查看: 1805|回复: 6
打印信息看不懂大神支招
发表于: 2018-6-19 11:20:26
UART_115200
BIST0-OK
BIST1-OK
[0123456][0123456]-33
[1234][012345]-22
_nPD
U-Boot 1.1.6 (Apr 15 2010 - 16:56:04)
Board: MSTAR TITANIA (CPU Speed 504 MHz)
DRAM:  0x8000000
Skipping flash_init
Flash:  0 kB
NAND:  nand_bbt: searching bbt....Bad block table found at page 262080, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 262016, version 0x01
nand_read_bbt: Bad block at 0x0f340000
512 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MSVC00B000100100208768TH0000000T
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
start init IIC-------------->
come to konka path----@1------
EEPROM @0x0 read: addr 80200000  off 1ffa  count 1 ... cmd: md.b 0x80200000 0x1
80200000: a5    .
done
EEPROM @0x0 read: addr 80400000  off 1ffb  count 1 ... cmd: md.b 0x80400000 0x1
80400000: 5a    Z
done
memory display value read from eeprom ----->:80200000: 5a5aa5a5    ..ZZ
80400000: 8000105a    Z...
data_1[1FFA]--->:a5
data_2[1FFB]--->:5a
---------->defatult_set is:165
---------->defatult_set1 is:90
*ucp is:165
*ucp1 is:90
startFlag_2 is:-1
keypad_pressed is [0]
0x00220000-0x1f240000 : "mtd=3"
Volume KL found at volume id 0
read 4194304 bytes from volume 0 to 81000000(buf address)
## Booting image at 81000000 ...
   Image Name:   Linux-2.6.28.10-mstar
   Created:      2010-03-30   2:43:22 UTC
   Image Type:   MIPS Linux Kernel Image (lzo compressed)
   Data Size:    3404549 Bytes =  3.2 MB
   Load Address: 80400000
   Entry Point:  80404150
   Uncompressing Kernel Image ... OK
Starting kernel ...
Linux version 2.6.28.10 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 4.3-51) ) #11 PREEMPT Tue Mar 30 10:43:01 CST 2010
LINUX started...
boot_command_line: console=ttyS0,115200 ubi.mtd=3,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2F00000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x43F04000,0x4000000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:128k(NPT),1m(BL0),1m(BL1),508032k(UBI),-(NA)
LX_MEM  = 0x400000, 0x2F00000
LX_MEM2 = 0x43F04000, 0x4000000
CPHYSADDR(PFN_ALIGN(&_end))= 0x9AA000
EMAC_LEN= 0x100000
DRAM_LEN= 0x10000000
console [early0] enabled
CPU revision is: 00019554 (MIPS 34Kc)
Begin Titania3_setup
BDetermined physical RAM map:
memory: 02f00000 @ 00400000 (usable)
memory: 04000000 @ 43f04000 (usable)
Wasting 32768 bytes for tracking 1024 unused pages
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  DMA      0x00000400 -> 0x00008000
  Normal   0x00008000 -> 0x00020000
  HighMem  0x00020000 -> 0x00047f04
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
    0: 0x00000400 -> 0x00003300
    0: 0x00043f04 -> 0x00047f04
  Normal zone: 768 pages exceeds realsize 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 26889
Kernel command line: console=ttyS0,115200 ubi.mtd=3,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2F00000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x43F04000,0x4000000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:128k(NPT),1m(BL0),1m(BL1),508032k(UBI),-(NA)
alloc ebase: 818fc000
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=0005d466
Readback ErrCtl register=0005d466
PID hash table entries: 256 (order: 8, 1024 bytes)
CPU freq count = 252000000
CPU frequency 504.00 MHz
console handover: boot [early0] -> real [ttyS0]
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 98500k/48128k available (3900k kernel code, 15080k reserved, 1331k data, 164k init, 65536k highmem)
SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 334.84 BogoMIPS (lpj=167424)
Mount-cache hash table entries: 512
net_namespace: 288 bytes
NET: Registered protocol family 16
SCSI subsystem initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
        (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
        (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
        (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
        (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
cfg80211: Calling CRDA for country: US
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND)2001-2006 Red Hat, Inc.
fuse init (API version 7.10)
msgmni has been set to 64
CPU 0 Unable to handle kernel paging request at virtual address 00000114, epc == 80638ca0, ra == 80638ca8
Oops[#1]:
Cpu 0
$ 0   : 00000000 0000002d 00000100 80638c74
$ 4   : 00000118 00000005 00000002 00008063
$ 8   : 0000003c 00000000 81052a00 00000000
$12   : e0066000 00000004 00000001 80980000
$16   : 00000005 e0066000 e0066000 00000118
$20   : 00000046 82d41cc4 82d41cc0 00000002
$24   : 82d0fa80 80600d84
$28   : 82d40000 82d41c20 00000002 80638ca8
Hi    : 0000000b
Lo    : 5555555b
epc   : 80638ca0 uart_tiocmget+0x2c/0xe4
    Not tainted
ra    : 80638ca8 uart_tiocmget+0x34/0xe4
Status: 11008c03    KERNEL EXL IE
Cause : 80800008
BadVA : 00000114
PrId  : 00019554 (MIPS 34Kc)
Modules linked in:
Process cryptomgr_test (pid: 174, threadinfo=82d40000, task=82c57a18, tls=00000000)
Stack : 5a5aa5a5 5a5aa5a5 5a5aa5a5 5a5aa5a5 5a5aa5a5 82d0fa80 e0066000 00000005
        80905e94 806238f4 5a5aa5a5 5a5aa5a5 5a5aa5a5 5a5aa5a5 5a5aa5a5 00000000
        82d0fa80 82d0fa00 80905e94 80600e18 00000007 80421558 5a5aa5a5 00000258
        80970000 80905e8c 8084c340 00000000 82d41cc4 82d0fa00 00000200 805fb1a0
        8091a290 804615c8 82d41cf8 00000000 82d41cc0 80946070 82c19658 00000001
Call Trace:
[<80638ca0>] uart_tiocmget+0x2c/0xe4
[<806238f4>] zlib_deflate+0x128/0x400
[<80600e18>] deflate_compress+0x94/0xac
[<805fb1a0>] test_comp+0x90/0x300
[<805fb46c>] alg_test_comp+0x5c/0xa4
[<805fb858>] alg_test+0x178/0x364
[<805fb084>] cryptomgr_test+0x3c/0x5c
[<80441b38>] kthread+0x58/0xa4
[<8040acd4>] kernel_thread_helper+0x10/0x18
Code: 00a08021  24530018  02602021 <0c1019ea> 8c510014  12000005  00000000  0c18a89c  02002021
 楼主| 发表于: 2018-6-19 11:23:43
现在电视不开机
发表于: 2018-6-19 11:58:03
重新刷系统,升级一下。先试一下双清
发表于: 2018-6-19 13:50:25
同意楼上意见,Flash:  0 kB
nand_read_bbt: Bad block at 0x0f340000这部分打印信息里有坏块这样的单词,只能升级一试
 楼主| 发表于: 2018-6-19 14:04:12
刷了引导还是不开机,只有用U盘试一试,谢谢
发表于: 2018-6-19 20:43:02
Oops[#1]:   应该是内核程序有问题好像是。
 楼主| 发表于: 2018-7-8 10:40:12
山间小溪 发表于 2018-6-19 20:43
CPU 0 Unable to handle kernel paging request at virtual address 00000114, epc == 80638ca0, ra == 806 ...
谢谢U盘升级无果最后更换主板
GMT+8, 2024-12-20 00:57 , Processed in 0.048982 sec., 9 queries .
