查看: 1081|回复: 2
RDA8501 STUCK ON LOGO + DATA
发表于: 2018-9-17 19:39:48
This TV is based on RDA8501. The set goes to standby when powered then, stuck on LOGO after Power button on TV set or remote control is pressed, does not accept any comands.Solution: Use remote Power button and imediately press menu or source before It displays the logo , then it will boot up OK. Enter service mode ( Menu _ followed by 1147 ) then on the Factory mode scroll down to Init Set--- and press cursor right then TV goes to standby. This will reset to factory defaults.
发表于: 2018-9-17 22:52:46
Thank you so much.
发表于: 2018-9-18 08:30:34
谢谢楼主分享
GMT+8, 2024-11-25 21:28 , Processed in 0.052850 sec., 10 queries .
