查看: 2053|回复: 3
那个大神帮看看打印信息
发表于: 2018-5-15 16:22:30
海信LED42K3110
Boot-
DRAM Channel A Calibration.
  0 00 00 ff ff
  1 00 00 ff ff
  2 00 00 ff ff
  3 00 00 ff ff
  4 00 00 ff ff
  5 00 00 00 ff
  6 00 00 00 ff
  7 00 00 00 00
  8 ff ff 00 00
  9 ff ff 00 00
10 ff ff 00 00
11 ff ff 00 00
12 ff ff 00 00
13 ff ff 00 00
14 ff ff 00 00
15 ff ff 00 00
16 ff ff 00 00
17 ff ff 00 00
18 ff ff 00 00
19 ff ff 00 00
20 ff ff 00 00
21 ff ff 00 00
22 ff ff 00 00
23 ff ff 00 00
24 ff ff 00 00
25 ff ff 00 00
26 ff ff 00 00
27 ff ff 00 00
28 ff ff 00 00
29 ff ff ff 00
30 ff ff ff ff
31 ff ff ff ff
32 ff ff ff ff
33 ff ff ff ff
34 ff ff ff ff
35 ff ff ff ff
36 ff ff ff ff
37 ff ff ff ff
38 ff ff ff ff
39 ff ff ff ff
40 ff ff ff ff
41 ff ff ff ff
42 ff ff ff ff
43 ff ff ff ff
44 ff ff ff ff
45 ff ff ff ff
46 ff ff ff ff
47 00 ff ff ff
48 00 ff ff ff
49 00 00 ff ff
50 00 00 ff ff
51 00 00 ff ff
52 00 00 ff ff
53 00 00 ff ff
54 00 00 ff ff
55 00 00 ff ff
56 00 00 ff ff
57 00 00 ff ff
58 00 00 ff ff
59 00 00 ff ff
60 00 00 ff ff
61 00 00 ff ff
62 00 00 ff ff
63 00 00 ff ff
64 00 00 ff ff
65 00 00 ff ff
66 00 00 ff ff
67 00 00 ff ff
68 00 00 ff ff
69 00 00 00 ff
70 00 00 00 ff
71 00 00 00 00
72 ff ff 00 00
73 ff ff 00 00
74 ff ff 00 00
75 ff ff 00 00
76 ff ff 00 00
77 ff ff 00 00
78 ff ff 00 00
79 ff ff 00 00
80 ff ff 00 00
81 ff ff 00 00
82 ff ff 00 00
83 ff ff 00 00
84 ff ff 00 00
85 ff ff 00 00
86 ff ff 00 00
87 ff ff 00 00
88 ff ff 00 00
89 ff ff 00 00
90 ff ff 00 00
91 ff ff 00 00
92 ff ff 00 00
93 ff ff ff 00
94 ff ff ff ff
95 ff ff ff ff
96 ff ff ff ff
97 ff ff ff ff
98 ff ff ff ff
99 ff ff ff ff
100 ff ff ff ff
101 ff ff ff ff
102 ff ff ff ff
103 ff ff ff ff
104 ff ff ff ff
105 ff ff ff ff
106 ff ff ff ff
107 ff ff ff ff
108 ff ff ff ff
109 ff ff ff ff
110 ff ff ff ff
111 00 ff ff ff
112 00 ff ff ff
113 00 00 ff ff
114 00 00 ff ff
115 00 00 ff ff
116 00 00 ff ff
117 00 00 ff ff
118 00 00 ff ff
119 00 00 ff ff
120 00 00 ff ff
121 00 00 ff ff
122 00 00 ff ff
123 00 00 ff ff
124 00 00 ff ff
125 00 00 ff ff
126 00 00 ff ff
127 00 00 ff ff
byte_i    status    best delay
0    3    8
1    3    8
2    3    29
3    3    30
1T = (86 - 19) = 67 delay cells
Clock frequency = 798 MHz, Clock period = 1253 ps, 1 delay cell =18 ps
Byte 0 : Gating(-33 ~ 33), Size=67 .
Byte 1 : Gating(-33 ~ 33), Size=67 .
Byte 2 : Gating(-33 ~ 33), Size=67 .
Byte 3 : Gating(-32 ~ 33), Size=66 .
error on bit 0 ,setup_time =hold_time =0!!
error on bit 1 ,setup_time =hold_time =0!!
error on bit 2 ,setup_time =hold_time =0!!
error on bit 3 ,setup_time =hold_time =0!!
error on bit 4 ,setup_time =hold_time =0!!
error on bit 5 ,setup_time =hold_time =0!!
error on bit 6 ,setup_time =hold_time =0!!
error on bit 7 ,setup_time =hold_time =0!!
error on bit 8 ,setup_time =hold_time =0!!
error on bit 9 ,setup_time =hold_time =0!!
error on bit 10 ,setup_time =hold_time =0!!
error on bit 11 ,setup_time =hold_time =0!!
error on bit 12 ,setup_time =hold_time =0!!
error on bit 13 ,setup_time =hold_time =0!!
error on bit 14 ,setup_time =hold_time =0!!
error on bit 15 ,setup_time =hold_time =0!!
HW Byte 0 : DQS(0 ~ 0), Size 0 , Set 0.
HW Byte 1 : DQS(0 ~ 0), Size 0 , Set 0.
HW Byte 2 : DQS(-8 ~ 16), Size 25 , Set 4.
HW Byte 3 : DQS(-10 ~ 15), Size 26 , Set 3.
RX DQ/DQS calibration fail!
DATLAT calibration
no DATLAT taps pass
default tx dq PI delay value(16) is fail on bit 0!!
default tx dq PI delay value(16) is fail on bit 1!!
default tx dq PI delay value(16) is fail on bit 2!!
default tx dq PI delay value(16) is fail on bit 3!!
default tx dq PI delay value(16) is fail on bit 4!!
default tx dq PI delay value(16) is fail on bit 5!!
default tx dq PI delay value(16) is fail on bit 6!!
default tx dq PI delay value(16) is fail on bit 7!!
default tx dq PI delay value(16) is fail on bit 8!!
default tx dq PI delay value(16) is fail on bit 9!!
default tx dq PI delay value(16) is fail on bit 11!!
default tx dq PI delay value(16) is fail on bit 12!!
default tx dq PI delay value(16) is fail on bit 13!!
TX HW Byte 0 : DQS(5 ~ -16), Size -20, Set 59.
TX HW Byte 1 : DQS(6 ~ -16), Size -21, Set 1.
TX HW Byte 2 : DQS(0 ~ 23), Size 24, Set 12.
TX HW Byte 3 : DQS(1 ~ 25), Size 25, Set 13.
TX DQ/DQS calibration fail!
发表于: 2018-6-7 19:17:38
刷程序试试。
发表于: 2018-6-8 08:26:06
查下DDR到主芯片排阻
GMT+8, 2024-12-21 14:51 , Processed in 0.048671 sec., 9 queries .
