查看: 2496|回复: 6
大家帮忙看下创维49E710 9R15机芯型号EL3不开机的打印信息
发表于: 2018-10-10 17:01:06
2018-10-10, 16:13:50
COM6, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
A
U-Boot 2012.07-svn12491 (Sep 28 2014 - 12:56:45)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
MISC: efuse had NOT been written
[krsv] use default uboot memory:
DRAM:  2 GiB
Watchdog: Enabled
init_amp_prepare
name=AMP_I2C ppcb_enum.Name=AMP_I2C, ppcb_enum.info=300061b48
AMP_I2C=12884901889
name=AMP_DEVICE_ADDR ppcb_enum.Name=AMP_DEVICE_ADDR, ppcb_enum.info=1b00061b18
name=PIN_AMP_MUTE ppcb_enum.Name=PIN_AMP_MUTE, ppcb_enum.info=1790300061b28
no PIN_MISC_951_RST
Board: Tv010 v2 2G Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
MMC:
emmc:mmc_initial(1) Sep 28 2014 12:57:14
RTD299x eMMC: 0
Device: RTD299x eMMC
Manufacturer ID: 11
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Extern param: MMC blk:0x7c (to 0x9000)
         rtk_eMMC_read blk_addr=0x0000007c, data_size=0x00000800, buffer=0x00009000
Factory: MMC
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000d433, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000f435, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00286a00, buffer=0x0a900000
Factory: seq:0x12ca, blk:0xe000(pp:1), size:0x286a00 (to 0xa900000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=0
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
BOOT_PAL_NTSC_100_120_HZ=0
boot_power_on_mode=0
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
TAG=21
Panel: Use parameters in tmp/factory/bin_panel/panel.bin
Panel: lg_49_4k2k_vby1_m+
panel_init_1st
Panel: ulFreq:148500000, nDPLL:157499520, Mcode:35, Ncode:3, offset:751
================== P_VBY1_4K2K condition ===================
***** Get Chip ID (3) *****
================== VBY_ONE_PANEL_CHINA_STAR_4K2K_VBY1 ===================
DispI : Finish BISR testing done
DispD : Finish BISR testing done
Panel_Custom_INDEX=6
In:    serial
Out:   serial
Err:   serial
Net:   rtl8139: REALTEK RTL8139 @0xb8016000
Hit Esc or Tab key to enter console mode or rescue linux:  0
------------bootloader message size is 1088
======== Checking into android recovery ====
boot_ac_on=1
stopping USB..
Start Boot Setup ...
[eMMC]STR value:0x0,0x0
No STR...
REG 0xb8060100 : 0x0
JUMP address: 0x0
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000020, buffer=0x0a820000
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000400, buffer=0x0a820000
         FW Table to 0x0a820000, size=0x00000400 (0x0a820400)
         FW Table fr 0x02000000, fw count: 6
part_entry[0].len 0xd2000000
fw_desc_table_v1.paddings 0x400
fw_total_paddings 0x1090400
eMMC_bootcode_area_size0x1800000
EMMC_FACTORY_SIZE 0x800000
g_u32STDsize 0xcef6f800, g_u32STDoffset 0x3090800
blkNO 0x20000, 0x4000000, 0x200, 0x1
         rtk_eMMC_read blk_addr=0x00020000, data_size=0x00001000, buffer=0x00062960
STD identifier NOT match, enter normal boot!!
Normal boot fw follow...
Linux Kernel:
         FW Image to 0x00108000, size=0x00ac4104 (0x00bcc104)
         FW Image fr 0x02008000 (non-lzma)
Audio FW:
         FW Image to 0x81700000, size=0x0020b090 (0x8190b090)
         FW Image fr 0x02acc200 (non-lzma)
         Enter standby, skip this entry
Video FW 1:
         FW Image to 0x81a00000, size=0x002bc208 (0x81cbc208)
         FW Image fr 0x02cd7400 (non-lzma)
Video FW 2:
         FW Image to 0x81d00000, size=0x000b2e64 (0x81db2e64)
         FW Image fr 0x02f93800 (non-lzma)
ECPU FW:
         FW Image to 0x00004000, size=0x00002043 (0x00006043)
         FW Image fr 0x03046800 (non-lzma)
         rtk_eMMC_read blk_addr=0x00018234, data_size=0x00002043, buffer=0x00004000
         FW Image entry  checksum=0x000c8529
         FW Image result checksum=0x000c8529
Video[image] data 1:
         FW Image to 0x85700000, size=0x0004f955 (0x8574f955)
         FW Image fr 0x03048a00 (non-lzma)
         Kernel entry to 0x00108000, size=0x00ac4104 (0x00bcc104)
         Kernel entry fr 0x02008000 (non-lzma)
         rtk_eMMC_read blk_addr=0x00010040, data_size=0x00ac4104, buffer=0x00108000
         Kernel entry  checksum=0x3b547888
         Kernel result checksum=0x3b547888
(rtkpm_clr_share_mem)2013/04/23 14:55
Kernel command line: androidboot.console=ttyS0 console=ttyS0,115200 envp=100700 flashtype=emmc mmcparts=rtkemmc:3440640k,768000k(/system),524288k(/data),262144k(/cache),358400k(/skydir),81920k(/dtv),16384k(/res),1258291k(/skyota) quiet POWERDOWN ac_on
Starting kernel ...
start MAGELLAN EMCU 2014/03/20 12:56
share_reg[0x0]:0x0
share_reg[0x1]:0x0
share_reg[0x2]:0x0
share_reg[0x3]:0x0
share_reg[0x4]:0x0
share_reg[0x5]:0x0
share_reg[0x6]:0x0
share_reg[0x7]:0x0
share_reg[0x8]:0x0
share_reg[0x9]:0x0
share_reg[0xa]:0x0
share_reg[0xb]:0x0
share_reg[0xc]:0x0
share_reg[0xd]:0x5
share_reg[0xe]:0x0
share_reg[0xf]:0x0
share_reg[0x10]:0x0
share_reg[0x11]:0x0
share_reg[0x12]:0x0
share_reg[0x13]:0x0
share_reg[0x14]:0x0
share_reg[0x15]:0x0
share_reg[0x16]:0x0
share_reg[0x17]:0x0
share_reg[0x18]:0x0
share_reg[0x19]:0x0
share_reg[0x1a]:0x0
share_reg[0x1b]:0x0
share_reg[0x1c]:0x0
share_reg[0x1d]:0x0
share_reg[0x1e]:0x0
share_reg[0x1f]:0x0
share_reg[0x20]:0x0
share_reg[0x21]:0x0
share_reg[0x22]:0x0
share_reg[0x23]:0x0
share_reg[0x24]:0x0
share_reg[0x25]:0x0
share_reg[0x26]:0x0
share_reg[0x27]:0x0
share_reg[0x28]:0x0
share_reg[0x29]:0x0
share_reg[0x2a]:0x0
share_reg[0x2b]:0x0
share_reg[0x2c]:0x0
share_reg[0x2d]:0x0
share_reg[0x2e]:0x0
share_reg[0x2f]:0x0
share_reg[0x30]:0x0
share_reg[0x31]:0x0
share_reg[0x32]:0x0
share_reg[0x33]:0x0
share_reg[0x34]:0x0
share_reg[0x35]:0x0
share_reg[0x36]:0x0
share_reg[0x37]:0x0
share_reg[0x38]:0x0
share_reg[0x39]:0x0
share_reg[0x3a]:0x0
share_reg[0x3b]:0x0
share_reg[0x3c]:0x0
share_reg[0x3d]:0x0
share_reg[0x3e]:0x0
share_reg[0x3f]:0x0
share memory have showed!
** switch X27 to ring_osc 0x0058[1]=0**
last track_val=0x33
avg  track_val=0x32
***0x0058=0x5
***0x0058=0xd
** bus clock selec **
** 0x0050[0] = 1 **
***0x0050=0x1
** block main por signal **
** reg_main_por_en 0x0004[13] = 0 **
***0x0004=0x114f05
** RBUS timeout disable **
** 0x0400[2] = 0 **
***0x0400=0x0
** main top isolation **
** 0x0010[0] = 1 **
***0x0010=0x3
***1108=0xc080450
** getn isolation **
** 0x0010[2] = 1 **
***0x0010=0x7
REG0004:0x114f05
REG0208:0xcffcfcc
REG012c:0x2379beef
Power pin have 0x0 set
USE_STANDBY_LED---> 0xc080557
POWER share---> 0xc081557
POWER data---> 0xc080440
***ISO_IR_PSR=0x25151034
***ISO_IR_PER=0x25
***ISO_IR_SF=0xff00021b
***ISO_IR_DPIR=0x3ff
***ISO_IR_CR=0x5ff
***ISO_IR_RP=0x0
** power off finish **
0x0 MINUTE passed...
0xa(0xa) second passed...
0x14(0x14) second passed...
0x1e(0x1e) second passed...
0x28(0x28) second passed...
0x32(0x32) second passed...
0x1 MINUTE passed...
0xa(0x46) second passed...
0x14(0x50) second passed...
0x1e(0x5a) second passed...
0x28(0x64) second passed...
0x32(0x6e) second passed...
0x2 MINUTE passed...
0xa(0x82) second passed...
0x14(0x8c) second passed...
0x1e(0x96) second passed...
0x28(0xa0) second passed...
0x32(0xaa) second passed...
0x3 MINUTE passed...
0xa(0xbe) second passed...
0x14(0xc8) second passed...
0x1e(0xd2) second passed...
0x28(0xdc) second passed...
0x32(0xe6) second passed...
0x4 MINUTE passed...
0xa(0xfa) second passed...
0x14(0x104) second passed...
0x1e(0x10e) second passed...
0x28(0x118) second passed...
0x32(0x122) second passed...
0x5 MINUTE passed...
0xa(0x136) second passed...
0x14(0x140) second passed...
0x1e(0x14a) second passed...
0x28(0x154) second passed...
0x32(0x15e) second passed...
0x6 MINUTE passed...
0xa(0x172) second passed...
0x14(0x17c) second passed...
0x1e(0x186) second passed...
0x28(0x190) second passed...
0x32(0x19a) second passed...
发表于: 2018-10-10 17:43:02
数据错误需要升级
发表于: 2018-10-10 19:42:03
多已经跑马了,硬件应该没问题,软件刷机一下试试
 楼主| 发表于: 2018-10-10 20:18:43
哪位有这个机器的数据?
发表于: 2018-10-10 21:08:23
Thank you for your post.
发表于: 2018-10-11 08:25:24
TB购买数据吧,试试...
发表于: 2019-1-17 21:33:22
大家也帮我看下打印,也是不开机,红灯量及它无反应。
A
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  2 GiB
Watchdog: Enabled
init_amp_prepare
AMP_I2C=12884901889
no PIN_MISC_951_RST
POWER ON: AC
Cache: Enabled
MMC:
RTD299x eMMC: 0
Manufacturer ID: 90
OEM: 14a
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Factory: MMC
Factory: seq:0x1638, blk:0xe000(pp:1), size:0x286a00 (to 0xa900000)
get_bootparam:
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
LOCAL_UPGRADE_EN=0
get_layout:
BOOTPART=0
TAG=21
panel_init_1st
In:    serial
Out:   serial
Err:   serial
boot_ac_on=1
stopping USB..
No STR...
JUMP address: 0x0
Linux Kernel:
Audio FW:
Video FW 1:
Video FW 2:
ECPU FW:
         emmc block_no=0x00010040
         flash_to_ram_addr=0x00108000
         imageSize=0x00ac4104
         Kernel checksum FAILED
         Kernel result checksum=0x3b548ae5
dump ddr data(base=0x00108000)
000 : 00 90 0f e1 09 e0 a0 e1 1f e0 0e e2 1a 00 5e e3
010 : c0 90 89 e3 1f 90 c9 e3 13 90 89 e3 04 00 00 1a
020 : 01 9c 89 e3 0c e0 8f e2 09 f0 6f e1 0e f3 2e e1
030 : 6e 00 60 e1 09 f0 21 e1 10 4f 11 ee 01 10 c4 e3
040 : 10 4f 01 ee 10 4f 11 ee 01 4a c4 e3 04 40 c4 e3
050 : 10 4f 01 ee 00 40 a0 e3 15 4f 07 ee 10 5f 30 ee
060 : 94 80 9f e5 a5 56 08 e0 00 60 a0 e3 00 80 a0 e3
070 : 06 7f a0 e1 88 72 87 e1 56 7f 07 ee 01 80 88 e2
080 : 05 00 58 e1 f9 ff ff da 01 60 86 e2 04 00 56 e3
090 : f5 ff ff ba 00 40 a0 e3 9a 4f 07 ee 00 40 a0 e3
0a0 : 17 4f 08 ee 00 40 a0 e3 16 4f 08 ee 00 40 a0 e3
0b0 : 15 4f 08 ee 00 40 a0 e3 95 4f 07 ee 10 9f 10 ee
0c0 : 66 68 11 eb 05 a0 b0 e1 75 68 11 0a 30 30 8f e2
0d0 : 10 01 93 e8 04 40 43 e0 04 80 88 e0 3e 00 00 eb
0e0 : c6 a3 17 eb 08 00 00 eb 10 d0 9f e5 04 e0 8f e2
0f0 : 04 80 a0 e1 10 f0 8a e2 52 68 11 ea ff 01 00 00
100 : 5c 10 6f 80 04 81 10 80 00 00 00 80 41 49 88 e2
110 : 04 00 a0 e1 00 30 a0 e3 01 69 80 e2 04 30 80 e4
120 : 04 30 80 e4 04 30 80 e4 04 30 80 e4 06 00 30 e1
130 : f9 ff ff 1a 08 70 9a e5 90 00 8f e2 68 00 90 e8
140 : 03 00 40 e0 00 50 85 e0 00 60 86 e0 25 5a a0 e1
150 : 26 6a a0 e1 05 3a 87 e1 05 31 84 e7 06 00 55 e1
160 : 01 50 85 32 fa ff ff 3a 02 0a 84 e2 58 60 9f e5
170 : 07 30 88 e1 26 69 84 e0 04 30 80 e4 01 36 83 e2
180 : 06 00 50 e1 fb ff ff 9a 06 33 a0 e3 23 3a a0 e1
190 : 03 3a 87 e1 07 3a c3 e3 0c 30 c3 e3 02 3a 83 e3
1a0 : fe 0d 84 e2 00 30 80 e5 22 0a a0 e1 00 0a b0 e1
1b0 : 08 30 40 10 02 31 83 12 23 39 84 10 00 60 87 11
1c0 : 00 60 83 15 0c 70 9a e5 0e f0 a0 e1 cf 17 c1 80
1d0 : d0 81 10 80 c0 8f 56 80 e0 8f 56 80 03 00 12 e3
1e0 : 0b 00 00 1a 00 50 92 e5 2c 60 9f e5 06 00 55 e1
1f0 : 06 00 00 0a 05 00 55 e3 02 00 55 13 04 00 00 1a
Enter console mode, disable watchdog ...
Realtek>
GMT+8, 2024-12-21 13:37 , Processed in 0.053683 sec., 10 queries .
