查看: 905|回复: 1
创维49E3500-9R20三无
发表于: 2018-7-13 17:34:19
49E3500-9R20,三无。指示灯不亮,开机测电源板380V只有300V,24V,12V电压均无。测量电路无明显短路情况,测电源块8A01供电正常,怀疑8A01性能不良,由于手头没有8A01,用6543代换,换后开机正常
发表于: 2018-7-13 21:44:26
Thank you so much for your sharing.
GMT+8, 2024-11-28 20:43 , Processed in 0.048025 sec., 9 queries .
