查看: 1409|回复: 7
创维9r10一直报错,大家帮忙,谢谢!
发表于: 2018-12-3 16:53:23
[    0.000000] Linux version 3.7.2-MAGELLAN (phoenix@rtkPhoenix) (gcc version 4.4.7 (Realtek ASDK-4.4.7 Build 1348) ) #6 Tue Mar 8 11:16:45 CST 2016
[    0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: Magellan board
[    0.000000] mem=512MB@0x00000000
[    0.000000] mem=512MB@0x40000000
[    0.000000] detected [1]th part(name_len:17 / /system)
[    0.000000] detected [2]th part(name_len:16 / /data)
[    0.000000] detected [3]th part(name_len:16 / /cache)
[    0.000000] detected [4]th part(name_len:17 / /skydir)
[    0.000000] detected [5]th part(name_len:13 / /dtv)
[    0.000000] detected [6]th part(name_len:13 / /res)
[    0.000000] Hit res!
[    0.000000] detected [7]th part(name_len:7 / /skyota)
[    0.000000] bootconsole [earlycon0] enabled
[    0.000000] cma: CMA: reserved 352 MiB at 02000000
[    0.000000] reserve 40000000 - 60000000 for high memory cma...
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] Realtek LINUX started...
[    0.000000]  System CPU has 1 UART.
[    0.000000]  System CPU uses internal timer interrupt.
[    0.000000]  Bootloader version: 0010.0700.0000.
[    0.000000]  Company:0x10  CPU:0x7  Board:0x100700
[    0.000000]  Ethernet Mac address: 1c:a7:70:a0:09:63
[    0.000000]  Base year of RTC is 2013.
[    0.000000] L310 cache controller enabled. run l2x0_inv_all()
[    0.000000] l2x0: 16 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x02050000, Cache size: 524288 B
[    0.000000] *** l2x0_ctrl          = 0x00000001
[    0.000000] *** l2x0_aux_ctrl      = 0x02050000
[    0.000000] *** l2x0_tag_latency   = 0x00000010
[    0.000000] *** l2x0_data_latency  = 0x00000121
[    0.000000] *** l2x0_prefetch_ctrl = 0x04000000
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 249344
[    0.000000] Kernel command line: androidboot.console=ttyS0 console=ttyS0,115200 envp=100700 flashtype=spi mmcparts=rtkemmc:3866624k,524288k(/system),1048576k(/data),262144k(/cache),358400k(/skydir),81920k(/dtv),16384k(/res),768000k(/skyota) earlyprintk
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 22MB 352MB 88MB 512MB = 974MB total
[    0.000000] Memory: 95192k/95192k available, 953384k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff000000   ( 488 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0108000 - 0xc0550778   (4386 kB)
[    0.000000]       .init : 0xc0551000 - 0xc0774000   (2188 kB)
[    0.000000]       .data : 0xc0774000 - 0xc07a2ac0   ( 187 kB)
[    0.000000]        .bss : 0xc07a2ae4 - 0xc07df9dc   ( 244 kB)
[    0.000000] NR_IRQS:256
[    0.000000] machine_desc->init_irq=c0553a0c
[    0.000000] Estimated  CPU  frequency: 999 MHz
[    0.000000] Estimated Timer frequency: 27 MHz
[    0.000000] sched_clock: 32 bits at 27MHz, resolution 37ns, wraps every 159072ms
[    0.000000] console [ttyS0] enabled, bootconsole disabled
[    0.011632] Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
[    0.038410] pid_max: default: 32768 minimum: 301
[    0.043195] Security Framework initialized
[    0.047420] Mount-cache hash table entries: 512
[    0.052395] CPU: Testing write buffer coherency: ok
[    0.057526] enter hw_watchdog!!!    200140
[    0.061756] Setting up static identity map for 0x423568 - 0x4235c0
[    0.068507] devtmpfs: initialized
[    0.072683] release 40000000 - 60000000 for high memory cma...
[    0.078671] cma: CMA: reserved 512 MiB at 40000000
[    0.083582] rtktlb: Hello, Realtek TLB Mapper...
[    0.088887] rtkbp: memmap size: 1081344
[    0.093006]  <<<FREE AREA BASE: 02000000>>>
 楼主| 发表于: 2018-12-3 16:55:11
[    0.097294]  0:      0
[    0.099264]  1:      0
[    0.101234]  2:      0
[    0.103208]  3:      0
[    0.105178]  4:      0
[    0.107148]  5:      0
[    0.109122]  6:      0
[    0.111092]  7:      0
[    0.113062]  8:      1
[    0.115037]          Addr: 10100000, order: 8
[    0.118963]  9:      1
[    0.120938]          Addr: 10200000, order: 9
[    0.124865]  10:     1
[    0.126929]          Addr: 10400000, order: 10
[    0.130949]  11:     1
[    0.133009]          Addr: 10800000, order: 11
[    0.137028]  12:     1
[    0.139088]          Addr: 11000000, order: 12
[    0.143107]  13:     2
[    0.145167]          Addr: 0e000000, order: 13
[    0.149186]          Addr: 16000000, order: 13
[    0.153206]  14:     2
[    0.155266]          Addr: 0a000000, order: 14
[    0.159285]          Addr: 12000000, order: 14
[    0.163305]  15:     1
[    0.165364]          Addr: 02000000, order: 15
[    0.186568] rtkbp: memmap size: 1572864
[    0.190756]  <<<FREE AREA BASE: 40000000>>>
[    0.195046]  0:      0
[    0.197016]  1:      0
[    0.198986]  2:      0
[    0.200962]  3:      0
[    0.202931]  4:      0
[    0.204900]  5:      0
[    0.206875]  6:      0
[    0.208844]  7:      0
[    0.210813]  8:      0
[    0.212787]  9:      0
[    0.214757]  10:     0
[    0.216820]  11:     0
[    0.218879]  12:     0
[    0.220943]  13:     0
[    0.223002]  14:     0
[    0.225065]  15:     4
[    0.227125]          Addr: 40000000, order: 15
[    0.231144]          Addr: 48000000, order: 15
[    0.235164]          Addr: 50000000, order: 15
[    0.239184]          Addr: 58000000, order: 15
[    0.268113] NET: Registered protocol family 16
[    0.272817] +++ ALLOC pfn: 65792 order: 6
[    0.278780] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.287186] Realtek: sysfs init done
[    0.291308] [RTICE]rtice_init...
[    0.303812] bio: create slab <bio-0> at 0
[    0.308607] SCSI subsystem initialized
[    0.312856] usbcore: registered new interface driver usbfs
[    0.318570] usbcore: registered new interface driver hub
[    0.324142] usbcore: registered new device driver usb
[    0.329853] Advanced Linux Sound Architecture Driver Initialized.
[    0.336615] Switching to clocksource RTK_CSRC
[    0.342469] Realtek eMMC Driver Rev:MAGELLAN (2014-07-24 16:30)
[    0.348553] rtkemmc: build at Mar  8 2016 11:12:45
[    0.353467] CONFIG_MMC_BLOCK_BOUNCE enable
[    0.357668] rtkemmc: ##### CONFIG_SMP disable!! #####
[    0.362845] Android timming setting
[    0.366485] rtkemmc: EMMC_SHOUTDOWN_PROTECT  not define
[    0.374391] rtkemmc:cmd240 cmd decode fail
[    0.374391] SD_STAT=0x0000003e INT_STAT=0x00000004 SD_TRANS=0x00000071
[    0.387259] rtkemmc: change to 1bit mode
[    0.421111] mmc0: rtkemmc driver initialized
[    0.432970] Realtek EMMC Controller Driver is successfully installing.
[    0.432970]
[    0.441238] NET: Registered protocol family 2
[    0.445988] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[    0.453277] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.459910] TCP: Hash tables configured (established 4096 bind 4096)
[    0.466467] TCP: reno registered
[    0.469785] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.475775] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.482309] NET: Registered protocol family 1
[    0.486893] RPC: Registered named UNIX socket transport module.
[    0.492965] RPC: Registered udp transport module.
[    0.497788] RPC: Registered tcp transport module.
[    0.502612] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.517453] mmc0: BKOPS_EN bit is not set
[    0.525562] rtkemmc: bus clock change to 33MHz
[    0.535883] rtkemmc: change to 8bits mode
[    0.540108] mmc0: new high speed MMC card at address 0001
[    0.650400] size of RPC_POLL_Dev 52 and RPC_INTR_Dev 52...
[    0.667394] input: venus_IR_input as /devices/virtual/input/input0
[    0.676291] [GDMA]panel_parameter->iCONFIG_PANEL_TYPE=1  *********************
[    0.676291]
[    0.676291]
[    0.676291]
[    0.688239] [GDMA]panel_parameter=inx_in8903_50_4k2k_vby1  *********************
[    0.688239]
[    0.688239]
[    0.688239]
[    0.702872] [GDMA]gdma->iCONFIG_PANEL_TYPE=1  *********************
[    0.702872]
[    0.702872]
[    0.702872]
[    0.713842] [GDMA]gdma->iCONFIG_PANEL_CUSTOM_INDEX=3  *********************
[    0.713842]
[    0.713842]
[    0.713842]
[    0.725520] [GDMA]gdma->ctrl.disp_pixel_mode=0, 0:ONE_PIXEL, 1:TWO_PIXEL, 2:FOUR_PIXEL
[    0.736319] [GPIO] venus_gpio_dev_init successed
[    0.742989] [MCP] Info, mcp device detected ...
[    0.750338] [user land] CmdBuf virt addr = df8ac000/df8ac000, phy addr=1f8ac000
[    0.759084]  ***************** md init module *********************
[    0.765605] md init module major number = 249
[    0.772681] Command Buffer Address = df904000, Physical Address = 1f904000, Size = 00004000
[    0.781258]
[    0.781258]
[    0.781258]
[    0.781258]
[    0.781258]  *****************    se init module  *********************
[    0.781258]
[    0.781258]
[    0.781258]
[    0.798633] se init module major number = 248
[    0.805608] arch/arm/bsp-realtek/mach-rtd299x/se.c, 991 Power trigget = 0
[    0.812577] [linux][CBUS] MHL_init_module
[    0.816701] [linux]CBUS: register sucess!!! IRQ 57
[    0.822261] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.842516] bounce pool size: 64 pages
[    0.847562] NTFS driver 2.1.30 [Flags: R/O].
[    0.851977] msgmni has been set to 889
[    0.856371] io scheduler noop registered
[    0.860407] io scheduler deadline registered
[    0.864796] io scheduler cfq registered (default)
[    0.869629] VenusFB: Framebuffer device driver for Realtek Media Processors
[    0.878553] Ve43] [ETH] RX_OFFSET = 0x0
[    0.989045] eth0: RTL-8139C+ at 0xb8016000, 1c:a7:70:a0:09:63, IRQ 52
[    0.996985] Initializing USB Mass Storage driver...
[    1.003117] cp_hotplug
[    1.005661] usbcore: registered new interface driver usb-storage
[    1.011824] USB Mass Storage support registered.
[    1.017509] mousedev: PS/2 mouse device common for all mice
[    1.026559] mmcblk0: mmc0:0001 004G90 3.68 GiB
[    1.031319] mmcblk0boot0: mmc0:0001 004G90 partition 1 2.00 MiB
[    1.037497] mmcblk0boot1: mmc0:0001 004G90 partition 2 2.00 MiB
[    1.046626] data[0] 0x0 signature[0] 0xbabeface
[    1.051282] data[1] 0x0 signature[1] 0xdeadbeef
[    1.055928]  mmcblk0: p1 p2 p3 p4 < p5 p6 p7 p8 >
[    1.069023] data[0] 0xffffffff signature[0] 0xbabeface
[    1.074305] data[1] 0xffffffff signature[1] 0xdeadbeef
[    1.079577]  mmcblk0boot1: unknown partition table
[    1.086998] data[0] 0xffffffff signature[0] 0xbabeface
[    1.092279] data[1] 0xffffffff signature[1] 0xdeadbeef
[    1.097550]  mmcblk0boot0: unknown partition table
[    1.103859] Realtek Card-Reader Driver Rev:MAGELLAN (2014-04-02 22:50)
[    1.110564] CR_BASE_ADDR:0xb8010c00
[    1.114144] rtksdio: ##### CONFIG_SMP disable!! #####
[    1.119325] rtksdio: ##### CONFIG_MMC_BLOCK_BOUNCE enable!! #####
[    1.125578] rtksdio: ##### CONFIG_SD_PCMCIA_PADLOCK disable!! #####
[    1.132001] rtksdio: check Power Pin.
[    1.135759] rtksdio: ### CONFIG_REALTEK_PCBMGR alert !!! ###
[    1.141614] PIN_CI_CA_PWR_EN got.(0x10103)
[    1.145815]          have not PIN_CI_CA_PWR_EN parameter,
[    1.145815]          use DEMO board setting(GPIO1).
[    1.156331] rtksdio: power pin is GPIO1
[    1.160267] divisor:0; remainder:1
[    1.163756] rtksdio: Android timming setting
[    1.173104] rtksdio: bus clock change to 16MHz
[    1.209111] mmc1: rtksdio driver initialized
[    1.217706] Realtek Card-Reader Controller Driver is successfully installing.
[    1.217706]
[    1.229056] usbcore: registered new interface driver usbhid
[    1.234783] usbhid: USB HID core driver
[    1.239408] ashmem: initialized
[    1.246890] TCP: cubic registered
[    1.250310] NET: Registered protocol family 17
[    1.254968] Realtek Magellan Power Management 2013/05/06 11:30
[    1.254968] (c) 2013 Realtek Semiconductor Corp.
[    1.265669] avcpu: audio & video cpu driver for Realtek Media Processors
[    1.276164] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 3
[    1.284059] ThumbEE CPU extension supported.
[    1.288450] Registering SWP/SWPB emulation handler
[    1.300925] ALSA device list:
[    1.303982]   #0: Mars 1
[    1.306680] devtmpfs: mounted
[    1.311429] Freeing init memory: 2188K
[    1.315281] Enter rtk_post_processing(respart:7)
[    1.324307] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[    1.332622] mount res partition(7) done!
[    1.344219] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
 楼主| 发表于: 2018-12-3 16:58:12
BusyBox v1.18.4 (2016-03-08 11:14:28 CST) built-in shell (ash)
Enter 'help' for a list of bui[    1.516263] #@# usb3_phy_setting(132) +++ 20130826
lt-in commands.
/ # [    1.768653] #@# usb3_phy_setting(233) ---
[    1.772862] #@# usb2_phy_setting(239) +++ 20130823-1
[    3.050454] #@# usb2_phy_setting(339) ---
[    3.054655] #@# usb3_mac_setting(347) +++ 20130916
[    3.059572] #@# usb3_mac_setting(452) ---
[    3.063783] xhci-hcd xhci-hcd: xHCI Host Controller
[    3.068806] xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 1
[    3.076074] +++ ALLOC pfn: 65856 order: 0
BUS_TYPE = (null)[    3.081099] [sched_delayed] sched: RT throttling activated
Hotplug: device "ram0" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram1" is skipped.
BUS[    3.093616] +++ ALLOC pfn: 65857 order: 0
_TYPE = (null)
Hotplug: device [    3.100436] +++ ALLOC pfn: 65858 order: 0
"ram2" is skipped.
BUS_TYPE = ([    3.107502] +++ ALLOC pfn: 65859 order: 0
null)
Hotplug: device "ram3" is[    3.114509] +++ ALLOC pfn: 65860 order: 0
skipped.
BUS_TYPE = (null)
Ho[    3.121553] +++ ALLOC pfn: 65861 order: 0
tplug: device "ram5" is skipped.[    3.128625] xhci-hcd xhci-hcd: irq 53, io mem 0xfe050000
BUS_TYPE = (null)
Hotplug: de[    3.138461] hub 1-0:1.0: USB hub found
vice "ram6" is skipped.
BUS_TYP[    3.143552] hub 1-0:1.0: 4 ports detected
E = (null)
Hotplug: device "ram[    3.150563] #@# xhci_hub_control(846) wIndex 0x0 0x2a0
[    3.158584] #@# xhci_hub_control(863) wIndex 0x0 0x2a0
[    3.163844] #@# xhci_hub_control(873) wIndex 0x0 0x2a0
[    3.169104] #@# xhci_hub_control(884) wIndex 0x0 0x2a0
7" is skipped.
BUS_TYPE = (null[    3.174396] #@# xhci_hub_control(846) wIndex 0x1 0x2a0
[    3.182479] #@# xhci_hub_control(863) wIndex 0x1 0x2a0
[    3.187739] #@# xhci_hub_control(873) wIndex 0x1 0x2a0
[    3.192998] #@# xhci_hub_control(884) wIndex 0x1 0x2a0
Hotplug: device "ram8" is ski[    3.198287] #@# xhci_hub_control(846) wIndex 0x2 0x2a0
[    3.206370] #@# xhci_hub_control(863) wIndex 0x2 0x2a0
[    3.211630] #@# xhci_hub_control(873) wIndex 0x2 0x2a0
[    3.216889] #@# xhci_hub_control(884) wIndex 0x2 0x2a0
pped.
BUS_TYPE = (null)
Hotplu[    3.222177] #@# xhci_hub_control(846) wIndex 0x3 0x2a0
[    3.230260] #@# xhci_hub_control(863) wIndex 0x3 0x2a0
[    3.235521] #@# xhci_hub_control(873) wIndex 0x3 0x2a0
[    3.240781] #@# xhci_hub_control(884) wIndex 0x3 0x2a0
g: device "ram9" is skipped.
BU[    3.246156] xhci-hcd xhci-hcd: xHCI Host Controller
S_TYPE = (null)
Hotplug: device[    3.253922] xhci-hcd xhci-hcd: new USB bus registered, assigned bus number 2
"loop0" is skipped.
BUS_TYPE =[    3.266076] hub 2-0:1.0: USB hub found
(null)
Hotplug: device "loop1"[    3.270686] hub 2-0:1.0: 1 port detected
is skipped.
[    3.277571] #@# xhci_hub_control(846) wIndex 0x0 0x80
[    3.285542] #@# xhci_hub_control(863) wIndex 0x0 0x80
[    3.290714] #@# xhci_hub_control(873) wIndex 0x0 0x80
[    3.295884] #@# xhci_hub_control(884) wIndex 0x0 0x80
Hotplug: device "loop2" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop3" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop4" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop5" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop6" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop7" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram10" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram11" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram12" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram13" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram14" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram15" is skipped.
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
BUS_TYPE = (null)
Hotplug: device "ram4" is skipped.
[main:3091]: Starting LoaderM......
argc = 2
argv = /sbin/factory load
0+1 records in
0+1 records out
227 bytes (227B) copied, 0.000118 seconds, 1.8MB/s
command:dd if=/sys/realtek_boards/system_parameters of=/tmp/str.txt, (line=205) [file=src/rtk_common.cpp], ret(0)
command:mkdir -p /tmp/factory, (line=259) [file=src/rtk_factory.cpp], ret(0)
tmp/factory/
tmp/factory/bin_panel/
tmp/factory/bin_panel/panel/
tmp/factory/bin_panel/panel/inx_in8903_40_4k2k_vby1_panel.bin
tmp/factory/bin_panel/panel/sky_v420dk1_panel.bin
tmp/factory/bin_panel/panel/China_Star_4K2K_VBY1_panel.bin
tmp/factory/bin_panel/panel/sky_rdl420_LDF_panel.bin
tmp/factory/bin_panel/panel/inx_in8903_4k2k_vby1_panel.bin
tmp/factory/bin_panel/panel/inx_in8903_42_4k2k_vby1_panel.bin
tmp/factory/bin_panel/panel/inx_in8903_50_4k2k_vby1_panel.bin
tmp/factory/bin_panel/panel/benq_e220hd_panel.bin
tmp/factory/bin_panel/panel/inx_in8901_50_4k2k_vby1_panel.bin
tmp/factory/bin_panel/panel/CMI_4K2K_60_VBY1_panel.bin
tmp/factory/bin_panel/panel/sky_v500dk2_panel.bin
tmp/factory/bin_panel/panel/sky_sdl550_panel.bin
tmp/factory/bin_panel/panel/inx_in8903_58_4k2k_vby1_panel.bin
tmp/factory/bin_panel/panel/sky_sdl470_panel.bin
tmp/factory/bin_panel/panel/inx_in8922_65_4k2k_vby1_panel.bin
tmp/factory/bin_panel/panel/lg_49_4k2k_vby1_panel.bin
tmp/factory/bin_panel/panel/lg_42_4k2k_vby1_panel.bin
tmp/factory/bin_panel/PanelParam/
tmp/factory/bin_panel/PanelParam/vip_inx_in8903_40_4k2k_vby1.bin
tmp/factory/bin_panel/PanelParam/vip_inx_in8903_42_4k2k_vby1.bin
tmp/factory/bin_panel/PanelParam/vip_inx_in8903_50[    3.523955] EXT4-fs (mmcblk0p8): recovery complete
_4k2k_vby1.bin
tmp/factory/bin_[    3.530720] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: (null)
panel/PanelParam/vip_default.bin
tmp/factory/bin_panel/PanelParam/vip_lg_55_4k2k_vby1.bin
tmp/factory/bin_panel/PanelParam/vip_inx_in8903_4k2k_vby1.bin
tmp/f[    3.554068] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
actory/bin_panel/PanelParam/vip_benq_e220hd.bin
tmp/factory/bin_panel/PanelParam/vip_inx_in8903_58_4k2k_vby1.bin
tmp/factory/bin_panel/PanelParam/vip_lg_49_4k2k_vby1.bin
tmp/factory/bin_panel/PanelParam/vip_China_Star_4K2K_VBY1.bin
tmp/factory/bin_panel/PanelParam/vip_inx_in8901_50_4k2k_vby1.bin
tmp/factory/bin_panel/PanelParam/vip_lg_42_4k2k_vby1.bin
tmp/factory/bin_panel/PanelParam/vip_inx_in8922_65_4k2k_vby1.bin
tmp/factory/bin_panel/panel.bin
tmp/factory/bin_panel/000BootParam.h
tmp/factory/recovery
tmp/factory/env.txt
5576+0 records in
5576+0 records out
2854912 bytes (2.7MB) copied, 0.181863 seconds, 15.0MB/s
tmp/factory/layout.txt
command:cd /;dd if=/dev/block/mmcblk0 bs=512 count=5576 skip=49152 | /bin/busybox tar xv, (line=388) [file=src/rtk_factory.cpp], ret(0)
skipping malformed layout.txt line: #define CREATE_DATE " Oct 24 2013 "
skipping malformed layout.txt line: #define CREATE_TIME " 10:59:44 "
skipping malformed layout.txt line: #define BOOTTYPE " BOOTTYPE_COMPLETE "
skipping malformed layout.txt line: #define SSUWORKPART 0
skipping malformed layout.txt line: #define BOOTPART 0
skipping malformed layout.txt line: #define FW_KERNEL " target=108000 offset=2008000 size=a3e0c4 type=(null) "
skipping malformed layout.txt line: #define FW_AKERNEL " target=81700000 offset=2a46200 size=1b9460 type=(null) "
skipping malformed layout.txt line: #define FW_VKERNEL " target=81a00000 offset=2bff800 size=2baf10 type=(null) "
skipping malformed layout.txt line: #define FW_VKERNEL2 " target=81d00000 offset=2eba800 size=b2884 type=(null) "
skipping malformed layout.txt line: #define FW_ECPU " target=4000 offset=2f6d200 size=1f80 type=(null) "
 楼主| 发表于: 2018-12-3 17:00:35
skipping malformed layout.txt line: #define FW_DVLOGO " target=deaddead offset=2f6f200 size=1b2dc type=bin "
         (device:/dev/block/mmcblk0p3, mount_point:/cache, fs:ext4, size:268435456)
         (device:/dev/block/mmcblk0p8, mount_point:/skyota, fs:ext4, size:786432000)
         (device:/dev/block/mmcblk0p1, mount_point:/system, fs:ext4, size:536870912)
         (device:/dev/block/mmcblk0p2, mount_point:/data, fs:ext4, size:1073741824)
         (device:/dev/block/mmcblk0p5, mount_point:/skydir, fs:ext4, size:367001600)
         (device:/dev/block/mmcblk0p6, mount_point:/dtv, fs:ext4, size:83886080)
         (device:/dev/block/mmcblk0p7, mount_point:/res, fs:ext4, size:16777216)
skipping malformed layout.txt line: #define TAG 21
  0 /cache ext4 /dev/block/mmcblk0p3 (null) 0 268435456
  1 /skyota ext4 /dev/block/mmcblk0p8 (null) 0 786432000
  2 /system ext4 /dev/block/mmcblk0p1 (null) 0 536870912
  3 /data ext4 /dev/block/mmcblk0p2 (null) 0 1073741824
  4 /skydir ext4 /dev/block/mmcblk0p5 (null) 0 367001600
  5 /dtv ext4 /dev/block/mmcblk0p6 (null) 0 83886080
  6 /res ext4 /dev/block/mmcblk0p7 (null) 0 16777216
alive!
MSG_TYPE[1] {eth0 UP}
alive!
MSG_TYPE[1] {lo UP}
alive!
mount: mounting /dev/block/mmcblk0p7 on /res failed: Device or resource busy
mount /res ok
[loadExternalLink:2448]: mount_dev:sdcard @ point /mnt/usb/sdcard
[loadExternalLink:2448]: mount_dev:udisk @ point /mnt/usb
[ExamineCmd:2653]: get command:recovery
--update_package=/skyota/9R10_E690U_V017.009.010_9.zip
[ExamineCmd:2672]: Get command Path: /skyota/9R10_E690U_V017.009.010_9.zip (37)
[ExamineCmd:2678]: Get File Name: 9R10_E690U_V017.009.010_9.zip
[ExamineCmd:2690]: do mount -t ext4 /dev/block/mmcblk0p8 /skyota
[ExamineCmd:2741]: redirectCmdPath:/skyota/9R10_E690U_V017.009.010_9.zip (len:37)
[checkIfZipBeOTAImg:2610]: Can't open cmd file:/skyota/9R10_E690U_V017.009.010_9.zip (No such file or directory)
phase1 doesn't detect ota img!!!
[main:3154]: get bootable cmd in factory
[main:3200]: ======  Checking mount cmd:mount -t ext4 /dev/block/mmcblk0p3 /cache ======
[main:3254]: ======  Checking umount cmd:umount /cache ======
[main:3272]: Enter installer mode, we won't erase BCB first (install.zip) to let installer erase, but restore
argc = 2
argv = /sbin/factory save
0+1 records in
0+1 records out
227 bytes (227B) copied, 0.000112 seconds, 1.9MB/s
tar: removing leading '/' from member names
tmp/factory/
tmp/factory/env.txt
tmp/factory/bin_panel/PanelParam/vip_benq_e220hd.bin
tmp/factory/bin_panel/[    4.005305] eth0: link down
tmp/factory/bin_panel/PanelParam/vip_default.bin
tmp/factory/bin_panel/PanelParam/vip_inx_in8903_50_4k2k_vby1.bin
command:/bin/busybox tar cvf /tmp/factory.tar /tmp/factory, (line=524) [file=src/rtk_factory.cpp], ret(0)
ret = 512
ret = 512
5577+0 records in
5577+0 records out
2855424 bytes (2.7MB) copied, 0.259143 seconds, 10.5MB/s
command:dd if=/tmp/factory.tar of=/dev/block/mmcblk0 bs=512 count=5577 seek=57344 conv=notrunc,sync, (line=556) [file=src/rtk_factory.cpp], ret(0)
command:rm /tmp/factory.tar, (line=564) [file=src/rtk_factory.cpp], ret(0)
[main:3290]: /sbin/factory save
[main:3297]: [loader_m.c][main][3297]Do some prepare work
[main:3303]: [loader_m.c][main][3303]Done some prepare work
[main:3341]:
>>>>>> loader start! (Mar  8 2016:11:15:15, version=00.01.01)
[main:3345]: do ln -s /mnt/sdcard/mmcblk1p1 /mnt/udisk/ssdcard
[JH] checksignatue(), open(/dev/mtdblock/0) nand_boot_size(0xc00000) factory_size(0x400000)
no IMG_XXXX signature found
[loader_m.c][verona_load_func][1642]Debug USB Install(path:/mnt/udisk/ssdcard)
发表于: 2018-12-3 17:58:18
完全看不懂,强刷看看。
发表于: 2018-12-3 18:19:00
Thank you for your post
发表于: 2018-12-3 19:59:31
都大神改数据
GMT+8, 2024-12-21 14:50 , Processed in 0.061366 sec., 10 queries .
