查看: 7354|回复: 11
TP.MT5507.PB801 红灯亮不开机 打印信息如下
发表于: 2018-10-3 17:50:43
Boot-
DRAM Channel A Calibration.
1T = (89 - 21) = 68 delay cells
Clock frequency = 750 MHz, Clock period = 1333 ps, 1 delay cell =19 ps
Gating calibration byte 0 window size is too small!!
Gating calibration byte 1 window size is too small!!
Gating calibration byte 2 window size is too small!!
Gating calibration byte 3 window size is too small!!
error on bit 0 ,setup_time =hold_time =0!!
error on bit 1 ,setup_time =hold_time =0!!
error on bit 2 ,setup_time =hold_time =0!!
error on bit 3 ,setup_time =hold_time =0!!
error on bit 4 ,setup_time =hold_time =0!!
error on bit 5 ,setup_time =hold_time =0!!
error on bit 6 ,setup_time =hold_time =0!!
error on bit 7 ,setup_time =hold_time =0!!
error on bit 8 ,setup_time =hold_time =0!!
error on bit 9 ,setup_time =hold_time =0!!
error on bit 10 ,setup_time =hold_time =0!!
error on bit 11 ,setup_time =hold_time =0!!
error on bit 12 ,setup_time =hold_time =0!!
error on bit 13 ,setup_time =hold_time =0!!
error on bit 14 ,setup_time =hold_time =0!!
error on bit 15 ,setup_time =hold_time =0!!
error on bit 16 ,setup_time =hold_time =0!!
error on bit 17 ,setup_time =hold_time =0!!
error on bit 18 ,setup_time =hold_time =0!!
error on bit 19 ,setup_time =hold_time =0!!
error on bit 20 ,setup_time =hold_time =0!!
error on bit 21 ,setup_time =hold_time =0!!
error on bit 22 ,setup_time =hold_time =0!!
error on bit 23 ,setup_time =hold_time =0!!
error on bit 24 ,setup_time =hold_time =0!!
error on bit 25 ,setup_time =hold_time =0!!
error on bit 26 ,setup_time =hold_time =0!!
error on bit 27 ,setup_time =hold_time =0!!
error on bit 28 ,setup_time =hold_time =0!!
error on bit 29 ,setup_time =hold_time =0!!
error on bit 30 ,setup_time =hold_time =0!!
error on bit 31 ,setup_time =hold_time =0!!
HW Byte 0 : DQS(0 ~ 0), Size 0 , Set 0.
HW Byte 1 : DQS(0 ~ 0), Size 0 , Set 0.
HW Byte 2 : DQS(0 ~ 0), Size 0 , Set 0.
HW Byte 3 : DQS(0 ~ 0), Size 0 , Set 0.
RX DQ/DQS calibration fail!
DATLAT calibration
no DATLAT taps pass
default tx dq PI delay value(16) is fail on bit 0!!
default tx dq PI delay value(16) is fail on bit 1!!
default tx dq PI delay value(16) is fail on bit 2!!
default tx dq PI delay value(16) is fail on bit 3!!
default tx dq PI delay value(16) is fail on bit 4!!
default tx dq PI delay value(16) is fail on bit 5!!
default tx dq PI delay value(16) is fail on bit 6!!
default tx dq PI delay value(16) is fail on bit 7!!
default tx dq PI delay value(16) is fail on bit 8!!
default tx dq PI delay value(16) is fail on bit 9!!
default tx dq PI delay value(16) is fail on bit 10!!
default tx dq PI delay value(16) is fail on bit 11!!
default tx dq PI delay value(16) is fail on bit 12!!
default tx dq PI delay value(16) is fail on bit 13!!
default tx dq PI delay value(16) is fail on bit 14!!
default tx dq PI delay value(16) is fail on bit 15!!
default tx dq PI delay value(16) is fail on bit 16!!
default tx dq PI delay value(16) is fail on bit 17!!
default tx dq PI delay value(16) is fail on bit 18!!
default tx dq PI delay value(16) is fail on bit 19!!
default tx dq PI delay value(16) is fail on bit 20!!
default tx dq PI delay value(16) is fail on bit 21!!
default tx dq PI delay value(16) is fail on bit 22!!
default tx dq PI delay value(16) is fail on bit 23!!
default tx dq PI delay value(16) is fail on bit 24!!
default tx dq PI delay value(16) is fail on bit 25!!
default tx dq PI delay value(16) is fail on bit 26!!
default tx dq PI delay value(16) is fail on bit 27!!
default tx dq PI delay value(16) is fail on bit 28!!
default tx dq PI delay value(16) is fail on bit 29!!
default tx dq PI delay value(16) is fail on bit 30!!
default tx dq PI delay value(16) is fail on bit 31!!
error: cannot find right boundary of DQM
error: cannot find left boundary of DQM
TX HW Byte 0 : DQS(-16 ~ -16), Size 1, Set 48.
TX HW Byte 1 : DQS(-16 ~ -16), Size 1, Set 48.
TX HW Byte 2 : DQS(-16 ~ -16), Size 1, Set 48.
TX HW Byte 3 : DQS(-16 ~ -16), Size 1, Set 48.
TX DQ/DQS calibration fail!
发表于: 2018-10-3 18:07:37
750MHz,时钟周期=1333ps,1延迟单元=19ps。门校准字节0窗口太小了!!选通校准字节1窗口大小太小!!选通校准字节2窗口大小太小!!选通校准字节3窗口大小太小!!0位错误,StuuPuthTime= HOLD引导DRAM通道进行校准。1T=(89-21)=68个延迟单元时钟频率=750MHz,时钟周期=1333ps,1延迟单元=19ps。门校准字节0窗口太小了!!选通校准字节1窗口大小太小!!选通校准字节2窗口大小太小!!选通校准字节3窗口大小太小!!0位错误,StuuPuthTime= HOLDYTIME=0!!1位错误,StuuPuthTime= HOLDYTIME=0!!2位错误,StuuPuthTime= HOLDYTIME=0!!3位错误,StuuPuthTime= HOLDYTIME=0!!4位错误,StuuPuthTime= HOLDYTIME=0!!5位错误,StuuPuthTime= HOLDYTIME=0!!6位错误,StuuPuthTime= HOLDYTIME=0!!7位错误,StuuPuthTime= HOLDYTIME=0!!8位错误,StuuPuthTime= HOLDYTIME=0!!9位错误,StuuPuthTime= HOLDYTIME=0!!10位错误,StuuPuthTime= HOLDYTIME=0!!11位错误,StuuPuthTime= HOLDYTIME=0!!12位错误,StuuPuthTime= HOLDYTIME=0!!13位错误,StuuPuthTime= HOLDYTIME=0!!14位错误,StuuPuthTime= HOLDYTIME=0!!15位错误,StuuPuthTime= HOLDYTIME=0!!16位错误,StuuPuthTime= HOLDYTIME=0!!17位错误,StuuPuthTime= HOLDYTIME=0!!18位错误,StuuPuthTime= HOLDYTIME=0!!19位错误,StuuPuthTime= HOLDYTIME=0!!20位错误,StuuPuthTime= HOLDYTIME=0!!21位错误,StuuPuthTime= HOLDYTIME=0!!22位错误,StuuPuthTime= HOLDYTIME=0!!23位错误,StuuPuthTime= HOLDYTIME=0!!24位错误,StuuPuthTime= HOLDYTIME=0!!25位错误,StuuPuthTime= HOLDYTIME=0!!26位错误,StuuPuthTime= HOLDYTIME=0!!27位错误,StuuPuthTime= HOLDYTIME=0!!28位错误,StuuPuthTime= HOLDYTIME=0!!29位错误,StuuPuthTime= HOLDYTIME=0!!30位错误,StuuPuthTime= HOLDYTIME=0!!31位错误,StuuPuthTime= HOLDYTIME=0!!HW字节0:DQS(0~0),大小0,集合0。HW字节1:DQS(0~0),大小0,集合0。HW字节2:DQS(0~0),大小0,集合0。HW字节3:DQS(0~0),大小0,集合0。RX DQ/DQS校准失败!DATLAT校准无DATLAT抽头通过
  报 PI延迟值(16)是失败的位14!!默认的TX DQ PI延迟值(16)是失败的位15!!默认的TX DQ PI延迟值(16)是失败的位16!!默认的TX DQ PI延迟值(16)是失败的位17!!默认的TX DQ PI延迟值(16)是失败的位18!!默认的TX DQ PI延迟值(16)是失败的位19!!默认的TX DQ PI延迟值(16)是失败的位20!!默认的TX DQ PI延迟值(16)是失败的位21!!默认的TX DQ PI延迟值(16)是失败的位22!!默认的TX DQ PI延迟值(16)是失败的位23!!默认的TX DQ PI延迟值(16)是失败的位24!!默认的TX DQ PI延迟值(16)是失败的位25!!默认的TX DQ PI延迟值(16)是失败的位26!!默认的TX DQ PI延迟值(16)是失败的位27!!默认的TX DQ PI延迟值(16)是失败的位28!!默认的TX DQ PI延迟值(16)是失败的位29!!默认的TX DQ PI延迟值(16)是失败的位30!!默认的TX DQ PI延迟值(16)是失败的位31!错误:找不到DQM错误的右边界:找不到DQM TX HW字节0QS(-16~-16),大小1,设置48。TX HW字节1:DQS(- 16~16),大小1,设置48。TX HW字节2:DQS(- 16~16),大小1,设置48。TX HW字节3:DQS(- 16~16),大小1,设置48。TXDQ/DQS校准失败!  报错 拼音  双语对照
排序
重点词汇
重点词汇
DRAMdynamic random access memory 动态随机存储器; 打兰,一杯,微量
Calibration管径测量; 校准,标准化; 刻度,标度
Clock frequency时钟频率
MHzmegahertz 兆赫[兹]; = MegaHertz,兆赫
Clock period时钟脉冲周期,时钟周期
delay cell延时元件
Gating选通,门控英国大学的禁足处罚; 配针
byte字节
window size窗口大小
on bit一值位
错 拼音  双语对照 YTIME=0!!1位错误,StuuPuthTime= HOLDYTIME=0!
 楼主| 发表于: 2018-10-3 19:10:16
请问是哪的问题,修了一下午都没好
 楼主| 发表于: 2018-10-10 10:36:34
已修好,用户刷错软件引起的
发表于: 2019-1-18 20:39:05
王杰123 2018-10-10 10:36
已修好,用户刷错软件引起的
不错哦.想问一下我有一个这板也是红灯亮不开机.可不可以给个数据试试
发表于: 2019-11-4 22:17:22
已修好,用户刷错软件引起的
你好,你是怎么修好的??15819091012
发表于: 2020-12-25 18:22:27
不要被误导 这跟程序半毛关系都没有
GMT+8, 2024-11-17 19:45 , Processed in 0.060262 sec., 10 queries .
