TCL-L40F3301B+40-MS82T0-MAB2HG+LVF399NDDL
打印信息:
SPI BOOT
Console Initial OK
Maria10: BD_MST021B_10ALG_11313_64M
[MIU]: 64MB - DDR2 800MHz
BIST_0 PASS.
77
[123456789ABC][123456789ABC]
0066
MIU Initial OK
--------[FILEtv-ap/dvb/app/MApp_SaveData.c,LINE:819]---Mapp_LoadGenVersion--GEN_VER:AFBA--GEN_FAC: 81FF-------RM_EEPROM_VER_ID:AFBA-------RM_EEPROM_FAC_ID:81FF--
--------FHD----g_ProjectID=37------
sar input test...
panel is********* 17MDrv_PNL_Init u32PnlRiuBaseAddr = A0200000
MDrv_PNL_Init u32PMRiuBaseAddr = A0000000
GE_SetOnePixelMode
set USB port auto switch to 0
Force to set USB port switch to 1
$$$$$DLC cap width=1920, height=1080
@@@@DLC cap hhstart=128, hhEnd=1792
#####DLC cap vvstart=180, vvEnd=945
_COPRO_Init: u32RiuBaseAdd = A0200000
R2 is HK!
=Tuner standby 18273=
#Jeffrey.duan power on panel 1
Disable Aeon
Disable Aeon Done
DSP code loaded successfully
=Tuner Init 18273=
Init pObj->tUnitTDA18273 to 0x 20
tUnit is 0x00000020
err is 0x00000000
tUnit is 0x00000020
Begin to init register
ATVProInitialize
InputSourceType is 3
Set audio standard
=== TUNER Standby ===
easpect is 0$$$$$DLC cap width=1920, height=1080
[effect OPEN]:0
MApp_DB_SaveGenSetting>> g_u16QuickGenSettingIdx = 27
PCMode: Set Mode ok
set CVBS mute4 0
CVBS Mute is 0$$$$$DLC cap width=1920, height=1080
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
CVBS Mute is 0
MApp_DB_SaveGenSetting>> g_u16QuickGenSettingIdx = 28
PCMode: Set Mode ok
set CVBS mute4 0
CVBS Mute is 0[effect OPEN]:0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
PCMode: Set Mode ok
set CVBS mute4 0
CVBS Mute is 0
