx_init().
[ALSA] probe: devptr->id = 0
==> pre-init start
post-init: start
2.88 6.15
[CEC]EEPROM ok. u4Val = 0.
_____u1RapOnOff=0______
==> pre-init end
{x_rm_reg_comp}[CH Debug] reg_com[NPTV]DDDSinitial only set error limit
p e_comp_type21
{x_rm_reg_comp[NPTV]Display Init[NPTV]Video SW Init[NPTV]TTD FW On/Off = 0
[NPTV]TTD FW On/Off = 1
[NPTV]NOT support xvYCC
[NPTV]Meter ISR Enable [OSD]DBG u1DrvBitPlusSIsBypass
[OSD]i4H=310 i4V=9
[SCPOS]Register SCPIP ISR OK!
[MJC]MJC Initialize.
[MJC]MJC ISR registered!
[NPTV][OD] : FBM is  ready for OD
[NPTV]Update OD Check init failed  ----  0
[NPTV][OD] : FlashPQ OD Not Ready
[NPTV][OD] IS_OD_ENABLE=[0x0]
[NPTV][OD] OD flag off
[NPTV]Load OD table
[NPTV]NOT Support OD Table
[NPTV]NOT Support PCID Table
[NPTV]OD OFF
[NPTV] PCID OFF
[NPTV]Success to register OD ISR!
[NPTV]OD ISR registered!
[NPTV]Video HW Init[NPTV]VBI_Init
[NPTV]Enable AdaptiveLuma
}[CH Debug] reg_comp e_comp_typ[NPTV]*******========source detect initial
[IR] set vga pdwnc module
[NPTV]vApiVideoInit
[NPTV]Verf PE Table Passed
u8Offset =0,0e20
PqDataLength=======64, 64read flash pq succussful!
Linux video capture interface: v2.00
[NPTV]FlashPQ ID OK
u8Offset =0,8020
PqDataLength=======48, 48read flash pq succussful!
u8Offset =0,8050usbcore: registered new interface driver uvcvideo
USB Video Class driver (1.1.1)
 楼主| 发表于: 2019-3-7 18:50:23
PqDataLength=======35840, 35840read flash pq succussful!
[NPTV]FlashPQ Qty OK
[NPTV]FlashPQ[0] Register DataEXT4-fs (mmcblk0p6): re-mounted. Opts: (null)
table Index Error! 0 >= 0
[NPTV]stat: /data/home_extend/yangxiaosheng/zhaobo/rtc_ch/rtc_5507_512m_mp_v128_20180117_cm/release/vm_linux/chiling/kernel/linux-3.10/fs/namespace.c:2683
wait for /cache init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
Timing        0  item    20001  value        0
[NPTV]Timing        0  item    20000  value       e0
[NPTV]Timing        0  item    20002  value       80
Mtk DBL _AdaptiveBacklightSetCurve y0 = 128, x1 = 24, y1 = 128, x2 = 100, y2 = 128
Mtk DBL _AdaptiveBacklightSetCurve x3 = 140, y3 = 80, x4 = 250, y4 = 0, y5 = 0
[NPTV]Set 3D depth control enable  0
[NPTV]TDDC FW On/Off = 0
AP set Output Window Width or Height is 0
init: powerctl: cannot expand '${sys.powerctl}'
init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
init: property 'sys.sysctl.tcp_def_init_rwnd' doesn't exist while expanding '${sys.sysctl.tcp_def_init_rwnd}'
init: cannot expand '${sys.sysctl.tcp_def_init_rwnd}' while writing to '/proc/sys/net/ipv4/tcp_default_init_rwnd'
mounted 1
register src chg call back in vd[VDEC][VDEC_RegRmCb] VDEC RM pfnRmCb(0xbf201108).
GetSwDmxPlayStatus =0
p_if2
[DMX]_DMX_MUL_AllocTsIdx: 0, 0,0
_MTDMX_Init - void end
[SWDMX]FBM_POOL_TYPE_SWDMX: 0x1e988ad0, 2142720
[SWDMX]_u4APreFIFO: 0xd9e28ad0--0xda033cd0, 2142720
[FEEDER]FEEDER get memory info
[FEEDER]mmp vir:0xd8f33000,size:0x300000
[FEEDER]feeder vir:0xd8f33000,size:0x300000
[FEEDER]feeder2 vir:0xd5000000,size:0x0
TVD MsgCtrl:  NRL:60/40, PER:100/90
####7,vbus off,1..................
#####2,u1VbusFlag=1..................
x_drv_init end!!
{At 00:00:3:457OSD Show Logo start printk...
}<<<<<After x_drv_init() ...>>>create file error
{At 00:00:3:458}<<<<<Before MW init ...>>>>>
MTDRVCUST_OptQuery() fail, ret=-fuse init (API version 7.22)
1
NTFS driver 2.1.30 [Flags: R/O MODULE].
======== MUC_init USB port Common USB Driver*************=====
MUC_init 5631: [USB]Controller in DMA mode
MtkUsbHcd MtkUsbHcd.0: USB Host Controller
MtkUsbHcd MtkUsbHcd.0: new USB bus registered, assigned bus number 1
MtkUsbHcd MtkUsbHcd.0: irq 79, io mem 0xf0050000
[NPTV]*******===== HDMI1 source detect no signal =====*******
[NPTV]NotifyAutoDetSrc(srcidx=13, sts=1)
[NPTV]<0>NotifyAutoDetSrc(av1(2),av2(2),ypbpr1(2),HDMI1(1),HDMI2(2),HDMI3(2),HDMI4(0) VGA(0))
[NPTV]*******===== HDMI2 source detect no signal =====*******
[NPTV]NotifyAutoDetSrc(srcidx=14, sts=1)
[NPTV]<0>NotifyAutoDetSrc(av1(2),av2(2),ypbpr1(2),HDMI1(1),HDMI2(1),HDMI3(2),HDMI4(0) VGA(0))
[NPTV]*******===== HDMI3 source detect no signal =====*******
[NPTV]Notusb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: USB Host Controller
usb usb1: Manufacturer: Linux 3.10.27 MtkUsbHcd
usb usb1: SerialNumber: MtkUsbHcd.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
MtkUsbHcd MtkUsbHcd.1: USB Host Controller
MtkUsbHcd MtkUsbHcd.1: new USB bus registered, assigned bus number 2
MtkUsbHcd MtkUsbHcd.1: irq 75, io mem 0xf0051000
ifyAutoDetSrc(srcidx=15, sts=1)
[NPTV]<0>NotifyAutoDetSrc(av1(2),av2(2),ypbpr1(2),HDMI1(1),HDMI2(1),HDMI3(1),HDMI4(0) VGA(0))
[NPTV]*******===== HDMI4 source detect no signal =====*******
[NPTV]NotifyAutoDetSrc(srcidx=16, sts=1)
[NPTV]<0>NotifyAutoDetSrc(av1(2),av2(2),ypbpr1(2),HDMI1(1),HDMI2(1),HDMI3(1),HDMI4(1) VGA(0))
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: USB Host Controller
usb usb2: Manufacturer: Linux 3.10.27 MtkUsbHcd
usb usb2: SerialNumber: MtkUsbHcd.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
MtkUsbHcd MtkUsbHcd.2: USB Host Controller
MtkUsbHcd MtkUsbHcd.2: new USB bus registered, assigned bus number 3
MtkUsbHcd MtkUsbHcd.2: irq 112, io mem 0xf0052000
runtime suspend not support!
usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb3: Product: USB Host Controller
usb usb3: Manufacturer: Linux 3.10.27 MtkUsbHcd
usb usb3: SerialNumber: MtkUsbHcd.2
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
MtkUsbHcd MtkUsbHcd.3: USB Host Controller
MtkUsbHcd MtkUsbHcd.3: new USB bus registered, assigned bus number 4
MtkUsbHcd MtkUsbHcd.3: irq 113, io mem 0xf0053000
input: Virtual Mouse as /devices/virtual/input/input2
input: Virtual Keyboard as /devices/virtual/input/input3
input: Virtual TouchScreen as /devices/virtual/input/input4
input: Virtual AccSensor as /devices/virtual/input/input5
input: Virtual MagneticField as /devices/virtual/input/input6
input: Virtual OriSensor as /devices/virtual/input/input7
input: Virtual Gyroscope as /devices/virtual/input/input8
usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb4: Product: USB Host Controller
chmod: /perm/voice: No such file or directory
chmod: /perm/voicmtk_fb_set_par info->var.xres=1280, u4Bpp =32
usb usb4: Manufacturer: Linux 3.10.27 MtkUsbHcd
usb usb4: SerialNumber: MtkUsbHcd.3
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 1 port detected
MUT_init
MUT_init register_chrdev() failed, -16
eact: No such file or directory
<5507> Usage:eeprom_read main-Start
<5507> argc = 1
Usage:eeprusbcore: registered new interface driver usb-storage
om_read Start addr:0x3d6 ,len=1
u4SrcWidth=960 u4Value=0
===running changhong script here===
{At 00:00:4:144}<<<<<Before MW customized parts init ...>>>>>
[AUD][Power off]AUD_DspDecPowerOffMute = 0
[PCMCIA]Internal CI.
[PCMCIA]PCMCIA_SwitchGPIO
[MTCI0] MTCI_Init : 0
MTCI0_RegFBClk() fail, ret=-1
[NPTV]NotifyAutoDetSrc(srcidx=2, sts=1)
[NPTV]<0>NotifyAutoDetSrc(av1(1),av2(2),ypbpr1(2),HDMI1(1),HDMI2(1),HDMI3(1),HDMI4(1) VGA(0))
[SHM alloc]{order = 10, ui4_page_num =961}
[MSDC_BLOCK]OK mtk_mmc_deviceinfo.chipsize_in_blk: 0x760000, blk_size: 0x200, erasesize_in_lik: 0x0, wpsize_in_blk: 0x0,~
Bad mode
/system/etc/script/changhong_run.sh: line 11: [MSDC_BLOCK]OK mtk_mmc_deviceinfo.chipsize_in_blk: 0x760000, blk_size: 0x200, erasesize_in_lik: 0x0, wpsize_in_blk: 0x0,~
[NPTV]NotifyAutoDetSrc(srcidx=3, sts=1)
[NPTV]<0>NotifyAutoDetSrc(av1(1),av2(1),ypbpr1(2),HDMI1(1),HDMI2(1),HDMI3(1),HDMI4(1) VGA(0))
/perm/bluetooth/TDRemoteCtrl: N[MSDC_BLOCK]OK mtk_mmc_deviceinfo.chipsize_in_blk: 0x760000, blk_size: 0x200, erasesize_in_lik: 0x0, wpsize_in_blk: 0x0,~
Usage:eeprom_rea[MSDC_BLOCK]OK mtk_mmc_deviceinfo.chipsize_in_blk: 0x760000, blk_size: 0x200, erasesize_in_lik: 0x0, wpsize_in_blk: 0x0,~
d Start addr:0x3d7 ,len=1
{At 00:00:4:486}<<<<<After MW customized parts init ...>>>>>
WAKE_UP_REASON: 0x00000003 - 0x00000000
Usage:eeprom_read Start addr:0x200 ,len=1
  TVOS first line
mt53: Exporting dma-buf
fb_get_dmabuf end dmabuf=c50cf300 flags=0x0
mt53 get dma_buf fd=28
<5507> resetFlag = 0
clean property
<5508> argv[0] = /system/bin/mtkEepInit
Usage:eeprom_read main-End
do mtkEepInit for AT
{At 00:00:5:195}<<<<<After MW init ...>>>>>
==> config ttyMT0 star
{At 00:00:5:210}<<<<< Enter _init_simple_dtv_svc>>>>>
/sbin/sh: /etc/script/adb_usb.sh: No such file or directory
===> after adb init: adb_usb
*** Mount EMMC ext4 cache...
EXT4-fs (mmcblk0p9): recovery complete
 楼主| 发表于: 2019-3-7 18:51:57
EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: noauto_da_alloc
can't create lock file /etc/mtab~1505: Read-only file system (use -n flag to override)
{At 00:00:5:286}{_init_simple_dtv_svc}acfg_init return 1
{At 00:00:5:286}{_init_simple_dtv_svc}init_channel_db return 0
_CompIdtoEsId 462, ucEsId(255) error
_CompIdtAP set Output Window Width or Height is 0
{At 00:00:5:313}{_init_simple_dtv_svc}brdcst_init return 0
{At 00:00:5:314}{_init_simple_dtv_svc}x_inps_init return 0
{At 00:00:5:315}{_init_simple_dtv_svc}a_e[AUD][Power off]AUD_DspDecPowerOffMute = 0
[AUD][Power off]AUD_DspDecPowerOffMute =mt53: Exporting dma-buf
fb_get_dmabuf end dmabuf=d134fb00 flags=0xb8ae9c08
mt53 get dma_buf fd=33
0
db_client_init return 0
{At 00[AUD][Power off]AUD_DspDecPowerOffMute = 0
:00:5:316}{_init_simple_dtv_svc}a_comp_init return 0
{At 00:00:5:316}<<<<< Exit _init_simple_dtv_svc>>>>>
{At 00:00:5:316}<<<<<FD: 22...>>>>>
{At 00:00:5:316}<<<<<dtv_svc main() function is ready...>>>>>
{At 00:00:5:316}<<<<<i4_ret: 0...>>>>>
post-init: sys.boot_complete chk: 1
[CHTV_API_System_Manager.cpp]::Init (line: 181)--> **********************************
aler_Ver: API:0.1,HAL:0.1
PQ_Ver: API:0.1,HAL:0.1
AQ_Ver: API:0.1,HAL:0.1
3D_Ver: API:0.1,HAL:0.1
Source_Ver: API:0.1,HAL:0.1
****CHTV MW  MODULE VERSION END****
[CHTV_API_System_Manager.cpp]::createAllApiObject (line: 263)--> CHTV Middleware API Resource Create
[CHTV_API_PanelManage.cpp]::CHTV_API_PANEL (line: 48)-->
**************Creat Panel  API class************
[CHTV_System_Entry.cpp]::Init (line: 313)--> CHTV Middleware Entry
[CHTV_System_Entry.cpp]::CHipHWInit (line: 134)--> CHTV Middleware CHip HW Resource Init
[CHTV_System_Manager_TV_China.cpp]::Init (line: 162)--> CHTV Middleware Resource Create and Module Init
[CHTV_Sqlite.cpp]::checkDirent (line: 10857)--> Dirent have exist
[CHTV_Sqlite.cpp]::GetPermDbPacket_Version (line: 10899)--> m_Db_Db_Vesion[6]=1004
[CHTV_Sqlite.cpp]::GetDataDbPacket_Version (line: 10939)--> m_Db_m_Db_Workspace_Vesion_Vesion[6]=1004
[CHTV_Sqlite.cpp]::preCheckDb_Status (line: 11053)-->  ********************no cpy ,data is newer [6]
[CHTV_Sqlite.cpp]::readDatabase_UserSetting (line: 7562)--> read begin UserSetting
[CHTV_Sqlite.cpp]::readDatabase_UserSetting (line: 7596)--> read end UserSetting
[CHTV_System_DataBase.cpp]:oadUserSysSetting (line: 230)--> debugLevel = 1
[CHTV_Sqlite.cpp]::GetPermDbPacket_Version (line: 10899)--> m_Db_Db_Vesion[2]=1003
[CHTV_Sqlite.cpp]::GetDataDbPacket_Version (line: 10939)--> m_Db_m_Db_Workspace_Vesion_Vesion[2]=1004
[CHTV_Sqlite.cpp]::GetPermDbPacket_Version (line: 10899)--> m_Db_Db_Vesion[3]=1002
[CHTV_Sqlite.cpp]::GetDataDbPacket_Version (line: 10939)--> m_Db_m_Db_Workspace_Vesion_Vesion[3]=1002
[CHTV_Sqlite.cpp]::GetPermDbPacket_Version (line: 10899)--> m_Db_Db_Vesion[4]=1002
[CHTV_Sqlite.cpp]::GetDataDbPacket_Version (line: 10939)--> m_Db_m_Db_Workspace_Vesion_Vesion[4]=1002
[CHTV_Sqlite.cpp]::GetPermDbPacket_Version (line: 10899)--> m_Db_Db_Vesion[5]=1004
[CHTV_Sqlite.cpp]::GetDataDbPacket_Version (line: 10939)--> m_Db_m_Db_Workspace_Vesion_Vesion[5]=1004
[CHTV_Sqlite.cpp]::GetPermDbPacket_Version (line: 10899)--> m_Db_Db_Vesion[8]=1000
[CHTV_Sqlite.cpp]::GetDataDbPacket_Version (line: 10939)--> m_Db_m_Db_Workspace_Vesion_Vesion[8]=1000
[CHTV_Sqlite.cpp]::GetPermDbPacket_Version (line: 10899)--> m_Db_Db_Vesion[9]=1000
[CHTV_Sqlite.cpp]::GetDataDbPacket_Version (line: 10939)--> m_Db_m_Db_Workspace_Vesion_Vesion[9]=1000
[CHTV_Sqlite.cpp]::GetPermDbPacket_Version (line: 10899)--> m_Db_Db_Vesion[1]=1003
[CHTV_Sqlite.cpp]::GetDataDbPacket_Version (line: 10939)--> m_Db_m_Db_Workspace_Vesion_Vesion[1]=1003
[CHTV_System_DataBase.cpp]:oadProductName (line: 1470)--> ProductName  = 48C1_LJ6Q
[CHTV_ATV_ChannelManage.cpp]::GetTunerCfgIndex (line: 1997)-->
Current tunerName= NXP-TDA18275A
[CHTV_ATV_ChannelManage.cpp]::GetTunerCfgIndex (line: 2001)-->
TunerFilePathName= /perm/chmw/tuner_cfg/NXP-TDA18275A.ini
[CHTV_ProductConfig.cpp]::iniparser (line: 1664)--> current CurrentProductName = 48C1_LJ6Q
<0>
----bHdmiSourceRemap:1----
[CHTV_ProductConfig.cpp]::iniparser (line: 1667)-->
--------CurrentProductPath  is /hwcfg/product/48C1_LJ6Q.ini--------
[CHTV_Panel_Manage.cpp]::Get_Panel_IniData (line: 504)-->  ==============u8Panelname=SEC_F_C480F16_E1_S4====================
[CHTV_Panel_Manage.cpp]::Get_Panel_IniData (line: 520)-->  ==============Panel_Ini_Path=/hwcfg/panel/SEC_F_C480F16_E1_S4.ini====================
[CHTV_Panel_Manage.cpp]::Get_Panel_IniData Mtk DBL _AdaptiveBacklightSetCurve y0 = 105, x1 = 24, y1 = 105, x2 = 100, y2 = 80
Mtk DBL _AdaptiveBacklightSetCurve x3 = 140, y3 = 65, x4 = 250, y4 = 0, y5 = 0
(l
HdmiNoStand = 0
i
u8Offset =0,0
[NPTV]FlashPQ ID OK
<0>QtyInitSuccess = 1----
ne: 534)-->  ==============load Panel.ini Success====================
[CHTV_ProductConfig.cpp]::CHTV_GetHwCfgUpdateFlag (line: 1964)-->  u8UpdateFlag = 0
[CHTV_Dbl.cpp]::Init (line: 131)-->  dbl_current_para.u1PresetGammaCompensateMode = 0
[CHTV_Picture.cpp]::Init (line: 1339)--> /hwcfg/pq/SEC_F_C480F16_E1_S4/SEC_F_C480F16_E1_S4_pq.ini
[CHTV_Picture.cpp]::CH_Pic_Update_All (line: 5511)--> CH_Pic_Update_AllOST_INIT
[CHTV_Picture.cpp]::CH_Pic_Convert_100toReallyValue (line: 2732)--> ~~Current PIC Curve:ATV~~
[CHTV_Audio.cpp]::CHTV_AQInitFromIniFile (line: 3055)--> current ProductConfigName = 48C1_LJ6Q
[CHTV_Audio.cpp]::CHTV_AQInitFromIniFile (line: 3060)--> Aq_path =/hwcfg/aq/aq/48C1_LJ6Q_aq.ini
[CHTV_Audio.cpp]::CHTV_AQInitFromIniFile (line: 3152)-->
[CHTV_A
bMute:1
Response is Ack: 0x24, Data0: 0x 0, Data1: 0x 0, Data2: 0x 0
[CHTV_Audio.cpp]::CHTV_AQInitFromIniFileResponse is Ack: 0x21, Data0: 0x 0, Data1: 0x 1, Data2: 0x 0
(line: 3152)-->
[MTVDO_SetTDTVPacking] 42, 0.
[CHTV_Scaler.cpp]:oad_OverScan_IniData (line: 3275)-->  ==============u8Panelname=SEC_F_C480F16_E1_S4====================
[CHTV_Scaler.cpp]:oad_OverScan_IniData (line: 3282)-->  ==============Panel_Ini_Path=/hwcfg/overscan/SEC_F_C480F16_E1_S4_SC.ini====================
[CHTV_System_SerialPort.cpp]::Init (line: 84)--> Enter serial Port Init!
[CHTV_System_SerialPort.cpp]::OpenDev (line: 325)--> open serial port Success!
[CHTV_System_SerialPort.cpp]::SetParity (line: 627)--> Set serial attr write hdmi edid to sram...
HDMI RX0 PA offset 168
HDMI RX0 PA 0x10
HDMI RX0 PA 0x10
HDMI1 RX0 checksum 0xc4
HDMI RX1 PA 0x20
HDMI RX1 checksum 0xb4
HDMI RX2 PA 0x30
HDMI RX2 checksum 0xa4
HDMI RX3 PA 0x40
HDMI RX3 checksum 0x94
Success!
[CHTV_System_UART1.cpp]::Init (line: 75)--> Enter UART1 Init!
[CHTV_System_UART1.cpp]::OpenDev (line: 155)--> open UART1 Success!
[CHTV_System_UART1.cpp]::SetParity (line: 306)--> Set serial attr Success!
[CHTV_System_UART1.cpp]::StartDataMonitorThread (line: 90)--> StartDataMonitorThread!
[CHTV_System_Manager_TV_China.cpp]::Init (line: 351)--> OpenTheSecondSerialPort()
[CHTV_EDID.cpp]::HDMI_Hdcp_Init (line: 670)--> Hdcp1.4 Key check finish! all right!!!
[CHTV_EDID.cpp]::HDMI_Edid_Init (line: 951)--> MHL edid NULL,no need set!!!
[CHTV_EDID.cpp]::HDMI_Edid_Init (line: 960)--> HDMI2.0 edid NULL,no need set!!!
[CHTV_EDID.cpp]::HDMI_Edid_Init (line: 969)-->  Hdmi edid set finish!
[CHTV_EDID.cpp]::VGA_Edid_Init (line: 1045)-->  Vga edid set finish!
[CHTV_EDID.cpp]::Hdcp2x_key_Check (line: 732)--> Hdcp2x Key check finish! all right!!!
[CHTV_Amp_Manager.cpp]::CHTV_Amp_SelectAmpInit (line: 101)--> Invalid  parameter !
ChanghongTV Adpt: CHTV_MW_Adapt_AQ_InstallCallbak ok
ATV_DEBUG: MTFE_ATV_Open() atv oic_support =0
[Vendor_Demod]Total 4 func table exist
pen
tuner index = 10
[Vendor_Demod]TunerAll u1PrCfg =10
jxj add :tuner id = 144
[Vendor_Demod]TunerAll tunertype
tuner index = 10
init: untracked pid 1564 exited
tuner index = 10
tuner ATD_Initialize successful !
[CHTV_System_Setting.cpp]::Get_Ctuner AtdEU_SetDeScrambleBox !
[TVD][TVD_DBG_MSG] vApiSetForDescrambler fgDeScrambleOnOffswich=0
[TVD][TVD_DBG_MSG] vApiSetForDescrambler _su1VpresGain=0x14,_su1VlockRatio=60
ommercial_RemoteMode (line: 258)--> bCominit: untracked pid 1569 exited
mercial_Mode=0
Sucess
/system/etc/script/changhong_run.sh: line 15: /system/bin/input_manager_server: No such file or directory
WDT driver for Acquire single board computer initialising
star: desc addr: 0xd261e000(virtual)/0x1261e000(physical)
Star Ethernet: Internal Vitesse PHY
发表于: 2019-3-10 12:59:30
屏不工作,要刷机程序干嘛
GMT+8, 2024-11-26 19:25 , Processed in 0.056983 sec., 9 queries .
