查看: 2147|回复: 1
创维8S40反复重启 U盘强刷红灯不闪帮忙看看打印信息
发表于: 2018-12-18 18:03:04
001:  当前所选:MAX9668 #ISP,容量:512位,64字节。
002:  >------------------------------------OK---------------------------------------<
003:  切换到快捷面板方式!
004:  C:\Users\Administrator\Desktop\Print.log
005:  COM5, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12,
006:  使用模式A扫描VGA口...
007:  模式A未识别到板卡,变换线序到模式D继续识别...
008:  模式D未识别到板卡,变换线序到模式B继续识别...
009:  MSTAR方案,型号以MST、TSUM、SE、FE开头,程序在外挂SPI存储器里。
010:  当前所选:MST_EXT_SPI #ISP,容量:128M位,16M字节。
011:  http://www.ifix.net.cn/thread-14392-1-8.html
012:  >------------------------------------OK---------------------------------------<
013:  C:\Users\Administrator\Desktop\Print.log
014:  COM5, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12,
UART_115200
AC_ON
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 01200000
[AT][MB][start ub][352]
U-Boot 2011.06-svn1591 (Dec 28 2016 - 09:30:43)  MBOT-1106.0.10.1430095
DRAM_SIZE1=256 MB    DRAM_SIZE2=256 MB    DRAM_SIZE3= MB
msIR_Initialize
[SYS][Utopia]: Function = SYSOpen, Line = 815, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 834, [SYS INFO] OPEN INSTANCE...
create instance at 296EAA48 with private size 108 bytes at 296EAA90
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 296EAB00 with private size 80 bytes at 296EAB48
create instance at 296EABA0 with private size 48 bytes at 296EABE8
uboot held at [294DDF60~2AC00000],size=017220A0
===MBoot_Binary_Release===
CPU  : Messi
Board: BD_MST091B_10ASXG_15281_MESSI
DRAM:  172 MiB
Now running in RAM - U-Boot at: 29D00000
eMMC: HS200 200MHz
eMMC 3.68 GB [75FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0x60: 0x42: 0x7F: 0x25:0xF9: 0xD3
[CPU][Utopia]:
[CPU INFO] cpu opencreate instance at 296FB0B0 with private size 44 bytes at 296FB0F8
[CPU][Utopia]: CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[tu]: ????? ?`???xV4
[AT][MBoot][Driver Init][510]
=wakeup=value==:0
Writing to MMC(0)... 128 blocks written: OK
done
--u8adc0_value = FF
--u8adc1_value = FF
--u8adc2_value = AB
--u8adc3_value = 6B
eeprom read:60:42:7F:25:F93
(hjn)bSelectModelViaProjectID = 1
(hjn)u32ProjectIdAddr = 0x1DFC00
(hjn)u32ProjectIdBackupAddr = 0x1DFE00
(hjn)u8eep_id = 0x7
u32ProjectIdAddr = 0x1DFC00 u32ProjectIdBackupAddr = 0x1DFE00
eep_id = 0x7, u8project_id = 0x7
bFactoryDB_Copy = 0
Changelist:        24543697
ddr MIU0 DDR3 1866
---wya--- do_check_safemode
---wya--- env_safemode =off
---wya--- eep_safemode =0
---wya--- before change eep_safemode =0 , env_safemode=off
AC on
it is AC POWER MODE [0xFF]
Boot Check: BootMode=1 --------
AC on
---zhangfan--- product_state =170
**** do_bootcheck get_boot_mode_from_mtd0 BootMode: 0
**** get_boot_mode_from_env BootMode: 1
**** BootMode: 1
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
[PM][Utopia]: Wait for PM51 standby...........[PM][Utopia]: PM51 run ok........... bPmWakeEnableSAR is TRUE...
UART_115200
AC_ON
BIST0-OK
BIST1-OK
_U
msIR_Initialize
[MIU][Utopia]:
CPU  : Messi
DRAM:  172 MiB
eMMC: HS200 200MHz
In:    serial
Out:   serial
Err:   serial
[CPU][Utopia]:
=wakeup=value==:0
done
--u8adc0_value = FF
--u8adc1_value = FF
--u8adc2_value = AB
--u8adc3_value = 6B
(hjn)u8eep_id = 0x7
bFactoryDB_Copy = 0
ddr MIU0 DDR3 1866
DC on !!
it is DC POWER MODE
force recovery u8adc0_value [0xFF]
force recovery u8adc1_value [0xFF]
key:0xff,mode=EN_BOOT_MODE_UNKNOWN
DC on !!
[AUDIO][Utopia]: MDrv_AUDIO_Init u32PnlRiuBaseAddr = 1F200000
[AUDIO][Utopia]: create Audio SHM data ...[AT][MB][audio_preinit][760]
create instance at 296FB468 with private size 356 bytes at 296FB4B0
[panel/MsDrvPanel.c][MsDrv_PNL_Init][001162]
[panel/MsDrvPanel.c][MsDrv_PNL_Init][001164]
MDrv_PNL_Init u32PnlRiuBaseAddr = tx
MDrv_PNL_Init u32PMRiuBaseAddr = tx
[_MDrv_PNL_Init_LPLL][351]pstPanelInitData->u16Width=1366, pstPanelInitData->u16Height=768
[_MDrv_PNL_Init_LPLL][353]u16HTotal=1560,u16VTotal=806,pstPanelInitData->u16HTotal=1560,pstPanelInitData->u16VTotal=806, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][403]pstPanelInitData->u16Width=1366, pstPanelInitData->u16Height=768
[_MDrv_PNL_Init_Output_Dclk][405]u16HTotal=1560,u16VTotal=806,pstPanelInitData->u16HTotal=1560,pstPanelInitData->u16VTotal=806, u16DefaultVFreq=600
[MApi_XC_MLG_GetStatus, 2057]No instance existed, please get an instance by calling MApi_XC_Init() first
->I-PWM init; ->V-PWM init begin!
init I_PWM_ENABLE = 1
init I_u8PWM_CH = 2
init I_u32PeriodPWM = 200
init I_u32DutyPWM = 50
init I_u16DivPWM = 3
init I_bPolPWM = 1
init I_u16MaxPWMvalue = 499
init I_u16MinPWMvalue = 0
[PWM][Utopia]: Init PWM0init V_PWM_ENABLE = 1
init V_u8PWM_CH = 3
init V_u32PeriodPWM = 200
init V_u32DutyPWM = 178
init V_u16DivPWM = 3
init V_bPolPWM = 1
init V_u16MaxPWMvalue = 499
init V_u16MinPWMvalue = 0
->I-PWM init; ->V-PWM init end!
wxm MApi_PNL_On: u16PanelOnTiming = 30
--panel_name is 07_7_SKY_SD_32_0C_Y480--!!
[AT][MB][panel_pre_init][929]
[PM][Utopia]: Wait for PM51 standby DRAM ...........[PM][Utopia]: PM51 run ok...........---wya--- do_check_safemode
[AT][MB][bootlogo begin][953]
create instance at 29710220 with private size 312 bytes at 29710268
[AT][MB][JPD Decode][990]
[UTOPIA INFO] close moduleNames[tu]: )`????? ?`???xV4
create instance at 29710220 with private size 1720 bytes at 29710268
create instance at 29710928 with private size 9596 bytes at 29710970
<<set_mirror V & H ON!!>>
[AT][MB][Show Logo][1068]
## Booting kernel from Legacy Image at 24D00000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    10142326 Bytes = 9.7 MiB
   Load Address: 20208000
   Entry Point:  20208000
   Contents:
      Image 0: 9817272 Bytes = 9.4 MiB
      Image 1: 325042 Bytes = 317.4 KiB
## Loading init Ramdisk from multi component Legacy Image at 24D00000 ...
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
   Loading Multi-File Image ... OK
---MsDrv_PNL_BackLigth_On:1665 Set MsDrv_PNL_BackLigth_On DelayTask 270
[AT][MB][start kr][1482]
Starting kernel   ...
[    0.000000] SAR5=ON
[    0.000000] SAR5=ON[    0.000000] [AT][KR][reset timer][1565]
[    0.670403] [AT][KR][start init][2235]
[    0.674180] [AutoTest][Kernel][start Initprocess][2235]
             A N D R O I D
root@sky338_8s40:/ # [    5.209588] IR IRQ registartion ERROR
TVOS *checkPoint*
发表于: 2018-12-18 22:23:20
升级主程序
GMT+8, 2024-12-21 15:23 , Processed in 0.056276 sec., 9 queries .
