查看: 1364|回复: 8
创维47E8CRS开机后死机 打印信息 有治吗
发表于: 2018-5-24 11:43:59
片断
Helloworld012345689:;\]^_`ad
5280 wait5280 waitload bbt...load env to (addr 0xa0010000, size 64KB)...
FLASH_NAND_search_latest_env version=0x3b *latest=0x1700
5280 wait5280 waitremap(0xb8000e08)=0x1be6
]load factory to (addr 0x80100000)...
ping_no =0xff
pong_no =0xdb
spare err recovery from pong
copy factory from 0x70 to 0x60 , length=0x10
////////////////Found it 0x80100000
custom_audio1_leng=0
custom_video1_leng=0
custom_audio2_leng=0
custom_video2_leng=0
boot_usb_log_mode=0
bootloader: wd ac on
logo 1, music 1, light 255, poweron 1, acOn 1
1 :  1,free run 0,suspend
raw = yes
Found it 0x80100400
*****info_boot*****
REALTEK ROM Monitor, Revision 0001.0705.0060.
Copyright (c) Realtek Semiconductor Corp. - All Rights Reserved.
Realtek LINUX started...
Venus setting:
        ROSs have 4194304 bytes RAM.
        System CPU has 1 UART.
        System CPU uses internal timer interrupt.
        Bootloader version: 0001.0705.0060. This version string is of new format.
        Error! Bootloader has a wrong CPU ID?
        Ethernet Mac address: 00.11.22.33.44.55
        Model Config length=0
Base year of RTC is 2010.
audio addr: 1b00000
Config serial console: console=ttyS0,115200n8r
bootconsole [early0] enabled
CPU revision is: 00019385 (MIPS 24Kc)
FPU revision is: 01739300
 楼主| 发表于: 2018-5-24 11:56:31
*****info_boot*****
For a list of available commands, type 'help'.
Compilation time /version=      Nov 30 2011  21:53:00  /0001.0705.0060
MAC address =                   00.11.22.33.44.55
Processor Company ID/options =  0x01 (MIPS Technologies, Inc.) / 0x00
Processor ID/revision =         0x93 / 0x85
Endianness =                    Little
Flash memory size =             512 MByte
SDRAM size =                    512 MByte
First free SDRAM address =      0x800b8000
Press 'ESC' to Monitor mode
Linux Kernel:
        FW Image  to 0x80100000, size=0x5c3a40
Audio FW:
        FW Image  to 0x81b00000, size=0x1b2750
Video FW:
        FW Image  to 0x81d80000, size=0x252068
Audio data(1):
        FW Image  to 0x83000000, size=0x17399
Video data(1):
        FW Image  to 0x83100000, size=0x3c049
REG32(Audio_Mute_GPIO)=0x0
panel_init
5280Go 5280Go set wait us=[600000, current=v4o4]110696
Vodimnait TAS5711
disable
VP_PowerOnVideo
VBM: configured to SD!
WARNING[1]:VO: don't support this API line 110
VBM: configured to User Defined (1280, 720)
WARNING[1]:H264DEC: bitstream error (slice header decode/setup, errCode=-56)!
start wait us=600000, first=44110696, last=60310696, current=47173706
[vo] ipg1080p_frc_fhd_dibypass !!!
NULL == ptSlrVoInfo
WARNING:registerbuffer: unused. task = 1. reg = 0
VIDEO FATAL SW TRAP tskID = 255, msgID =  0x0000fe06
Video 392320
STATUS =  0xb0000004
CAUSE  =  0x00000200
EPC    =  0x81d839a0
ESTATUS=  0x00000000
ECAUSE =  0x00000000
RADDR  =  0x81ed3610
0x90000008: 0x00000000 0xfffffffe 0x00000200 0x00000035
0x90000018: 0x0000000a 0x0000fe06 0x81f993b4 0x00000050
0x90000028: 0xb000ff01 0x00000001 0x00000002 0x00000000
0x90000038: 0x81d87ccc 0x81d87cd0 0x00000000 0x00007530
0x90000048: 0x00000001 0x00000000 0x00000100 0x8400e1a0
0x90000058: 0x84140118 0x84140110 0x8400d9
h4F 0ox0rc0000e 0020c
   0xF90o00r0m0a6t8::  0xD00T00S 0D0T0S8H D0 x0A0C003 0044D D0P xbM0L0P0 fAAfC0 4 0WxM81Ad8P3R9Oa0
00Sxt9a0r000t P0ow7e8:r  O0x8n1f 97Mua4si0c  F0lxo9w00
f2
83 0 [A0Ux0DI0O00]0v0ol04  0= x-8117 d
  a08
0xa1d83990: 0x3c0481fc 0x40026800 0x34420200 0x40826800
0xa1d839a0: 0x03e02821 0x0c762e9c 0x24040002 0xp0o8w76er0 eo6bn
AmTuAsLi EcRR OR:c Sroefattwe araoe Trokap
iIfSRi!n!
sh power on music create
panel_init  DCLK = 0xb8000530 = 2101700
panel_init  DCLKOffset = 0xb8000540 = 86e90089
panel_init  DispTiming = 0xb8028000 = 3530400
panel_init  DVTotal 0xb8028014 = 464
panel_init  DHTotal 0xb802800c = 8970897
kernel_entry->offset =0x20000
block_no =0x81
kernel_entry->length =0x5c3a40
kernel_entry->target_addr =0x80100000
* Exception : Coprocessor Unusable *
FATAL: Audio ROS Unexpected interrupt error!!
EPC:     0x00000010
Cause:   0x00000028
Problem results from co-processor 0
Interrupt pending is  0x00000000
ExcCode = RI
Return ADDR:     0x00000000
Bad ADDR:        0x00000000
status:  0xb000ff04
estatus:         0x00ff0000
ECAUSE:  0x00000000
Running Task is unknown
Audio CPU Registers:
z0: 0x00000000, at: 0xffff01ff, v0: 0x81cbd0b8, v1: 0x81cbd0b8
a0: 0x00000018, a1: 0x00000003, a2: 0xffb5fffc, a3: 0x000000d8
t0: 0xb000ff01, t1: 0x00ff0000, t2: 0x00000020, t3: 0x00000007
t4: 0x00000000, t5: 0x00000065, t6: 0x00000065, t7: 0x00000001
s0: 0x00000069, s1: 0x00000004, s2: 0x83c0e078, s3: 0x90000004
s4: 0x83c0e078, s5: 0x00000000, s6: 0xb0000400, s7: 0x00000001
t8: 0x00047a08, t9: 0xfffffffe, k0: 0xb000ff04, k1: 0x81b3c550
gp: 0x81cb2750, sp: 0x83c050d8, s8: 0x83c050d8, ra: 0x81b3c6b8
发表于: 2018-5-24 13:54:06
看打印信息CPU 不过 ,可能要换主芯片了...
发表于: 2018-5-24 14:10:27
先換数据试试。
 楼主| 发表于: 2018-5-24 14:15:35
cpu 滚烫  偶尔能过 过了后 几秒 死机  我重做一次试下   淘宝 rtd2974B  10元 加运费20元  一块旧板  40元加运费12块  重做不行就直接换板划算点
发表于: 2018-5-24 15:02:32
谢谢你的分享
发表于: 2018-5-24 17:53:25
谢谢楼主分享
发表于: 2018-5-24 18:12:22
感谢分享,谢谢楼主。
发表于: 2018-5-24 19:34:42
ygh1102001 发表于 2018-5-24 14:15
cpu 滚烫  偶尔能过 过了后 几秒 死机  我重做一次试下   淘宝 rtd2974B  10元 加运费20元  一块旧板  40元 ...
看来还是换板最省时。
GMT+8, 2024-11-28 17:42 , Processed in 0.057185 sec., 10 queries .
