查看: 2614|回复: 9
帮帮忙看下TCL打印信息,开机卡在LOOG故障是不是在EMMC
发表于: 2019-2-18 14:48:29
夿IST OK
BIST OK
ALL BIST OK!!
[123456789][3456789AB][3456789A][456789AB] 5767
[0123456789ABCDEF][0123456789ABCDEF][23456789AB][3456789ABCD] 7768
HAL_MIU_INIT2
Hello PM51...
Hello Main
MDrv_BDMA_Init OK..
bdma start .......
wait done.......
Bdma is done!
run code in dram
Start to reset MIPS
End of MIPS init
HAL_MB_Unmask_Cpu3_2_Cpu0
UART_115200__D
U-Boot 2011.06-svn19959 (Apr 18 2016 - 13:13:57)
CPU  : AMBER3
Board: BD_MS801_MAA2XG
DRAM:  256 MiB
SPI:  Flash is detected (0x0711, 0xEF, 0x40, 0x15)
MDrv_SERFLASH_GetInfo()
        u32AccessWidth = 1
        u32TotalSize   = 2097152
        u32SecNum      = 32
        u32SecSize     = 65536
spi_init: cfg_env_offset: 0x1e0000, at 552
MMC:   mstar-emmc: 0, 0 blocks
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
read_spi_dbtable success...>>>
read table >>>
logo  offset[0x00180028] size[0x0001c2e1] end[0x0019c309]
music offset[0x0019c309] size[0x00000000] end[0x0019c309]
panel offset[0x0019c309] size[0x0000005c] end[0x0019c365]
ursa  offset[0x0019c365] size[0x00000024] end[0x0019c389]
keypad  offset[0x0019c389] size[0x00005000] end[0x001a1389]
db_checksum =:0x4ea5900e
save db_checksum =:0x4ea5900e
db_table.keypad_offset =:0x19c389...db_table.keypad_size=:0x5000
Read_PanelParaFromSpiflash success...>>>
UART BUS OFF!!_MApi_PM_ProcessPmInit >> MDrv_PM_Init
avlink_init done
power down
enable WDT
HAL_PM_WakeupFromZero
蕡ˇU%鞰e珛弁IST OK...
BIST OK
ALL BIST OK!!
HAL_MIU_INIT2
MDrv_BDMA_Init OK..
bdma start .......
wait done.......
Bdma is done!
run code in dram
Start to reset MIPS
End of MIPS init
bring up MIPS over
UART_115200__D
CPU  : AMBER3
DRAM:  256 MiB
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
        u32AccessWidth = 1
        u32SecNum      = 32
        u32SecSize     = 65536
read table >>>
UART BUS OFF!!
发表于: 2019-2-24 23:42:51
UART BUS OFF!!
发表于: 2019-2-25 09:28:43
没法看,串口总线关闭了的
 楼主| 发表于: 2019-2-25 20:53:18
故障已找到,是EMMC时钟和主芯片连接的贴片电阻性能不良,换了就OK,谢谢
发表于: 2019-2-26 16:06:27
thanks for your post
发表于: 2019-3-22 18:21:02
怎么连接的,我的不显示打印
发表于: 2019-4-11 15:18:40
发表于: 2019-5-8 10:43:00
我也遇到一台确实是一个贴片排阻性能不稳定了
GMT+8, 2024-12-21 14:01 , Processed in 0.062194 sec., 10 queries .
