查看: 2482|回复: 3
求助:乐视进控制台打开串口方法
发表于: 2018-7-7 08:47:26
乐视超3花屏,如何进控制台打开串口?
AC_ON
MIU0_DQS-OK
MIU1_DQS-OK
MIU2_DQS-OK
BIST0-OK
BIST1-OK
BIST2-OK
_U_WDT
Relocation Offset is: 00900000
[AT][MB][start ub][324]
U-Boot 2011.06-00000-ga4b4f07-dirty (Jan 12 2017 - 03:06:43)
[MIU INFO] miu opencreate instance at 57d75020 with private size 80 bytes at 57d75068
create instance at 57d750c0 with private size 52 bytes at 57d75108
AC on
uboot held at [579ddf60~59300000],size=019220a0
CPU  : Monaco
Board: BD_MST068D_10AHP_14222
DRAM:  915 MiB
Now running in RAM - U-Boot at: 58400000
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
UART BUS OFF!!?
 楼主| 发表于: 2018-7-7 09:08:12
开机画面正常,几秒钟后花屏
 楼主| 发表于: 2018-7-8 20:52:07
读取用户区数据只完成了一部分,报错,
保存的文件信息:
 楼主| 发表于: 2018-7-8 20:55:57
不能完整读出,是不是EMMC有问题?如果换空片EMMC,把这个备份写入可以吗?
GMT+8, 2024-12-29 10:07 , Processed in 0.054945 sec., 10 queries .
