楼主 |
发表于: 2018-6-17 07:40:57
显示全部楼层
更加奇怪的是,用rt809f 备份了emmc资料之后,电视的打印资料变成了下面的情况:
Boot-
DRAM Channel A Calibration.
1T = (85 - 19) = 66 delay cells
Clock frequency = 750 MHz, Clock period = 1333 ps, 1 delay cell =20 ps
Byte 0 : Gating(-33 ~ 33), Size=67 .
Byte 1 : Gating(-32 ~ 32), Size=65 .
Byte 2 : Gating(-32 ~ 32), Size=65 .
Byte 3 : Gating(-31 ~ 32), Size=64 .
HW Byte 0 : DQS(-8 ~ 15), Size 24 , Set 4.
HW Byte 1 : DQS(-10 ~ 14), Size 25 , Set 2.
HW Byte 2 : DQS(-8 ~ 16), Size 25 , Set 4.
HW Byte 3 : DQS(-10 ~ 14), Size 25 , Set 2.
DATLAT calibration
first_step= 11 total pass= 5 best_step=12 .
TX HW Byte 0 : DQS(2 ~ 25), Size 24, Set 14.
TX HW Byte 1 : DQS(3 ~ 27), Size 25, Set 15.
TX HW Byte 2 : DQS(2 ~ 25), Size 24, Set 14.
TX HW Byte 3 : DQS(2 ~ 27), Size 26, Set 15.
DRAM A Size = 512 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xaa59232b
:0x3002e31c
:0x30344745
:0x11010030
LZHS addr:0x00100040
LZHS size:0x000d5688
LZHS checksum:0x0000000f
store RSA & AES keys in DMX SRAM
LZHS begin
Boot
Start Lmain
MT5882 Boot Loader v0.9
Boot reason: A/C power on!!Load HDMI internal EDID.................
00 ff ff ff ff ff ff 00 63 18 00 00 00 00 00 00
06 18 01 03 80 00 00 00 0a d7 a5 a2 59 4a 96 24
14 50 54 a3 08 00 d1 c0 b3 00 81 00 81 80 81 40
81 c0 01 01 01 01 02 3a 80 18 71 38 2d 40 58 2c
45 00 3f 43 21 00 00 1a 66 21 50 b0 51 00 1b 30
40 70 36 00 3f 43 21 00 00 1e 00 00 00 fd 00 32
4c 1e 50 10 00 0a 20 20 20 20 20 20 00 00 00 fc
00 41 41 41 0a 20 20 20 20 20 20 20 20 20 01 4e
02 03 24 74 50 90 05 04 03 07 02 06 01 1f 14 13
12 16 11 15 20 23 09 07 03 66 03 0c 00 20 00 00
83 01 00 00 01 1d 00 bc 52 d0 1e 20 b8 28 55 40
c4 8e 21 00 00 1e 01 1d 80 d0 72 1c 16 20 10 2c
25 80 c4 8e 21 00 00 9e 8c 0a d0 8a 20 e0 2d 10
10 3e 96 00 13 8e 21 00 00 18 8c 0a d0 90 20 40
31 20 0c 40 55 00 13 8e 21 00 00 18 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 f3
CEC Physical offset 9d
HDMI1 PA 0x20
HDMI1 checksum 0xf3
HDMI2 PA 0x30
HDMI2 checksum 0xe3
HDMI3 PA 0x10
HDMI3 checksum 0x3
HDMI4 PA 0x40
HDMI4 checksum 0xd3
SIF_Master0: V2 design
IR DATA register : 0x 0
Load T8032 FW (addr: 0x da6740, size: 21826)success!!
T8032 FW version: 1
LDR_FlashCopy 0xf010 0x59280 0x80
11010030:30344745:3002e31c:11010030
id1:00303034 id2:47453002
eMMC Name: UNKNOWN
1st MAC in EEP is valid (00:25:92:81:d3:da)
Boot reason: A/C power on!!<5507> getenv flag=0xa01, len=0x0b
Do USB upgrade
u1USBBlock = 0x01505840
USB: Vbus turn up time = 299 ms, Max =1000 ms.
USB-3: insert.
USB-3: ClassCode= 0x0, u4Diff=0 ms.
No USB device.
USB upgrade stop
LDR_EEPUserDrvCheckMagic u4HeaderData=0x16170437, u4Magic=0x16170437
Boot reason: A/C power on!!<5507> getenv flag=0xa09, val=0x00
<5508> LDR_IsGoBootup prLdrData->u4WakeupReason:6
<5507> getenv flag=0xa08, val=0x00
<5507> getenv flag=0xf8d, val=0xff
<5507> getRecoveryStep step=255
<5507> setenv flag=0xb21, val=0xff
<5508> LDR_IsGoBootup AT_READ_FLAG=0, AT_B_FLAG=0
Boot reason: A/C power on!!go to standby when ac on at factory mode 0.
PDWNC_EnterPowerDown(100,6)
Disable VGA wakeup
support WOL
Standby
SWITCH_T8032
?vEnterPowerStandby: Cbus_Init
按了开机键之后下面又多了一些信息,屏幕就是没有图像H匔吤DRAM Channel A Calibration.
Byte 0 : Gating(-31 ~ 32), Size=64 .
Byte 1 : Gating(-31 ~ 31), Size=63 .
Byte 2 : Gating(-31 ~ 31), Size=63 .
HW Byte 1 : DQS(-9 ~ 15), Size 25 , Set 3.
HW Byte 2 : DQS(-8 ~ 17), Size 26 , Set 5.
HW Byte 3 : DQS(-10 ~ 16), Size 27 , Set 3.
DATLAT calibration
TX HW Byte 3 : DQS(2 ~ 27), Size 26, Set 14.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0xaa59232b
:0x3002e31c
:0x30344745
:0x11010030
LZHS begin
Boot
Start Lmain
eMMC Name: UNKNOWN
<5508> LDR_IsGoBootup prLdrData->u4WakeupReason:3
PDWNC_Init
LiGF: Set GPIO88 = 0.
Loader_ReadMsdc(14, 0, 0x0d000000, 2097152, 2097152)
Find panel index 6 from EEPROM
2 Find panel index 6(PANEL_CMO_37_H1) from EEPROM
PANEL_ReadSettingsFromEeprom u4ControlWord=0xffffffff, u1FacAtPanel=0xff, u1FacAtMap=0xff
before u4PanelControlWord = 0x00000028
LvdsDisplayBit = 0x00000020
IsLvdsOddSwOn = 0x00000000
IsLvdsMsbSwOn = 0x00000000
after u4PanelControlWord = 0x00000028
Curr panel controlword = 00000028
[SA7] vDDDSInit
[SA7] _fgVopllUseDDDS = True
[LVDS] VOPLL Initialize successful !
vDrvLVDSOn(), FIFO skew = 0x506
jpeg_decode(0x0d000000, 2097152, 0x0f000000, 2097152, 0x11000000, 1920, 1080)
Color:14 BmpAddr:0x11000000 Width:1920 Height:1080
Panel_width=1920, panel_height =1080
====u1FlipMirrorEnable 0
[OSD]DBG Timing is Front Scaler
[OSD]i4H=310 i4V=9
u4HaderAddr = 0x1989f000, u4DisAddr=0x198a0000
Panel 1920 x 1080
*************u4BmpPitch=7680******************
u4SrcWidth=1920 u4Value=0
u4OutWidth=1920,u4OutHeight=1080,u4OutX=0,u4OutY=0.
LDR_OsdDisplay(14, 0x11000000, 1920, 1080) return 0
Flash load lzhs header from 0x80000 to dram(0x1502d50), size=2048
Decompression uboot to 0x01000000...
Flash load image from 0x80000 to dram(0x1502d50), size=0x3cff4
Flash load tz from 0x0(part_15) to dram(0x1fb00000), size=0x412dd
LZHS start
LZHS done
LZHS start
LZHS done
Starting image...
U-Boot 2011.12.12 (Jun 16 2016 - 17:04:32)
DRAM: 374.1 MiB
u4DramSize: 0x200
WARNING: Caches not enabled
MMC: HOST 1
11010030:30344745:3002E31C:AA59232B
eMMC Name: UNKNOWN
[emmc]bus timing switch to HS
[emmc]bus width switch to 8(SDR)
msdc clock driving = 0!
msdc clock driving = 7!
[emmc]bus clock switch to 50000000
msdc clock driving = 23!
: 0
msdcgpiomsdcgpio=-1,-1,-1,-1,-1,-1,
0.0.0.0
In: serial
Out: serial
Err: serial
Net: init MMAC driver
ethernet internal PHY init successful!
priv : 0x00ef41e8
Mmac:hyAddr=0
Mmac::initialize
Net Initialization Skipped
`T`T
pmisc_msg:
Hit any key to stop autoboot: 0
kernel: signature verification is OK
ramdisk: signature verification is OK
## Booting kernel from Legacy Image at 00007fc0 ...
XIP Kernel Image ... OK
OK
