查看: 2095|回复: 4
创维42e60hr-5800-A8R800-0030-倍频板5800-H8R800-001-LC420EUD(SC)(A1)
发表于: 2018-12-1 13:58:39
打印信息
2018-12-1, 11:32:6
COM6, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809F:
Usb_Hcd_RBus_Probe [INFO] : before setting RTD_USB_EHCI_INSNREG01 =  0x01000040
Usb_Hcd_RBus_Probe [INFO] : before setting RTD_USB_EHCI_INSNREG03 =  0x00000001
Usb_Hcd_RBus_Probe [INFO] : after setting RTD_USB_EHCI_INSNREG01 =  0x01000040
Usb_Hcd_RBus_Probe [INFO] : after setting RTD_USB_EHCI_INSNREG03 =  0x00000001
hub : no power switching (usb 1.0)
hub : global over-current protection
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
ROSTaskCreate Rtd_USB_Host_Task(5) OK!!
ROSTaskCreate Rtd_USB_Host_RH_Timer_Task(4) OK!!
APP task
APP Init  0x00008000
============ Mem Manage Init ==============
Mem Manage StartAddr : 0xa18e9c00, Size:7431168
fun=Ds_OsdMgr_Malloc_Init line=109
fun=Ds_PixData_Malloc_Init line=80
fun=Ds_Palette_Malloc_Init line=34
&&& power on stBakSleepTimeData= 0x00000000
Enter Idle Task
fff
zzz
0x00000000_M= 0x00000003
0x00000002_M= 0x00000003
drvif_audio_set_source(14)
set std [ 0x00000000  0x0000001f ]
mute num = 0x00000001,
0x00000006_M= 0x00000003
mute num = 0x00000000,
uM= 0x00000001
uM= 0x00000002
vol2 = -12 vol1 = -44
j = 544 , k = 24 , int_vol = -21333
finial_int_vol = -21250
2 volume = -21, fraction = -250
CAudioEnableMpgDec 1  0x80994a24
set eos 0 current status 0
output buffer size is  0x00002000
RCV DECODE CMD IS DECODE MPEG
set dma
reset  dma  0x00000000
APP wait change status 2
current state  0x00000002
APP change   0x00000002 finish
set decode play
mpg c s  0x00000001
mpg c s delay
mpg update status  0x00000001
frame start
frame start
frame start
STREAM TYPE IS MPEG1_LAYER_3
start dma  0x00000000  0x00001f80
R  0x00000000 W  0x00001f80
a=29 c=11 d=1 e=1
mpg c s  0x00000001 ok
set eos 1 current status 1
eos
CAudioEnableMpgDec 0  0x00000000
set eos 0 current status 1
APP wait change status 0
current state  0x00000000
APP change   0x00000000 finish
==Customer_PowerOn==boot source 1>>>
[fw_control_force_bg] disp=0, Enable=1
type =2
EEStorageSyncPartial 0 1
type =2
GPIO_HDMI0_HOT_PLUG 1
GPIO_HDMI1_HOT_PLUG 1
get stMagicPicInfo.magic_picture =1,
drvif_audio_set_source(15)
type =2
Release VDC Memory !
vdc srcobj index= 0x00000000
vdc call back function addr: 0x801a6cbc
Initial State: disp =  0x00000000,  src: 0x00000003
type =2
appcb_set_input_src_mux=3==6=
[Audio] Set Audio Path:  0x00000003
drvif_audio_set_source(7)
VDC get addr =  0x81587800, _SDRAM_3D_COM_USE =  0x00362360
VDC set addr =  0x002b0f00
memory set done =  0x0031d36b
video reset done
[Y_path]  0x0000000c, [Y_Gnd_path]  0x00000000
[ver.C and latter]
CAVSVInitial done!!
[address debug]  0x800f0ad0  0x800f0db0  0x800f0dcc
---ucOSDState= 0x00000000---  msg =  0x00000127
---ucOSDState= 0x00000000---  msg =  0x00000105
fun=COsdFxCloseAll
--- main state is not factorymenu state
=COsdCoreSourceInfoEventProc= (message= 0x000000f2)
COsdCtrlGetAgingMode==0
OsdMgrAPI_SetScaleOn
[OSD] ==Create Section 2==
display=0,SourceType=3
fun=COsdCtrlShowOtherSource display=0
inputsource type = 3>>>>>>
fun=COsdCtrlShowNoSignal display=0
SendCmd:[ 0x00000055 0x000000cf 0x00000000 0x00000000 0x00000024]>>>>>>>>>
SendCmd:state = 0>>>>>>>>>>
==DMP_Handler==valid = 0>>>>>>>>>>>
SBUF = 0x00000055
SBUF = 0x000000d4
SBUF = 0x00000000
SBUF = 0x0000001a
SBUF = 0x00000043
==scaler_uart_PVR_handler==Active state machine.
SBUF = 0x00000055
SBUF = 0x000000d6
SBUF = 0x0000009a
SBUF = 0x000000f0
SBUF = 0x000000b5
SBUF = 0x00000055
SBUF = 0x000000d8
SBUF = 0x000000ed
SBUF = 0x00000013
SBUF = 0x0000002d
==DMP_Handler==valid = 15>>>>>>>>>>>
GetCmd:[ 0x00000055 0x000000d4 0x00000000 0x0000001a 0x00000043]>>>>>>>>>
#####modestate_no_signal_event
type =2
nosig---ucOSDState= 0x00000019---  msg =  0x0000012c
nal_start_tick = 9
==DMP_Handler==valid = 10>>>>>>>>>>>
GetCmd:[ 0x00000055 0x000000d6 0x0000009a 0x000000f0 0x000000b5]>>>>>>>>>
==DMP_Handler==valid = 5>>>>>>>>>>>
GetCmd:[ 0x00000055 0x000000d8 0x000000ed 0x00000013 0x0000002d]>>>>>>>>>
SendC
SBUF = 0x00000055
SBUF = 0x000000ca
SBUF = 0x00000000
SBUF = 0x00000000
SBUF = 0x0000001f
GetCmd:[ 0x00000055 0x000000ca 0x00000000 0x00000000 0x0000001f]>>>>>>>>>
Display info ack>>>>
push download task message, load tast=0>>>>
---ucOSDState= 0x00000019---  msg =  0x00000147
=COsdCoreSourceInfoEventProc= (message= 0x00000147)
=COsdFxExitEvent=
---ucOSDState= 0x00000019---  msg =  0x0000013c
=COsdCoreSourceInfoEventProc= (message= 0x0000013c)
fun=COsdFxCloseAll
---ucOSDState= 0x00000000---  msg =  0x00000125
SBUF = 0x00000055
SBUF = 0x000000c9
SBUF = 0x00000000
SBUF = 0x00000000
SBUF = 0x0000001e
GetCmd:[ 0x00000055 0x000000c9 0x00000000 0x00000000 0x0000001e]>>>>>>>>>
start complete>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
---ucOSDState= 0x00000000---  msg =  0x0000014b
SBUF = 0x00000055
SBUF = 0x000000c6
SBUF = 0x00000000
SBUF = 0x00000000
SBUF = 0x0000001b
GetCmd:[ 0x00000055 0x000000c6 0x00000000 0x00000000 0x0000001b]>>>>>>>>>
---ucOSDState= 0x00000000---  msg =  0x0000012c
got COsdCoreNoSignalEventProc msg=300, 0x0000012c, 0x00000135
fun=COsdFxCloseAll
[OSD] ==Create Section 5==
Test PowerOff  _FL2UI_MAIN_NO_SIGNAL !!!!!!!!!!
======COsdCoreNoSignalCheckEvent=====
=COsdFxExitEvent=
---ucOSDState= 0x0000001b---  msg =  0x0000013c
got COsdCoreNoSignalEventProc msg=316, 0x0000013c, 0x00000135
AcPowerOnOneMinDmpPowerOff  0x00000001
GET_FACMODESWITCH()=0,
COsdNoSignal_SleepCountDownEvent (ucNoSignalTimeMin= 0x00000005)
发表于: 2018-12-1 15:37:22
感谢楼主分享
发表于: 2018-12-1 22:46:13
Thank you really for your program data sharing.
发表于: 2020-5-29 09:52:30
感谢分享
发表于: 2023-9-11 08:37:20
GFHDFDFGBFDXG SDFXSZDFSZFZS
GMT+8, 2024-12-23 13:53 , Processed in 0.053901 sec., 9 queries .
