查看: 7304|回复: 27
实战案例:TCL T968方案维修一例
发表于: 2018-10-26 15:48:33
故障现象:开机出现LOGO,随后卡在正在配置系统界面。
打印信息如下:
GXTVBB:BL1:ee57c+:7a1241;FEAT:EDFD718COC:3;RCY:0;EMMC:0;READ:0;CHK:0;
no sdio debug board detected
TE: 138364
BL2 Built : 16:14:20, Sep 30 2016.
gxtvbb gfdb57f2 - xiaobo.gu@droid05
set vcck to 1100 mv
set vddee to 1100 mv
init panel power
Board ID = 1
CPU clk: 1536MHz
CLK81: 167MHz
HHI_MPLL_CNTL: 0xc00006fa
DDR channel: DDR0+1 two channel @ 720MHz
DQS-corr enabled
DDR0: 1024MB-2T-11
DDR1: 512MB-2T-11
DataBus test pass!
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c000, des: 0x01400000, size: 0x00004000
Load bl30 from eMMC, src: 0x00010000, des: 0x01000000, size: 0x00008450
Sending bl30..................................OK.
Run bl30...
Load bl301 from eMMC, src: 0x000c8000, des: 0x01000000, size: 0x00001ad0
Wait bl30...Done
Sending bl301.......OK.
Run bl301...
Load bl31[ from eMMC, src: 0x0001c000, des: 0x10100000, size: 0x00013140
Image: gxtvb_v1.1.3081-33a313f-dirty 2016-11-24 15:47:33 qiufang.dai@droid07]
efuse_setup() 221: OPS=0x12
efuse_sLoad bl33 from eMMC, src: 0x00030000, des: 0x01000000, size: 0x000977a0
etup() 249: HDCP=0x0c REG32(SEC_AO_SEC_SD_CFG9)=0x00000007
bl30: check_permit, count is 1
bl30: check_permit: ok!
chipid: ef be ad de d f0 ad ba ef be ad de not ES chip
[0.265453 Inits done]
secure task start!
high task start!
low task start!
low task NOTICE:  BL3-1: v1.0(debug):db24c1e
NOTICE:  BL3-1: Built : 21:16:03, Mar 10 2016
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-g0ffa610-dirty (Sep 01 2017 - 15:31:40)
DRAM:  1.5 GiB
Relocation Offset is: 56edb000
low task comd=0x00060100
into process_low_task
into LOW_TASK_U_llow task comd=0x00000110
LED timer...
LED timer...
LED timer...
LED timer...
LED timer...
LED timer...
Enter USB burn
LED timer...
Try connect time out 701, 700, 2481
mwm 0xc8836800:[0x8002023c] with [0x8002023c] ok
mwm 0xc8836800:[0x8002023c] with [0x8c42023c] ok
Hit Enter key to stop autoboot -- :  1  0
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =53f60830
copy done
      Amlogic multi-dtb tool
      Single dtb detected
load dtb from 0x1000000 ......
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x0208bb98
   Loading Ramdisk to 539ff000, end 53ec8e98 ... OK
   Loading Device Tree to 000000001fff0000, end 000000001ffffe2f ... OK
fdt_instaboot: no instaboot image
Starting kernel ...
uboot time: 4324011 us
[    0.000000@0] Initializing cgroup subsys cpu
[    0.000000@0] Initializing cgroup subsys cpuacct
[    0.000000@0] Linux version 3.14.29-svn3593 (cq@npi2) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG MStar-1.13.1-4.9-2015.04 - MStar GCC 4.9-2015.04) ) #1 SMP PREEMPT Wed Jan 24 15:33:00 CST 2018
[    0.000000@0] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000@0] no prop version_code
[    0.000000@0] bootconsole [earlycon0] enabled
low task comd=0x00000003
[    0.425546@0] pinmux-gxtvbb c1109880.pinmux: pin GPIOH_7 already requested by c1108d80.spicc; cannot claim for wifi.37
[    0.430728@0] pinmux-gxtvbb c1109880.pinmux: pin-42 (wifi.37) status -22
[    0.437489@0] pinmux-gxtvbb c1109880.pinmux: could not request pin 42 (GPIOH_7) from group wifi_32k_pins  on device c1109880.pinmux
[    0.449365@0] aml_wifi wifi.37: Error applying setting, reverse things back
[    0.697465@0] mtdoops: mtd device (mtddev=name/number) must be supplied
单从打印信息上来看,这个打印信息是完全正常的,按照先易后难的原则,先对主板升级。
将脚本文件和强升包放入U盘根目录,进入控制台,控制台下输入升级命令:run recvoery_from_flash,快速进入升级模式。
升级界面如下:
升级完成后,故障现象不变,排除软件自身问题,卡开机画面的原因非常多,我们先来分析一下卡开机画面有哪几种可能性。
1、软件自身问题(已排除);
2、硬件部分的EMMC电路、DDR电路和CPU自身;
3、受I2C总线控制的接口电路;
既然软件自身可能性已经被我们排除,剩下的依然是先易后难的原则,先检查I2C总线控制的接口电路,此板外挂电路分别有高频头,本地网卡和AV切换电路,伴音功放。
分别断开三部分电路的I2C总线,当断开本地网卡和AV切换电路的总线时,可以正常进入系统,遥控功能也正常,只是不能用有线网络和AV,故障范围锁定在此电路。
测量5V和3.3V电压正常,测量三路内部LDO输出的1.8V也正常,测量P220与主芯片之间的通讯时发现R763阻值非常大为几百K。
更换为47欧,恢复总线通讯电阻。
通电故障排除!
总结:卡开机画面的故障应该是比例最高的,故障部位还是多种多样的,这就需要平时学习总结,而且卡开机画面故障部位在DDR电路最为常见,有的同学经常会问,打印信息显示开机初始化DDR的时候已经通过了,为什么还是DDR故障呢?其实开机初始化的时候就像我们去医院体检一样,只是做了一个抽样检查而已。
也就是说,打印显示开机初始化DDR通过,并不代表DDR电路完整正常工作。
那么打印显示开机初始化DDR失败,是不是就一定是DDR电路故障呢?
答案仍然是否定的!
结论是:打印显示开机初始化DDR通过,并不代表DDR电路正常,打印显示开机初始化DDR失败,也不代表DDR电路不正常。
只有不停的学习,实战,总结,维修工作才能轻松的收获!
后语:大量粉丝还没养成点赞的习惯,如写得好,望大家阅读后在右下边点个赞,以示鼓励!长期坚持原创真的很不容易,多次想放弃,坚持是一种信仰,专注是一种态度!
学习课程已更新,
欢迎大家进入学习。
入口:
公众号首页-精选-案例直播;
目前课程观看已使用专属APP
支持苹果、安卓手机以及电脑,
微信授权登录即可,
详见微信及QQ通知。
各芯片方案维修技巧、实战演练
各种机型电路基础原理
信号流程、刷机技巧
高安芯片快速解决方案
赠送各品牌备份软件
发表于: 2018-10-27 09:35:11
谢谢楼主的分享
发表于: 2018-10-26 17:01:06
谢谢楼主分享
发表于: 2018-10-26 18:35:58
谢谢楼主分享
发表于: 2018-10-26 19:07:56
谢谢楼主分享
发表于: 2018-10-26 19:24:47
谢谢楼主分享
发表于: 2018-10-27 07:45:25
昨天也是一台这种板,不开机,没头绪 老大说是EMMC坏了
发表于: 2018-10-27 08:04:25
谢谢楼主分享
发表于: 2018-10-27 09:09:10
谢谢版主分享的维修实例,收藏学习.....
发表于: 2018-11-1 08:42:54
谢谢楼主的分享
GMT+8, 2024-12-26 08:40 , Processed in 0.062439 sec., 11 queries .
