查看: 2344|回复: 2
师傅们帮看看55X的打印信息这是哪的问题
发表于: 2018-9-7 22:47:55
暴风55x开机背光会亮,灰屏 按键会开机不会关机 没遥控器不保证会不会关机 打印信息如下:
002:  COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12,
QA9:B;SVN:1C64OC:1FF;STS:0;BOOT:0;INIT:0;READ:0;CHECK:0ASS:0;
no sdio debug board detected
TE : 160783
BT : 21:45:10 May  9 2016
PMU:NONE
##### VDDEE voltage = 0x042e1070
PUB init fail! Reset...
QA9:B;SVN:1C64OC:1FF;STS:6B730001;SKIP:0;BOOT:1;QA9:B;SVN:1C64OC:1FF;STS:0;BOOT:0;INIT:0;READ:0;CHECK:0ASS:0;
TE : 159624
PMU:NONE
CPU clock is 1200MHz
Aml log : mmc_init_all
Aml log : DDR0 - DFI status check done
Aml log : DDR1 - DFI status check done
Aml log : HX DDR PUB training begin:
Aml log : DDR0 - PLL,DCAL,RST,ZCAL done
Aml log : DDR1 - PLL,DCAL,RST,ZCAL done
Aml log : DDR0 - DRAM INIT done
Aml log : DDR1 - DRAM INIT done
Aml log : DDR0 - WL done
Aml log : DDR1 - WL done
Aml log : DDR0 - DQS done
Aml log : DDR1 - DQS done
Aml log : DDR0 - PUB_PGSR0_WLAERR with [c08000ff] retry...
Aml log : DDR0 - PUB_PGSR0_WLAERR with [808000ff] retry...
Error loop 10times, error...
QA9:B;SVN:1C64OC:1FF;STS:6B730001;SKIP:0;BOOT:1;INIT:10;USB:3;SERIAL:4;STS:6B730000;BOOT:0;INIT:0;READ:0;CHECK:0ASS:0;
TE : 11712027
PMU:NONE
一直反复出现QA9:B;SVN:1C64OC:1FF;STS:6B730001;SKIP:0;BOOT:1;INIT:10;USB:3;SERIAL:4;
 楼主| 发表于: 2018-9-7 22:52:34
4;STS:6B730000这个一直过不去
 楼主| 发表于: 2018-9-8 22:11:28
刚才又研究一番
DDR0_PUB_PGSR0: 0xc***.Retry... DDR init fail 指的是DDR0与主芯片通讯异常;
Error loop 10times, error...错误循环10次,错误
更换4片DDR打印信息故障依旧
直接扔垃圾堆里
GMT+8, 2025-12-15 13:01 , Processed in 0.054145 sec., 10 queries .
