查看: 1773|回复: 8
帮分析打印信息!
发表于: 2018-4-20 12:30:35
帮分析打印信息!谢谢师傅!
 楼主| 发表于: 2018-4-20 12:34:27
帮分析打印信息!
乐视S40 Air不开机打印信息.zip
1.37 KB, 下载次数: 58, 下载积分: 金钱 -10
发表于: 2018-4-20 14:33:39
zhss2580 发表于 2018-4-20 12:34
帮分析打印信息!
你把你的打印信息粘贴出来不行吗?
发表于: 2018-4-21 10:29:30
待机的了 遥控开机
 楼主| 发表于: 2018-4-21 14:37:37
2018-4-2, 11:14:3
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
UART_115200
AC_ON
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 1bf00000
[AT][MB][start ub][900]
U-Boot 2011.06-00000-g39fbebe-dirty (Nov 22 2016 - 19:56:37)
[NOS] UtopiaInit
1st UTOPIARegisterToUtopia is done[MBoot] Driver Register to UtopiaAC on
uboot held at [3c0ddf60~3e000000]
CPU  : Napoli
Board: BD_MST051D_20ANV_NAPOLI
DRAM:  480 MiB
Now running in RAM - U-Boot at: 3d100000
eMMC: HS200 200MHz
eMMC 14.55 GB [1D1EFF8h]
In:    serial
Out:   serial
Err:   serial
original bootargs: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x20000000 LX_MEM3=0xB1400000,0x2EA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0 pname=S240F 3d=2 Channel=LETV-s40airc
getenv dtmb error
set default DTMB
getenv system_update error
no this env system_update
new bootargs: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x20000000 LX_MEM3=0xB1400000,0x2EA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0 pname=S240F 3d=2 Channel=LETV-s40airc
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0xc8: 0xe: 0x77: 0x8e:0x5a: 0xbf
msIR_Initialize
mmc change mount : factory1
Size of file "/device.ini" from mmc device 0 partition factory1: 96 bytes
Loading file "/device.ini" at offset 0x0 from mmc device 0 partition factory1
96 bytes read
mmc change mount : factory2
Size of file "/device.ini" from mmc device 0 partition factory2: 116 bytes
Loading file "/device.ini" at offset 0x0 from mmc device 0 partition factory2
116 bytes read
OnOffValue[0]: 1
InOutValue[0]: 1
OnOffValue[1]: 1
InOutValue[1]: 1
OnOffValue[2]: 1
InOutValue[2]: 1
read GPIO FLASH_WP reTryCnt : 0, reReadCnt : 0
rdOnOffValue[0]:0
rdOnOffValue[1]:0
rdOnOffValue[2]:0
Changelist:        00112233
Unknown command 'if_51OnRam_set' - try 'help'
setCtvFacTestMode==bootargs =console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x20000000 LX_MEM3=0xB1400000,0x2EA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0 pname=S240F 3d=2 Channel=LETV-s40airc
AC on
Writing to MMC(0)... done
MPOOL size : 0x200000
AC on
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
Wait for PM51 stand
 楼主| 发表于: 2018-4-21 14:40:30
开机指示灯就亮一下!不开机黑屏!
发表于: 2018-4-25 09:09:59
处于待机模式,要想办法开机
GMT+8, 2024-12-21 15:06 , Processed in 0.058958 sec., 13 queries .
