查看: 1314|回复: 8
创维32E361S雷击后的效果
发表于: 2018-5-31 18:53:23
      创维32E361S雷击后出现 红绿兰白黑 不停的显示,按键失灵,摇控器只能开关机,下面是读取的打印信息,各高手看下,是哪里的问题,谢谢
2018-5-31, 18:26:55
COM6, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
C卋oot_ac_on = 1
b806012c = 2379beef
A5280wait V5280wa[initmodules.c 238]:initmodules 1
[initmodules.c 242]:initmodules 2
[initmodules.c 248]:initmodules 3
[initmodules.c 253]:initmodules 4
[initmodules.c 259]:initmodules 5
ACPU : Finish BISR testing acpu_bisr_st1:done
VCPU : Finish BISR testing vcpu_bisr_st1:done
IO Config 2= PIN_BL_ON_OFF@0000000001010204
IO Config 2= PIN_BL_ADJ@00c8ffc800000307
IO Config 2= PIN_V_PWM@00c8ff983a000008
IO Config 2= PIN_I_PWM@00c8ff983a000108
IO Config 2= PIN_LVDS_ON_OFF@0000000000015203
IO Config 2= PIN_KEYPAD_POWER@000000080f000001
IO Config 2= PIN_HDMI1_HOTPLUG@0000000000000000
IO Config 2= PIN_HDMI2_HOTPLUG@0000000001011304
IO Config 2= PIN_HDMI3_HOTPLUG@0000000001011004
IO Config 2= PIN_EEP_WP@0000000000015103
IO Config 2= PIN_GLED_ON_OFF@0000000000010004
IO Config 2= PIN_LED_ON_OFF@0000000100010004
IO Config 2= PIN_RLED_ON_OFF@0000000000010004
IO Config 2= PIN_PROGRAMING_LED@0000000000010004
IO Config 2= PIN_AMP_MUTE@0000000100010b04
IO Config 2= PIN_POWER_EN@0000000100010704
IO Config 2= PIN_FLASH_WP@0000000000011303
[initmodules.c 270]:initmodules 5
load bbt...
nand info:W29N01GV,6b/seq
[initmodules.c 275]:initmodules 6
flash read factory starting..............
load factory to (addr 0x81a00000)...
pp 0 okpp 1 okpp_ok = 3
current_pp = 0 seq_num = 2247 tarsize = 6000
read factory from 81a00000 tarsize = 24576
[initmodules.c 285]:initmodules 7
#@#[cfyeh-debug] env_init(1409)
name=EEP_I2C ppcb_enum.Name=EEP_I2C, ppcb_enum.info=0000000000000000
name=EEP_DEVICE_ADDR ppcb_enum.Name=EEP_DEVICE_ADDR, ppcb_enum.info=0000000000000050
name=PIN_EEP_WP ppcb_enum.Name=PIN_EEP_WP, ppcb_enum.info=0000000000015103
m_PIN_EEP_WP = 0xa
Panel: Use parameters in tmp/factory/panel.bin
Panel: sky_SDL320HYCD0812_9R0332E361S
[initmodules.c 289]:initmodules 8
[initmodules.c 294]:initmodules 9
[initmodules.c 296]:
[initmodules.c 302]:initmodules 10
[initmodules.c 306]:initmodules 11
[initmodules.c 322]:initmodules 12
[ETH] ROM BIST DONE = 841dffff
[initmodules.c 355]:initmodules 13
[initmodules.c 514]:initmodules 14
[initmodules.c 521]:initmodules 15
[initmodules.c 543]:initmodules 16
*****info_boot*****
REALTEK ROM Monitor, Revision 0010.0601.0001.
Copyright (c) Realtek Semiconductor Corp. - All Rights Reserved.
For a list of available commands, type 'help'.
Compilation time/version =      May  9 2015 09:51:58 /0010.0601.0001
SVN version =                   1702
MAC address =                   00.11.22.33.44.55
Processor Company ID/options =  0x01 (MIPS Technologies, Inc.) / 0x00
Processor ID/revision =         0x93 / 0x85
Endianness =                    Little
Flash memory size =             128 MByte
SDRAM size@ =                   128 MByte
First free SDRAM address =      0x800bb000
name=PIN_KEYPAD_POWER ppcb_enum.Name=PIN_KEYPAD_POWER, ppcb_enum.info=000000080f000001
Press 'ESC' to Monitor mode
======Rescue Process 3sadc_Key_info=000000080f000001 boot_ac_on=1======
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
======Rescue Process 3:Lsadc_Key_info=000000080f000001 boot_ac_on=1======
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
b806011c = 0
SSU off.
[DEBUG_MSG] fw_entry[0] offset = 0x1020000 length = 0x4ed640 (paddings = 0x500000)
[DEBUG_MSG] fw_entry[1] offset = 0x1520000 length = 0x182da0 (paddings = 0x1a0000)
[DEBUG_MSG] fw_entry[2] offset = 0x16c0000 length = 0x1e5c14 (paddings = 0x200000)
[DEBUG_MSG] fw_entry[3] offset = 0x18c0000 length = 0x29b22 (paddings = 0x40000)
Linux Kernel:信息太长,不能上传完
发表于: 2018-6-1 08:37:23
最后显示  不过  ,主芯片  或数据坏了  ,先刷机试试...不试不检查 不能确定哪里问题哦
 楼主| 发表于: 2018-6-1 10:04:56
谢谢,我从某宝买了个数据,可不管怎么样都刷不进去,也是按RTD芯片的操作 方法,按TAB键后再插电,一直没显示 reading install.img,大师帮看看,是哪里操作不对,这是控制台里的最后几行信息
>>>>>> loader start! (Dec 26 2014:16:14:02, version=00.01.01)
#@#[cfyeh-debug] check_boot_code_size(1099) nand_boot_size 0xc00000
#@#[cfyeh-debug] check_boot_code_size(1105) factory_size 0x400000
[JH] checksignatue(), open(/dev/mtdblock0) nand_boot_size(0xc00000) factory_size(0x400000)
no IMG_XXXX signature found
                BUS_TYPE = (null)
Hotplug: device "ram1" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram0" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram2" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram3" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram4" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram5" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram6" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram7" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram8" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram9" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram10" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram11" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram12" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram13" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram14" is skipped.
BUS_TYPE = (null)
Hotplug: device "ram15" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop0" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop1" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop2" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop3" is skipped.
                BUS_TYPE = (null)
Hotplug: device "loop5" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop6" is skipped.
BUS_TYPE = (null)
Hotplug: device "loop7" is skipped.
                BUS_TYPE = (null)
Hotplug: device "loop4" is skipped.
BUS_TYPE = (null)
Hotplug: device "mtdblock0" is skipped.
                usb 2-1: new full speed USB device using ohci and address 4
        usb 2-1: device not accepting address 4, error -62
                                usb 2-1: new full speed USB device using ohci and address 5
        eth0: link up, 100Mbps, full-duplex, lpa 0xFFFF
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
eth0: Set multicast.
Hotplug got one Net Hotplug of "LinkUP" from "eth0".
                        usb 2-1: device not accepting address 5, error -62
hub 2-0:1.0: unable to enumerate USB device on port 1
发表于: 2018-6-1 15:47:53
雷击机就是麻烦,不能刷程序?先刷引导程序再刷主程序试试!
发表于: 2018-6-6 11:51:49
换版吧,浪费时间的
发表于: 2018-6-7 12:15:35
这现象是进入老化模式了,清空用户存储器试试
 楼主| 发表于: 2018-6-7 13:21:37
已经换板了,后来检查是RTD2634D挂了,谢谢大家
发表于: 2018-6-7 13:32:18
谢楼 主 分享
发表于: 2018-6-8 16:44:01 来自手机
雷击机,如果客户用高清线信号的,芯片坏多
来自: 微社区
GMT+8, 2024-11-28 18:40 , Processed in 0.058880 sec., 9 queries .
