查看: 1759|回复: 2
创维机芯8S40不开机,打印信息求助
发表于: 2018-12-18 11:58:23
创维机芯8S40不开机,求助打印信息含义  ,信息跑到Starting kernel 《启动内核》停止,请问论坛大佬这个是说明主程序问题吗?另外中间有段提示检测不到信息,求助老师帮忙分析一下!!
no miu_setting information in mmap.ini
[ERROR] syncMmap2bootargs:939: sync LX_MEM fail
[ERROR] do_sync_mmap_to_env:1405: sync the part of mmap info to bootargs fail
Changelist:        24543697
下面是打印信息某某信息
UART_115200
AC_ON
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 01200000
[AT][MB][start ub][341]
U-Boot 2011.06-svn1591 (Dec 28 2016 - 09:30:43)  MBOT-1106.0.10.1430095
DRAM_SIZE1=256 MB    DRAM_SIZE2=256 MB    DRAM_SIZE3= MB
msIR_Initialize
[SYS][Utopia]: Function = SYSOpen, Line = 815, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 834, [SYS INFO] OPEN INSTANCE...
create instance at 296EAA48 with private size 108 bytes at 296EAA90
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 296EAB00 with private size 80 bytes at 296EAB48
create instance at 296EABA0 with private size 48 bytes at 296EABE8
uboot held at [294DDF60~2AC00000],size=017220A0
===MBoot_Binary_Release===
CPU  : Messi
Board: BD_MST091B_10ASXG_15281_MESSI
DRAM:  172 MiB
Now running in RAM - U-Boot at: 29D00000
eMMC: HS200 200MHz
eMMC 3.68 GB [75FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0x60: 0x42: 0x7F: 0x1E:0xB1: 0xA0
mmc change mount : tvconfig
Size of file "/config/sys.ini" from mmc device 0 partition tvconfig: 1904 bytes
Loading file "/config/sys.ini" at offset 0x0 from mmc device 0 partition tvconfig
1904 bytes read
sizeof( sys ini script ) --------> 1904 bytes
Writing to MMC(0)... 128 blocks written: OK
done
done
** File not found 294DD214
[ERROR] prepare_nand_dbtable:777:  get logo_size fail...>>>:0
[ERROR] write_dbtable:869: flash database not ready...>>>
[ERROR] do_dbtable_init:219: dbtable init fail
[CPU][Utopia]:
[CPU INFO] cpu opencreate instance at 296FB0B0 with private size 44 bytes at 296FB0F8
[CPU][Utopia]: CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[tu]: ????? ?`???xV4
[AT][MBoot][Driver Init][649]
=wakeup=value==:0
done
--u8adc0_value = FF
--u8adc1_value = FF
--u8adc2_value = A8
--u8adc3_value = 66
eeprom read:60:42:7F:1E:B1:A0
(hjn)bSelectModelViaProjectID = 0
Size of file "/config/mmap.ini" from mmc device 0 partition tvconfig: 46659 bytes
Loading file "/config/mmap.ini" at offset 0x0 from mmc device 0 partition tvconfig
46659 bytes read
ddr MIU0 DDR3 1866
---wya--- do_check_safemode
---wya--- env_safemode =off
---wya--- eep_safemode =0
---wya--- before change eep_safemode =0 , env_safemode=off
AC on
it is AC POWER MODE [0xFF]
Boot Check: BootMode=2 --------
wxm boot_mode_recovery set Customer_Rest 1
done
0x1
set eep:0x11 copy db flag=0x01 end
[ERROR] raw_read:533: len is zero
[ERROR] Read_PanelParaFromflash:1569: ERROR: Read_PanelParaFromflash fail...>>>
[ERROR] panel_dinit:611: panel_dinit: Read_PanelParaFromflash() failed, at 611
[AT][MB][panel_pre_init][1224]
[ERROR] do_run_time_pm:117: get E_MMAP_ID_PM51_USAGE_MEM_ADR mmap fail
[AT][MB][bootlogo begin][1233]
[ERROR] do_bootlogo:529: Panle is not ready
## Booting kernel from Legacy Image at 24D00000 ...
   Image Name:   MStar-linux(recovery)
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    14189939 Bytes = 13.5 MiB
   Load Address: 20208000
   Entry Point:  20208000
   Contents:
      Image 0: 9775096 Bytes = 9.3 MiB
      Image 1: 4414831 Bytes = 4.2 MiB
## Loading init Ramdisk from multi component Legacy Image at 24D00000 ...
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
   Loading Multi-File Image ... OK
[AT][MB][start kr][1417]
Starting kernel   ...
发表于: 2018-12-18 17:57:13
帮顶我的是反复重启,U盘强刷无反应
发表于: 2020-4-1 20:39:02
你这个没问题吧
GMT+8, 2024-12-22 01:28 , Processed in 0.046792 sec., 9 queries .
