查看: 1625|回复: 2
创维不开机求助
发表于: 2018-11-27 15:08:15
前两天接一台创维机器,8S72机芯,灯亮不开机,通电查看打印发现显示emmc die,EMMC死了吗???我以为是emmc问题,供电3.3,阻值和对地压降也测了,然后就不知道咱办了,麻烦师傅们帮我看看,谢谢!附:
UART_115200
AC_ON
MIU0_DQS-OK
MIU1_DQS-OK
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 01200000
[AT][MB][start ub][280]
U-Boot 2011.06-00000-gcb48563-dirty (Dec 12 2016 - 13:30:15)
Function = SYSOpen, Line = 810, current resource pri_shm content is: 0
Function = SYSOpen, Line = 829, [SYS INFO] OPEN INSTANCE...
create instance at 345aa858 with private size 108 bytes at 345aa8a0
[MIU INFO] miu opencreate instance at 345aa910 with private size 80 bytes at 345aa958
create instance at 345aa9b0 with private size 48 bytes at 345aa9f8
uboot held at [342ddf60~36200000],size=01f220a0
===MBoot_Binary_Release===
CPU  : Muji
Board: BD_MST072B_20AEV_MUJI_CUS36
DRAM:  354 MiB
Now running in RAM - U-Boot at: 35300000
FCIE_MODE_GPIO_PAD_DEFO_SPEED
FCIE_MODE_8BITS_MACRO_HIGH_SPEED
FCIE_MODE_32BITS_MACRO_HS400_DS
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0xfc: 0xa3: 0x86: 0xd0:0x22: 0xa1
[CPU INFO] cpu opencreate instance at 345baeb8 with private size 44 bytes at 345baf00
[UTOPIA INFO] close moduleNames[38]: MODULE_CPU
msIR_Initialize
[AT][MBoot][Driver Init][442]
=wakeup=value==:0
Writing to MMC(0)... [ eMMC_CMD25_MIU() ] eMMC WARN: CMD25 Reg.12: FF08h, Err: 0h, Retry: 1, Arg: 3700h
eMMC Warn: slow clk to 200.0MHz, 90h
[ eMMC_CMD25_MIU() ] eMMC WARN: CMD25 Reg.12: FF08h, Err: 0h, Retry: 2, Arg: 3700h
[ eMMC_CMD25_MIU() ] eMMC WARN: CMD25 Reg.12: FF08h, Err: 0h, Retry: 3, Arg: 3700h
eMMC Warn: slow clk to 50.0MHz, 90h
[ eMMC_CMD25_MIU() ] eMMC WARN: CMD25 Reg.12: FF08h, Err: 0h, Retry: 4, Arg: 3700h
[ eMMC_CMD25_MIU() ] eMMC WARN: CMD25 Reg.12: FF08h, Err: 0h, Retry: 5, Arg: 3700h
[ eMMC_CMD25_MIU() ] eMMC Err: CMD25 Reg.12: FF08h, Err: 80000A16h, Retry: 5, Arg: 3700h
[ eMMC_CheckR1Error() ] eMMC Err: eMMC_ST_ERR_R1_23_16
  0x35CE30D4: 0Dh 00h 40h 09h 00h 00h 00h 00h 00h 00h 00h 00h 00h 00h 00h 00h  | ..@.............
[ eMMC_CMD13() ] eMMC: CMD13 check R1 error: 80000A05h, should not retry
[ eMMC_Dump_eMMCStatus() ] eMMC St: 0h 40h 9h 0h
[ eMMC_DumpDriverStatus() ]
  eMMCDrvExtFlag: 0h
eMMC Status: 2014/03/25
  MIU Mode
  Polling Mode
  FCIE Byte Mode
  SDR Mode
  FCIE Clk: 50.0 MHz, 90h
  8-bits width
  Bus Speed: HIGH
  PwrOff Notification: OFF
[pad setting]: FCIE_MODE_8BITS_MACRO_HIGH_SPEED
FCIE_BOOT_CONFIG = 0003h
FCIE_SD_MODE = 0004h (check data sync)
reg_ckg_fcie = 006Ch
fcie reg:
00h:| 0002h 0000h 0000h AED0h 145Bh 0000h 0001h 0001h
08h:| 0080h 0200h 0505h 0004h 0006h FF00h 0003h 0080h
10h:| 0003h 0000h 0000h 0000h 0000h 0000h 03FFh 0000h
18h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
20h:| 000Dh 0940h 0000h 0000h 0000h 0000h 0000h 0000h
28h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
30h:| 0000h 0000h 0000h 0000h FFFFh 0008h 0000h 0001h
38h:| 0000h 1000h 0000h 0000h 0000h 0000h 0001h 0001h
chiptop reg:
00h:| 0000h 0000h 1000h 003Fh 0000h 0000h 07FFh 0000h
08h:| 0000h FFFFh FFFFh 0003h 0FF0h FFFFh 07FFh DAFFh
10h:| 71C0h 7707h 0000h 0200h 0777h C000h 0000h 0000h
18h:| 0000h 000Fh 0000h 0000h 0000h 0010h 0000h 0000h
20h:| 0000h 0800h 0040h 0000h 0000h 0000h 0000h 0000h
30h:| 0000h 0000h 0000h 0000h FFFFh 0FFFh 07FFh 07FFh
38h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
40h:| 0001h 0000h 3F00h 001Fh 000Ch 0000h 0000h 0000h
48h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
50h:| 0000h 0000h 0000h 0654h 0000h 0000h 0000h 00D0h
58h:| 1556h 0000h 0010h 0000h 0000h FFFFh 0000h 0000h
60h:| 7E00h 0000h 0000h 0000h 00E4h 003Ah 07FFh 0000h
68h:| 0000h 0080h 0000h 0000h 0000h 0000h 0040h 0000h
70h:| 0000h 6008h 0080h 45A9h 45A9h 0000h 0000h 0000h
78h:| 0000h 0000h 0000h 0000h 0000h 0000h 9FF7h 0010h
emmc_pll reg:
00h:| 8000h 7F72h 0000h 0050h 0006h 0001h 0000h 0000h
08h:| 0000h 0030h 0000h 0000h 0000h 0000h 0000h 0000h
10h:| 6000h 0000h 0000h 0000h 8000h 0000h 0000h 0000h
18h:| 03D8h 0024h 0005h 0000h 0200h 0000h 0200h 0004h
20h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
30h:| 3178h 0032h F200h 8093h 0093h 0000h 3014h 0000h
40h:| 4000h 1000h 0001h 0000h 0000h 0000h 0000h 0000h
50h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
58h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
60h:| 0000h 0111h 0001h 0000h 0000h 0000h 0000h 0000h
68h:| 0001h 0000h 0000h 0000h 0002h 0000h 0000h 0003h
70h:| 00F3h FFFFh 00FFh FFFFh 80FFh 0000h 0000h 0000h
78h:| 3000h 0000h 0000h 0500h 00FFh 55AAh 0200h 0020h
clkgen reg:
00h:| 0000h 0007h 0000h 0000h 0000h 0000h 0000h 0000h
08h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
10h:| 0001h 0000h 0000h 0C00h 0C0Ch 0000h 0044h 0124h
18h:| 0900h 0000h 0000h 0000h 0000h 0808h 0002h 0000h
20h:| 0100h 0111h 0101h 0101h 0101h 000Dh 0101h 1D01h
28h:| 1D1Dh 011Dh 001Ch 0111h 0000h 0000h 0000h 0000h
30h:| 0101h 010Dh 0011h 0101h 0101h 0101h 0000h 0000h
38h:| 0000h 0101h 0100h 0101h 0101h 0000h 0001h 1111h
40h:| 0101h 0101h 0001h 0101h 1111h 0011h 0000h 0000h
48h:| 0001h 0000h 0000h 0000h 0101h 0101h 0101h 0011h
50h:| 0000h 0000h 0000h 0000h 2020h 0020h 0101h 0000h
58h:| 0000h 0020h 0000h 0000h 0000h 0100h 0000h 0000h
60h:| 0000h 0000h 0000h 0000h 006Ch 0000h 0000h 0000h
68h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
70h:| 0000h 0000h 0000h 0000h 0000h 0000h 0000h 0000h
78h:| 0000h 0000h 0000h 0000h 0000h 0000h 0001h 0000h
[ eMMC_FCIE_DumpDebugBus() ]
0x15 = 2h, 0x38 = 0h, 0x39 = 1500h
0x15 = 4h, 0x38 = 0h, 0x39 = 1500h
0x15 = 6h, 0x38 = 0h, 0x39 = 1500h
0x15 = 8h, 0x38 = 0h, 0x39 = 1500h
CMD state:  000000h
FIFO status:  000000h
ADMA Address:  000000h
ADMA blk cnt:  000000h
eMMC die eMMC_FCIE_ErrHandler_Stop() Ln: 262
发表于: 2018-11-27 19:27:14
Thank you for your posting.
GMT+8, 2024-11-28 08:31 , Processed in 0.053833 sec., 10 queries .
