查看: 1109|回复: 1
创维55E660E开机后经常死机 打印数据
发表于: 2019-2-28 11:09:40
创维55E660E开机后经常死机 打印数据  请高手看看是什么故障谢谢
A
U-Boot 2012.07-svn629168 (Feb 20 2014 - 19:19:02)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
MISC: efuse had NOT been written
[krsv] use default uboot memory:
DRAM:  1 GiB
Watchdog: Enabled
init_amp_prepare
Board: Tv010 v2 1G Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
MMC:
emmc:mmc_initial(1) Feb 20 2014 19:19:15
RTD299x eMMC: 0
Device: RTD299x eMMC
Manufacturer ID: 11
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 8-bit
Extern param: MMC blk:0x7c (to 0x9000)
         rtk_eMMC_read blk_addr=0x0000007c, data_size=0x00000800, buffer=0x00009000
Factory: MMC
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000d1b0, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000f1b0, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00236000, buffer=0x0a900000
Factory: seq:0x116c, blk:0xe000(pp:1), size:0x236000 (to 0xa900000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=1
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
BOOT_PAL_NTSC_100_120_HZ not found
default is PAL: pal_ntsc_100_120_hz=0
boot_power_on_mode=1
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
TAG=21
init_amp
Factory_RO: MMC
         rtk_eMMC_read blk_addr=0x00008000, data_size=0x00000200, buffer=0x0b200008
[FAC_RO] No factory_ro data in eMMC
[ENV] read_env from factory failed
[ENV] Using default environment variables
Mac Address use 00:10:20:30:40:50
Panel: Use parameters in tmp/factory/bin_panel/panel.bin
Panel: sky_sdl420
panel_init_1st
$$$$$$$$ This is Local Dimming Panel !!!
Panel: ulFreq:149000000, nDPLL:157499520, Mcode:35, Ncode:3, offset:6e9
DispI : Finish BISR testing done
DispD : Finish BISR testing done
In:    serial
Out:   serial
Err:   serial
Net:   rtl8139: REALTEK RTL8139 @0xb8016000
Hit Esc or Tab key to enter console mode or rescue linux:  0
------------bootloader message size is 1088
======== Checking into android recovery ====
boot_ac_on=1
stopping USB..
Start Boot Setup ...
[eMMC]STR value:0x0,0x0
No STR...
REG 0xb8060100 : 0x0
JUMP address: 0x0
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000020, buffer=0x0a820000
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000400, buffer=0x0a820000
 楼主| 发表于: 2019-2-28 11:13:56
         FW Table to 0x0a820000, size=0x00000400 (0x0a820400)
         FW Table fr 0x02000000, fw count: 6
part_entry[0].len 0xec000000
fw_desc_table_v1.paddings 0x400
fw_total_paddings 0xee2200
eMMC_bootcode_area_size0x1800000
EMMC_FACTORY_SIZE 0x800000
g_u32STDsize 0xe911da00, g_u32STDoffset 0x2ae2600
blkNO 0x20000, 0x4000000, 0x200, 0x1
         rtk_eMMC_read blk_addr=0x00020000, data_size=0x00001000, buffer=0x000635a0
STD identifier NOT match, enter normal boot!!
Normal boot fw follow...
Linux Kernel:
         FW Image to 0x00108000, size=0x00992744 (0x00a9a744)
         FW Image fr 0x02008000 (non-lzma)
Audio FW:
         FW Image to 0x81700000, size=0x001b6bb8 (0x818b6bb8)
         FW Image fr 0x0299a800 (non-lzma)
         rtk_eMMC_read blk_addr=0x00014cd4, data_size=0x001b6bb8, buffer=0x01300000
         FW Image entry  checksum=0x08b9f9d1
         FW Image result checksum=0x08b9f9d1
Video FW 1:
         FW Image to 0x81a00000, size=0x002a2960 (0x81ca2960)
         FW Image fr 0x02b51400 (non-lzma)
         rtk_eMMC_read blk_addr=0x00015a8a, data_size=0x002a2960, buffer=0x01a00000
         FW Image entry  checksum=0x089c97c2
         FW Image result checksum=0x089c97c2
Video FW 2:
         FW Image to 0x81d00000, size=0x000b207c (0x819b207c)
         FW Image fr 0x02df3e00 (non-lzma)
         rtk_eMMC_read blk_addr=0x00016f9f, data_size=0x000b207c, buffer=0x01900000
         FW Image entry  checksum=0x0231b402
         FW Image result checksum=0x0271b402
ECPU FW:
         FW Image to 0x00004000, size=0x00001f80 (0x00005f80)
         FW Image fr 0x02ea6000 (non-lzma)
         rtk_eMMC_read blk_addr=0x00017530, data_size=0x00001f80, buffer=0x00004000
         FW Image entry  checksum=0x000c7db4
         FW Image result checksum=0x000c7db4
Video[image] data 1:
         FW Image to 0x85700000, size=0x000420f1 (0x857420f1)
         FW Image fr 0x02ea8000 (non-lzma)
         rtk_eMMC_read blk_addr=0x00017540, data_size=0x000420f1, buffer=0x05300000
         FW Image entry  checksum=0x029369a3
         FW Image result checksum=0x029369a3
Enable VCPU1
Enable VCPU2
aa 0xffff0010, 0x0, 0x0, 0x0
Release HW semaphore
ABCD[BOOT_AIO][0]  0x00000000
[BOOT_AIO][1]  0x00000000
[BOOT_AIO][2]  0x00000000
[BOOT_AIO][3]  0x00000000
[AIO_PATH] use default setting!
[AIO_PATH] src_sel_scart1    =  0x00000001
[AIO_PATH] src_sel_headphone =  0x00000001
[AIO_PATH] src_sel_pcm_dac0  =  0x00000007
[AIO_PATH] src_sel_pcm_dac1  =  0x00000007
spdif raw from PB
enable_clock 34 hold_hw_semaphore
VVwwaaiitt
VCPU1: BISR testing ....
VCPU1 : Finish BISR testing done
VCPU2: BISR testing ....
VCPU2 : Finish BISR testing done
aa 0x73811a3c, 0x98b01a27, 0x8004003, 0x0
Release HW semaphore again
V1go V2go panel_init_2nd
RosStartTaskRCosrSetaateHrtoToak s1kC32r
e
Va1 tpeHokotkQ   103x281d8c
50V00 ,p ktszQ  8  0x168 1c85
81
00, sz 8 16 8
V0 pktQ  0xa1c58100  0xa1d8c500
[vo] v1 PLL_VODMA m/n/o 9/0/0, clk: 297000000
[vo] v1 vsyncgen clk_div_n: 9/29700000
[vo] v1 vsyncgen ratio_n_off: 2/27843750
[vo] v1 vsyncgen div2: 13921875
[vo] v1 vsyncgen freerun: 0/27000000/60000/450000
[vo] v1 vsyncgen vs width: 27000000/525/857
[VO] Force DTG FRC
[VO]SynGen= 0x80000004
[vo] v2 PLL_VODMA m/n/o 9/0/0, clk: 297000000
[vo] v2 vsyncgen clk_div_n: 9/29700000
[vo] v2 vsyncgen ratio_n_off: 2/27843750
[vo] v2 vsyncgen div2: 13921875
[vo] v2 vsyncgen freerun: 0/27000000/60000/450000
[vo] v2 vsyncgen vs width: 27000000/525/857
[vo] Vodma(1) disable
[vo] VODMA(1) ForceBG(0)
VP_PowerOnVideo 38
~vbm create  0xa2504000, 34872
VBM: configured to DivX HD!
~detect query panel type 0
[vo] ShowChannel(p0)
POV: image filter testing
+++[RequestBuffer] width 1920, height 1080 ret 268435456
POV: request Buffer, Y_BufID = 0
POV: request Buffer, C_BufID = 1
POV: image filter testing Y_bufID 0, C_BufID 1
(IMG) JPEG detect!!IMG_DEC: Create Filter fmt 0
SE_SCALER_Init90): base0  0x83e74000, sz0  0x00800000,base1  0x84674000, sz1  0x00800000SE_SCALER: procBuf  0x84e74000, sz0  0x00400000
IMG_DEC: send ringbuffer cmd to Dec
JPEG_DEC: base= 0x85700000 limit= 0x85742100 Wr= 0x857420f1 Rd= 0x85700000
IMG_DEC: send Decode cmd to Dec
JPG_DEC: IMG_DECODE
IMG_DEC: send cmd to Scaler
(JPEG_COMP) get unread_marker  0x000000d8, dec  0x05700002!!
(JPEG_COMP) get unread_marker  0x000000e0, dec  0x05700004!!
(JPEG_COMP) get unread_marker  0x000000ee, dec  0x05700016!!
(Adobe) set saw_Adobe_marker TRUE!!
(JPEG_COMP) get unread_marker  0x000000e1, dec  0x05700026!!
(JPEG_THUMB) get ExifIFD  0x000000a6, S 5512, L 5418, i 6, size 7 !!
(JPEG_THUMB) NextIFD  0x000000c6, start 5512, length 5414 !!
(JPEG_THUMB) RealPic w 1920!!
(JPEG_THUMB) RealPic h 1080!!
(JPEG_COMP) get unread_marker  0x000000d8, dec  0x05700154!!
(JPEG_COMP) get unread_marker  0x000000e2, dec  0x05700156!!
(JPEG_APP2) check NOT MPO marker L:1364
(lJPdE_GW_rCiOtMeP)  g!e!t!  u
n
r
e
a dl_dm_aWrkerri t e0 x 0L000D0_0WeRdI,T Ede_cM O D0Ex_0N570O0Td_bF0O!L!
L(OJWP_EVGS_COYMNPC)! !g!e t u
n
re
a
d _malrdk_eWrr i t0x0e0 0!0!0!0 e
e,
d
ec
  0lxd0_5W7r00dibtee! !
L
D(_AWdobReI)T Es_eMtO saDwE__ANdOoTb_e_mFaOrLkLeOrW _TVRUES!Y!N
C(!J!P!E G
_CO
MP) get unrea
d
_ mladr_kWer r i0txe0 0!0!000!d b
d
ec   l0dx_0W5r7i0t0ed c e!!L
D(_JWPREIGT_ECOM_PM)O DgEe_tN unOrTe_aFdO_LmLarkOeWr_ V S0YxN000C0!0!0!c 0
dec  0x0
5
7 00el5d4_!W!r
i
t(eT H!U!M!B)  I
S
U
S IlNdG_ THWUrMiBt e0 ,  w L1D6_0W,R IVhT1 E 9_p0,Mkt OQtD gtE _0_wxN 1Oa91T2d_08Fc,O tL5gL0t0O_ Wh _ 10V0xS8aY01!Nc!C
5!8
(10T!HU0MB
le!ng t
h
44
1
4 4l,d _SWtarrti t e0 x!2!b80!0 1
4
0
  dledc_p_tWrr i t0ex 2b8 0L7D3_2W8R!I!T
E(_TMHOUDMEB_) PNEOETK_BFIOTLS  L0OxW0_0VfSfYed2N9C !!!!!
JPE
G
_ ClOdM_PW) greitt eu nre!!a!d _
m
a
r
ker  l d0_xW0r0i000t0ee d ,L Dd_ec W R0IxT0E5_7M015ObD8E!_!NO
T(_JFPOELGL_COOMWP_)V SgYeNt uCn!r!e!a d
_
m
a
r kledr_  0Wxr0i0t0e0 0!0e1!,!  d
e
c
0x 0l5d7_0W3rfi10!t!e
(TLHDU_MWBR)I TlenEg_tMhO D4E1_688N,O TS_tFaOrLt  L0OxW2_bV8S1Yf89N0C,! !d!e c
_pt
r
0 xl2db8_1Wfr8ict0e!!
!(!T H
UMB
P
E ElKdB_ITSW r i0txe0 0 ffeL2D0_2W R!I!T
E
(J_PMEOGD_EC_ONMOPT)_ FgOeLtL unOrWe_aVdS_YmNarkCe!r! !  0
0
0
0 0l0d0_e2,W rdietce   !0x0!5!7 05
3
6
f
! !l
d
_(WJPErGi_tAeP P 2L) cDh_eWcRkI TNEOT _MMPOOD Em_aNrkeOrT _LF:O1L3L64!O!W
(_JVPSEYGN_CC!O!MP)!  g
e
t
u nlrdead__Wmrairtkee r  !0!x!0 0
0
00
0
d bl,d _dWec r i0txe0 5L7D0_5W5b1R!I!T
E
_(MJPEOGD_EC_OFMOPL) gLeOtW _uVnSrYeadN_Cm a!r!k!e r
0
x000000db, dec  0x057055f6!!
(JPEG_COMP) get unread_marker  0x000000c0, dec  0x0570563b!!
(JPEG_COMP) get unread_marker  0x000000c4, dec  0x0570564e!!
(JPEG_COMP) get unread_marker  0x000000c4, dec  0x0570566f!!
(JPEG_COMP) get unread_marker  0x000000c4, dec  0x05705726!!
47!! $$$$$($JPE$G$_ ClOoMcPa) gle td iumnirneadg_ msaertkert i n0g xc000o0m0p0ldedt, dee c. . .0.x.057.0.5 7
f
ea!m!
p
i(nJPEiGt_ CaOtM Pp) gaente lu nrefaldo_wm,a r3ker0 3 20
0[0D000b0gd]a ,A MdPe_c  D0ExV0I5C7E0_580A4D!D!R=
1
a(0J0P0E0G0)0 Is0C0
0
,w w u1h9a2h0a- >p192a0n,e lhi d1 080=- >41
0
8i0n, hiotr  T0A,S 5ver7 101! !(
2(9J9P2E)G) .I.s
C
1, w 3840->3840, h 1080->1080, hor 0, ver 0!!
(JPEG_SENDST)   Luma, w 1920, h 1080, Hor 0, factor 0, Ver 0, factor 0!!
(JPEG_SENDST) Chroma, w 3840, h 1080, Hor 0, Ver 0!! SE_SCALER: MPO 1 0
GMT+8, 2024-11-28 04:28 , Processed in 0.061040 sec., 9 queries .
